EPSON爱普生晶振型号:SG2520VGN,编码为:X1G0059010002,频率:156.250000 MHz,小体积晶振尺寸2.5x2.0x0.84mm封装,六脚贴片晶振,LVDS输出差分晶振,石英晶振,有源晶振,SPXO石英晶体振荡器。6G将以指数级的方式增加网络通信流量。6G通信网络需要高速和宽带宽,同时最小化噪声,这将通过一个高频、低抖动参考时钟来实现的通信设备,其中将使用小尺寸光学模块。SG2520VGN是非常流行的SG3225VEN系列的下一代,提供相同的功能组合,由于使用内部设计的IC和改进的频率容忍性能。具有超小型,轻薄型,低抖动,低功耗晶振,低电源电压,低耗能,低损耗,低相位声等特点。SG2520VGN石英晶振应用于:网络设备(路由器、交换机、光模块等),数据中心,测试和测量设备,工厂自动化,高速转换器,ADC和DAC,光纤通道,服务器、存储、无线网络、0TN等。
差分晶振优势:
差分晶振具有低电平,低抖动,低功耗等特性。差分品振作为目前行业中高要求、高技术石英晶体振荡器,具有相位低、损耗低的特点。因此也被称之为“低抖动振荡器,低抖动石英晶振,低相位晶振,低损耗晶振”① 能够很容易地识别小信号。
② 对外部电磁干扰(EMI)是高度免疫的,
③ 能够从容精确地处理"双极'信号
| 进口晶振 | 型号 | 频率 | 尺寸 | 输出方式 | 电源电压 |
| X1G0059010001 | SG2520VGN | 156.250000 MHz | 2.50x2.00x0.84 mm | LVDS | 3.135 to 3.465 V |
| X1G0059010002 | SG2520VGN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 1.710 to 1.890V |
| X1G0059010003 | SG2520VGN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 2.375 to 2.625 V |
| X1G0059010004 | SG2520VGN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 3.135 to3.465 V |
| X1G0059010006 | SG2520VGN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 2.375 to 2.625 V |
| X1G0059010007 | SG2520VGN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 1.710 to 1.890V |
| X1G0059010008 | SG2520VGN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 2.375 to 2.625 V |
| X1G0059410001 | SG2520VHN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 3.135 to 3.465 V |
| X1G0059410002 | SG2520VHN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 2.375 to 2.625 V |
| X1G0059410003 | SG2520VHN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 1.710 to 1.890V |
| X1G0059410004 | SG2520VHN | 156.250000 MHz | 爱普生晶振 | LVDS | 1.710 to 1.890V |
| X1G0059410005 | SG2520VHN | 156.250000 MHz | 2.50x2.00x0.84 mm | LVDS | 3.135 to 3.465 V |
| X1G0059410006 | SG2520VHN | 155.520000 MHz | 2.50x2.00x 0.84 mm | LVDS | 3.135 to 3.465 V |
| X1G0059410007 | SG2520VHN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 1.710 to 1.890V |
| X1G0059410008 | SG2520VHN | 174.703000 MHz | 2.50x2.00x 0.84 mm | LVDS | 2.375 to 2.625 V |
| X1G0059410009 | SG2520VHN | 156.250000 MHz | 2.50x2.00x0.84 mm | LVDS | 2.375 to 2.625 V |
| X1G0059410010 | SG2520VHN | 156.250000 MHz | 2.50x2.00x 0.84 mm | LVDS | 3.135 to 3.465 V |
| X1G0059410011 | SG2520VHN | 156.250000 MHz | 2.50x2.00x0.84 mm | LVDS | 1.710 to 1.890V |
| X1G0059410603 | SG2520VHN | 400.000000 MHz | 2.50x2.00x 0.84 mm | LVDS | 2.970 to 3.465V |
| X1G0059410604 | SG2520VHN | 400.000000 MHz | 2.50x2.00x0.84 mm | LVDS | 2.970 to 3.465 V |
| X1G0059410605 | SG2520VHN | 467.529297 MHz | 2.50x2.00x0.84 mm | LVDS | 1.710 to 1.890V |
