LOG:
02-22 17:50:01.931 E/ROCKCHIP_VIDEO_DECCONTROL( 223): event OMX_BUFFERFLAG_EOS!!!
02-22 17:50:01.932 D/ACodec ( 5155): [OMX.rk.video_decoder.hevc] saw output EOS
02-22 17:50:01.941 I/pv_hevcdec_api( 223): pv_rkhevcdecoder_flush out
02-22 17:50:01.950 E/SampleIterator( 5155): getChunkOffset return error
02-22 17:50:01.950 W/NuMediaExtractor( 5155): read on track 0 failed with error -1004
02-22 17:50:01.964 E/SampleIterator( 5155): getChunkOffset return error
02-22 17:50:01.964 W/NuMediaExtractor( 5155): read on track 0 failed with error -1004
Patch:
media/libstagefright/FileSource.cpp | 34 ++++++++++++++++++++++++++++------
1 file changed, 28 insertions(+), 6 deletions(-)
diff --git a/media/libstagefright/FileSource.cpp b/media/libstagefright/FileSource.cpp
index 8005a05..73c476c 100644
--- a/media/libstagefright/FileSource.cpp
+++ b/media/libstagefright/FileSource.cpp
@@ -60,12 +60,34 @@ FileSource::FileSource(int fd, int64_t offset, int64_t length)
mDrmBufOffset(0),
mDrmBufSize(0),
mDrmBuf(NULL){
- CHECK(offset >= 0);
- CHECK(length >= 0);
- /*Begin: 2011120903153 added by g00166974 20110603 . */
- /*Begin: 2011120903153 deleted by h00184579 20120325 for FD*/
- //mFileName = NULL;
- /*End: 2011120903153 deleted by h00184579 20120325 for FD*/
+ ALOGV("fd=%d, offset=%lld, length=%lld",
+ fd, (long long) offset, (long long) length);
+ if (mOffset < 0) {
+ mOffset = 0;
+ if (mLength < 0) {
+ mLength = 0;
+ if (mLength > INT64_MAX - mOffset) {
+ mLength = INT64_MAX - mOffset;
+ struct stat s;
+ if (fstat(fd, &s) == 0) {
+ if (mOffset > s.st_size) {
+ mOffset = s.st_size;
+ mLength = 0;
+ if (mOffset + mLength > s.st_size) {
+ mLength = s.st_size - mOffset;
+ if (mOffset != offset || mLength != length) {
+ ALOGW("offset/length adjusted from %lld/%lld to %lld/%lld",
+ (long long) offset, (long long) length,
+ (long long) mOffset, (long long) mLength);
mIsDrmPreview = false;
/*End: 2011120903153 added by g00166974 20110603 . */
LOG:
Patch:
mDrmBufOffset(0),
mDrmBufSize(0),
mDrmBuf(NULL){
+ mOffset = 0;
+ mLength = 0;
+ struct stat s;
+ mLength = 0;
