Platform: ROCKCHIP
OS: Android 6.0
Kernel: 3.10.92
此方法适用于全新eMMC(MaskRom模式)以及已经刷过系统的(RockU***模式)板子升级。
1. 编译整个系统。
$ 。/1_build_debug.sh
2. 拷贝所有 Images
$ cp rockdev/rk3288-eng/* RKTools/linux/Linux_Pack_Firmware/rockdev/Images
3. 拷贝loader
$cpockdev/rk3288-eng/RK3288UbootLoader_V2.30.10.bin RKTools/linux/Linux_Pack_Firmware/rockdev/
4. 修改package-file
# NAME Relative path #HWDEF HWDEF package-file package-file bootloader RK3288UbootLoader_V2.30.10.bin parameter parameter resource Image/resource.img kernel Image/kernel.img boot Image/boot.img recovery Image/recovery.img system Image/system.img backup RESERVED
5. 修改parameter
FIRMWARE_VER:6.0.0 MACHINE_MODEL:rk3288 MACHINE_ID:007 MANUFACTURER:RK3288 MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 3288 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 CMDLINE:console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),0x00008000@0x00192000(metadata),0x00020000@0x0039A000(radical_update),-@0x003BA000(userdata)
6. 修改mkupdate.sh
#!/bin/bash
pause()
echo “Press any key to quit:”
read -n1 -s key
exit 1
echo “start to make update.img.。.”
if [ ! -f “parameter” ]; then
echo “Error:No found parameter!”
pause
fi
if [ ! -f “package-file” ]; then
echo “Error:No found package-file!”
pause
fi
。/afptool -pack 。/ Image/update.img || pause
。/rkImageMaker -RK32 RK3288UbootLoader_V2.30.10.bin Image/update.img update.img -os_type:androidos || pause
echo “Making update.img OK.”
read -n1 -s key
exit 0
7. 生成update.img
[kris@:~/rk3288/RKTools/linux/Linux_Pack_Firmware/rockdev]$ 。/mkupdate.sh
Android Firmware Package Tool v1.62
------ PACKAGE ------
Add file: 。/package-file
Add file: 。/RK3288UbootLoader_V2.30.10.bin
Add file: 。/parameter
Add file: 。/Image/resource.img
Add file: 。/Image/kernel.img
Add file: 。/Image/boot.img
Add file: 。/Image/recovery.img
Add file: 。/Image/system.img
Add CRC.。.
Make firmware OK!
------ OK ------
********RKImageMaker ver 1.63********
Generating new image, please wait.。.
Writing head info.。.
Writing boot file.。.
Writing firmware.。.
Generating MD5 data.。.
MD5 data generated successfully!
New image generated successfully!
8. 插上u*** cable线,升级
upgrade_tool从 rk3288/RKTools/linux/Linux_Upgrade_Tool/Linux_Upgrade_Tool_v1.23
Copy过来。
[kris@:~/rk3288/RKTools/linux/Linux_Pack_Firmware/rockdev_bk]$ 。/upgrade_tool
List of rocku*** connected
DevNo=1 Vid=0x2207,Pid=0x320a,LocationID=31a Maskrom
Found 1 rocku***,Select input DevNo,Rescan press 《R》,Quit press 《Q》:1
---------------------Tool Usage ---------------------
Help: H
Quit: Q
Version: V
Clear Screen: CS
------------------Upgrade Command ------------------
ChooseDevice: CD
SwitchDevice: SD
UpgradeFirmware: UF 《Firmware》
UpgradeLoader: UL 《Loader》
DownloadImage: DI 《-p|-b|-k|-s|-r|-m image》 [parameter file]
DownloadBoot: DB 《Loader》
EraseFlash: EF 《Loader|firmware》
LowerFormat: LF
----------------Professional Command -----------------
TestDevice: TD
ResetDevice: RD [subcode]
ResetPipe: RP [pipe]
ReadFlashID: RID
ReadFlashInfo: RFI
ReadChipInfo: RCI
ReadSector: RS 《BeginSec》 《SectorLen》 [-decode] [File]
WriteSector: WS 《BeginSec》 《File》
ReadLBA: RL 《BeginSec》 《SectorLen》 [File]
WriteLBA: WL 《BeginSec》 《File》
EraseBlock: EB 《CS》 《BeginBlock》 《BlokcLen》 [--Force]
Rocku***》uf update.img
Loading firmware.。.
Support Type:RK32 FW Ver:6.0.00 FW Time:2016-10-25 11:36:04
Loader ver:2.30 Loader Time:2016-09-06 14:29:09
Upgrade firmware ok.
这样就可以开机了。
Platform: ROCKCHIP
OS: Android 6.0
Kernel: 3.10.92
1. 编译整个系统。
2. 拷贝所有 Images
3. 拷贝loader
4. 修改package-file
5. 修改parameter
6. 修改mkupdate.sh
#!/bin/bash
pause()
read -n1 -s key
exit 1
pause
fi
pause
fi
read -n1 -s key
exit 0
7. 生成update.img
Add CRC.。.
Make firmware OK!
------ OK ------
Writing firmware.。.
8. 插上u*** cable线,升级
Copy过来。
Help: H
Quit: Q
Version: V
Clear Screen: CS
ChooseDevice: CD
SwitchDevice: SD
LowerFormat: LF
TestDevice: TD
ReadFlashID: RID
ReadFlashInfo: RFI
ReadChipInfo: RCI
Loading firmware.。.
这样就可以开机了。
