瑞芯微Rockchip开发者社区
剪刀脚
8年用户 823经验值
RK3288移植Ubuntu文件系统的过程是怎么样的?
蓝孝增
2022-3-10 10:49:33
1,  linux下 unpack 解包
报错
root@Ubuntu:/opt/rk-linux/mkimg# ./unpack.sh
start to unpack update.img...
********RKImageMaker ver 1.61********
Unpacking image, please wait...
Error:update.img is not exist!
Press any key to quit:
解包的命令有问题,在linux下不能正常解包
2,    继续打包.
测试在安卓下面运行是可以的:
liupingwei@xdtUbuntu:~/RK3288/rk3288Android5.1$ ./FFTools/mkupdate/mkupdate.sh
PRODUCT_FIREFLY_NAME=Public
TARGET_PRODUCT=rk3288_box
Android Firmware Package Tool v1.62
------ PACKAGE ------
Add file: ./package-file
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/parameter.txt
Add file: ./Image/misc.img
Add file: ./Image/resource.img
Add file: ./Image/kernel.img
Add file: ./Image/boot.img
Add file: ./Image/recovery.img
Add file: ./Image/system.img
Add CRC...
Make firmware OK!
------ OK ------
********RKImageMaker ver 1.63********
Generating new image, please wait...
Writing head info...
Writing boot file...
Writing firmware...
Generating MD5 data...
MD5 data generated successfully!
New image generated successfully!
Making updateimg: rockdev/Image-rk3288_box/Firefly-RK3288_Android5.1.1_Public_181023.img
应该是缺少环境变量配置,所以才会 导致直接执行不通
3, 找到原因, 执行脚本的时候有个字符不匹配:
./afptool -pack ./ Image/update.img || pause
./rkImageMaker -RK32 RK3288Loader_uboot_V2.15.01.bin Image/update.img update.img -os_type:androidos || pause
# Ubuntt# ./rkImageMaker -RK32 rk3288_bootloader_v1.00.06.bin Image/update.img update.img -os_type:androidos || pause
后可生成
liupingwei@xdtUbuntu:~/RK3288/rk3288Android5.1/RKTools/linux/Linux_Upgrade_Tool_v1.2/rockdev$ ./rkImageMaker -RK32 rk3288_bootloader_v1.00.06.bin Image/update.img update.img -os_type:androidos || pause
Writing firmware...
改成新的脚本执行:
root@Ubuntu:/opt/rk-linux/mkimg# ./umkupdate_ubuntu.sh
start to make update.img...
Android Firmware Package Tool v1.0
Add file: ./rk3288_bootloader_v1.00.06.bin
Add file: ./parameter
Add file: ./linux-kernel.img
Add file: ./linux-resource.img
Add file: ./ubuntu1604armhf-rootfs.img
Add file: ./update-script
Add file: ./recover-script
Add CRC...
Make firmware OK!
------ OK ------
Writing firmware...
Making update.img OK.
4, 文件系统制作的在显卡部分应该有问题,导致启动卡死在 显卡驱动部分
5, 继续制作文件系统
替换\192.168.0.102optrk-linuxmkimg 目录下的  ubuntu1604armhf-rootfs.img
cd ..
./ch-mount.sh -m linux-rootfs
进入挂载模式
3、卸载软件
 1)sudo apt-get remove XXXX     #卸载软件(删除软件包)
 2)sudo apt-get autoremove XXXX          #自动卸载软件但保留其配置文件
 3)sudo apt-get autoremove --purge  XXXX      #自动卸载软件其删除其配置文件
apt-get autoremove --purge    ubuntu-session xubuntu-desktop
重新安装:
root@Ubuntu:/# apt-get install ubuntu-session xubuntu-desktop
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xubuntu-desktop : Depends: gtk2-engines-pixbuf but it is not going to be installed
                   Depends: xubuntu-artwork but it is not going to be installed
                   Depends: xubuntu-core but it is not going to be installed
                   Depends: xubuntu-default-settings but it is not going to be installed
                   Recommends: brltty-x11 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
红色部分是依赖库,需要安装:
apt-get install  gtk2-engines-pixbuf
apt-get install  xubuntu-artwork
apt-get install  xubuntu-core
apt-get install  xubuntu-default-settings
apt-get install  brltty-x11
apt-get install
apt install ibgtk2.0-0
apt-get install libgtk2.0-dev
gtk2-engines-pixbuf
gtk2-engines-pixbuf : Depends: libgtk2.0-0 (= 2.24.30-1ubuntu1) but 2.24.30-1ubuntu1.16.04.2 is to be installed
apt-get install
xubuntu-artwork
xubuntu-artwork : Depends: shimmer-themes but it is not going to be installed
apt-get install
xubuntu-core
apt-get install
apt-get install
brltty-x11
root@Ubuntu:/# apt-cache policy libgtk2.0-0
libgtk2.0-0:
  Installed: 2.24.30-1ubuntu1.16.04.2
  Candidate: 2.24.30-1ubuntu1.16.04.2
  Version table:
*** 2.24.30-1ubuntu1.16.04.2 500
        500 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main armhf Packages
        100 /var/lib/dpkg/status
     2.24.30-1ubuntu1 500
        500 http://ports.ubuntu.com/ubuntu-ports xenial/main armhf Packages
root@Ubuntu:/#
如何指定安装2.0版本呢?
apt-get autoremove  --purge libgtk2.0-dev
apt-cache policy libgtk2.0-dev
参考:  http://dev.t-firefly.com/thread-12732-1-19.html
原因: 需要clean 及重新 update
NOTICE:
apt-get upgrade
apt-get autoclean
apt-get update
后:
正常
