瑞芯微Rockchip开发者社区
9年用户 781经验值
擅长:可编程逻辑
如何对RK3288的ubuntu根文件系统进行配置呢
怎样去修改RK3288的ubuntu根文件系统播放呢?
如何对RK3288的ubuntu根文件系统进行配置呢?
h1654155275.5697
2022-3-4 13:41:36
  下载ubuntu基本裸系统
  http://cdimage.ubuntu.com/ubuntu-base/releases/16.04/release/
  http://cdimage.ubuntu.com/ubuntu-base/releases/16.04/release/ubuntu-base-16.04-core-armhf.tar.gz
  下载ubuntu-base-16.04-core-armhf.tar.gz之后,建立一个ubuntufs文件,然后进行文件的解压,复制到ubuntufs文件夹里面:
  ---/rk3288$ mkdir ubuntufs
  ---/rk3288$ sudo tar -xpf ubuntu-base-16.04-core-armhf.tar.gz -C ubuntufs
  接下来就是修改我们的根文件系统
  在修改之前我们要做一些准备工作
  由于我们要chroot,所以需要能够在chroot环境执行arm64版本的binary,所以我们要接触linux的binfmt机制和qemu static解释器。qemu是纯软件实现的虚拟化模拟器,几乎可以模拟任何硬件设备,有了它就可以通过chroot命令进入不同平台架构的根文件系统进行相关操作。
  安装qemu
  ---/rk3288$ sudo apt-get install qemu-user-static
  然后复制到
  ---/rk3288$ sudo cp /usr/bin/qemu-arm-static ubuntufs/usr/bin/
  准备网络
  将本机的dns配置复制到目标rootfs
  ---/rk3288$ sudo cp -b /etc/resolv.conf ubuntufs/etc/resolv.conf
  把所有的# deb替换成deb,即取消注释,然后将所有链接换成阿里云的源。另外需要注意的是,其中的xenial代表ubuntu16.04版本,如果是ubuntu18.04则对应bionic。
  ---/rk3288$ sudo vi ubuntufs/etc/apt/sources.list
  # See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
  # newer versions of the distribution.
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial main restricted
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial main restricted
  ## Major bug fix updates produced after the final release of the
  ## distribution.
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial-updates main restricted
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial-updates main restricted
  ## Uncomment the following two lines to add software from the ‘universe’
  ## repository.
  ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
  ## team. Also, please note that software in universe WILL NOT receive any
  ## review or updates from the Ubuntu security team.
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial universe
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial universe
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial-updates universe
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial-updates universe
  ## N.B. software from this repository may not have been tested as
  ## extensively as that contained in the main release, although it includes
  ## newer versions of some applications which may provide useful features.
  ## Also, please note that software in backports WILL NOT receive any review
  ## or updates from the Ubuntu security team.
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial-backports main restricted
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial-backports main restricted
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial-security main restricted
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial-security main restricted
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial-security universe
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial-security universe
  deb http://mirrors.aliyun.com/ubuntu-ports/ xenial-security multiverse
  deb-src http://mirrors.aliyun.com/ubuntu-ports/ xenial-security multiverse
  使用chroot命令进入根文件系统进行操作
  ---/rk3288$ sudo chroot ubuntufs
  chroot,即 change root directory,更改root目录的意思,命令详情自查。
  root@chry-PC:/# ls
  bin boot dev etc home lib media mnt opt proc root run ***in srv sys tmp usr var
  root@chry-PC:/# pwd
  然后更新和安装软件
  最新的软件包列表,使用apt update命令,然后酌情使用apt upgrade命令更新已安装的软件。
  root@*****:/# apt update
  root@*****:/# apt upgrade
  然后是使用apt-get install命令安装需要用到的软件,这一步自行发挥。可以在最后面增加–no-install-recommends参数来避免安装非必须的文件,从而减小镜像的体积。
  root@*****:/# apt-get install vim net-tools iputils-ping ssh udhcpc sudo rsync --no-install-recommends
  添加用户及设置密码
  root@*****:/# useradd -s ‘/bin/bash’ -m -G adm,sudo chry
  root@*****:/# passwd chry
  Enter new UNIX password:
  Retype new UNIX password:
  passwd: password updated successfully
  root@*****:/# passwd root
  root@*****:/#
  设置可使用root用户登录ssh
  安装ssh后,默认情况下不允许使用root用户登录,需作以下修改:
  root@*****:/# vi /etc/ssh/sshd_config
  设置串口
  因为没有安装桌面,所以这里的配置要具体和内核中登录的串口的设备对应起来,不然对导致无法通过串口登录的问题。
  vi /lib/systemd/system/serial-getty@.service
  修改BindsTo选项:
  dev-%i.device改成dev-%i如果不执行这一步,烧录文件系统后启动,串口可能会卡死。
  串口自动登录root用户(可选)
  修改ExecStart选项:
  -/***in/agetty --keep-baud 115200,38400,9600 %I $TERM改成
  -/***in/agetty -a root --keep-baud 115200,38400,9600 %I $TERM
  设置主机名(可选)
  默认主机名为localhost.localdomain
  root@*****:/# echo ‘ubuntu.ubuntu’ 》 /etc/hostname
  添加主机入口
  root@*****:/# vi /etc/hosts
  127.0.0.1 localhost
  127.0.0.1 ubuntu.ubuntu
  如果不修改/etc/hosts,该系统每次运行sudo命令都会有错误提示,但不影响使用。
  制作根文件系统
  在修改完跟文件系统后,使用exit退出来,开始制作镜像文件。
  root@****:/# exit
  使用du命令查看一下修改后根文件系统的大小
  ubuntu@ubuntu-PC:~/code/rk3288$ sudo du -h --max-depth=0 ubuntufs/
  410M ubuntufs/
  用dd工具创建镜像文件,注意6G是分区大小:
  ubuntu@ubuntu-PC:~/code/rk3288$ dd if=/dev/zero of=linuxroot.img bs=1M count=6144
  记录了6144+0 的读入
  记录了6144+0 的写出
  6442450944 bytes (6.4 GB, 6.0 GiB) copied, 48.2686 s, 133 MB/s
  格式化镜像文件,并加入linuxroot卷标:
  ubuntu@ubuntu:~/code/rk3288$ mkfs.ext4 -F -L linuxroot linuxroot.img
  mke2fs 1.43.4 (31-Jan-2017)
  丢弃设备块: 完成
  创建含有 1572864 个块(每块 4k)和 393216 个inode的文件系统
  文件系统UUID:b9207194-30bc-4f8c-9476-70ccf7c83794
  超级块的备份存储于下列块:
  32768, 98304, 163840, 229376, 294912, 819200, 884736
  正在分配组表: 完成
  正在写入inode表: 完成
  创建日志(16384 个块)完成
  写入超级块和文件系统账户统计信息: 已完成
  挂载镜像并往里面拷入修改后的文件系统
  ubuntu@ubuntu-PC:~/code/rk3288$ mkdir rootfs
  ubuntu@ubuntu-PC:~/code/rk3288$ sudo mount linuxroot.img rootfs/
  ubuntu@ubuntu-PC:~/code/rk3288$ sudo cp -rfp ubuntufs/* rootfs/
  ubuntu@ubuntu-PC:~/code/rk3288$ sudo umount rootfs/
  linuxroot.img里就已经有刚才制作的根目录内容了,但linuxroot.img文件大小却是定义的分区大小,不是文件系统的实际大小,所以还要经过一些处理才能发布。检查并修复linuxroot.img镜像的文件系统,不熟悉的朋友可以通过网络了解此工具:
  ubuntu@ubuntu-PC:~/code/rk3288$ e2fsck -p -f linuxroot.img
  linuxroot:正在修复日志
  linuxroot:16382/393216 文件(0.0% 为非连续的), 75104/1572864 块
  减小ubuntu.img镜像文件的大小
  ubuntu@ubuntu-PC:~/code/rk3288$ resize2fs -M linuxroot.img
  resize2fs 1.43.4 (31-Jan-2017)
  将 linuxroot.img 上的文件系统调整为 206153 个块(每块 4k)。
  linuxroot.img 上的文件系统现在为 206153 个块(每块 4k)。
  ubuntu@ubuntu-PC:~/code/rk3288$ ls -lh linuxroot.img
  -rw-r--r-- 1 ubuntu ubuntu 806M 9月 4 09:48 linuxroot.img
  配置ubuntu文件系统
  源码中默认的Linux rootfs是buildroot,如果rootfs使用buildroot,跳过此步,需要使用用ubuntu文件系统。需要通过以下步骤来配置
  在device/rockchip/rk3288/BoardConfig_8846.mk中, 将“# rootfs image path”修改为:
  Export RK_ROOTFS_IMG=rootfs/linuxroot.img
  编译配置文件
  在工程目录下执行:
  。/build.sh BoardConfig_8846.mk
  模块化编译
  编译u-boot:
  。/build.sh uboot
  编译kernel
  。/build.sh kernel
  打包固件(工程目录下执行)
  。/mkfirmware.sh
  整理分区镜像到rockdev/目录下,每次打包固件前,需要运行mkfirmware.sh脚本更新rockdev/下的分区镜像。
  整合统一固件
  。/uild.sh updateimg
  注意:每次打包固件前,需要运行mkfirmware.sh脚本更新rockdev/下的分区镜像。
  测试根文件系统
  烧录
  测试___给rootfs分区扩展磁盘空间
  `sudo l***lk`
  sudo df -h
  检查根文件系统大小是否一致,如果,不一致,运行一下命令解决sudo resize2fs /dev/mmcblk2p*上面的*换成l***lk下根文件系统对应的编号。重新运行sudo df -h问题解决。网络测试ifconfig发现只有127.0.0.1,运行sudo udhcpc自动获取ip,测试ping命令,测试电脑上通过ssh使用root用户登录到板子上。
