瑞芯微Rockchip开发者社区
京五环以外
10年用户 3173经验值
擅长:EMC/EMI设计
请问RK3288平台Android6.0系统怎样去修改默认Launcher呢
请问RK3288平台Android6.0系统怎样去修改默认Launcher呢?
李瑜斌
2022-3-4 14:56:08
public class ResolverActivity extends Activity {
……//此处省略好多行
private static final String DEFAULT_HOME = "persist.sys.default.home";
……//此处省略好多行
protected void onCreate(Bundle savedInstanceState, Intent intent,
CharSequence title, int defaultTitleRes, Intent[] initialIntents,
ListrList, boolean alwaysUseOption) {
setTheme(R.style.Theme_DeviceDefault_Resolver);
super.onCreate(savedInstanceState);
……//此处省略好多行
setupDefaultLauncher(); //封装一个设置默认桌面的函数
……//此处省略好多行
……//此处省略好多行
private void setupDefaultLauncher() {
String first = "";
try{
first = SystemProperties.get(DEFAULT_HOME);
}catch(Exception e){
Log.w(TAG,"exception error get DEFAULT_HOME");
int position = mAdapter.getDefaultHomePosition("com.XXX.home");//在此处获取指定包名的Launcher的位置,mAdapter是ResolveListAdapter的引用
if (position == -1) {
if (DEBUG)
Log.w(TAG,"not find default Home");
return;
ResolveInfo ri = mAdapter.resolveInfoForPosition(position, true);
TargetInfo intent = mAdapter.targetInfoForPosition(position, true);
onTargetSelected(intent, false);
try{
SystemProperties.set(DEFAULT_HOME,DEFAULT_HOME);
Log.w(TAG,"exception error set DEFAULT_HOME");
startSelected(position, true, true);
dismiss();
public int getDefaultHomePosition(String packageName){
for (int i = 0; i < mDisplayList.size(); i++) {
ResolveInfo info = mDisplayList.get(i).mResolveInfo;
if (DEBUG)
Log.w(TAG,"getDefaultHomePosition " + info.activityInfo.packageName);
if (info.activityInfo.packageName.equals(packageName)) {
return i;
return -1;
……//此处省略好多行
