单片机/MCU论坛
金伟
44经验值
擅长:控制/MCU
MAX7219级联显示时有一个模块总是有闪烁
PIC单片机
最近学习
单片机
,用的是877A,4M晶振,在用MAX7219级联驱动4块8*8组成8*32点阵时,总是第三块有闪烁。请问是代码的问题吗?谢谢各位帮忙看一下,谢谢了!
#include
__CONFIG(HS&WDTDIS&LVPDIS);
#define INT8U unsigned char
#define _XTAL_FREQ 4000000UL
//定义Max7219端口
#define DIN RB0
#define CS RB1
#define CLK RB2
const INT8U disp1[10][8]={
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
{0x18,0x28,0x08,0x08,0x08,0x08,0x08,0x08},//1
{0x3c,0x42,0x42,0x02,0x1c,0x20,0x40,0x7E},//2
{0x3c,0x42,0x42,0x0c,0x2,0x42,0x42,0x3c},//3
{0x28,0x28,0x48,0x48,0x7e,0x8,0x8,0x8},//4
{0x3e,0x40,0x40,0x7c,0x2,0x2,0x42,0x3c},//5
{0x3e,0x42,0x40,0x7C,0x42,0x42,0x42,0x3c},//6
{0x7E,0x02,0x4,0x8,0x8,0x8,0x8,0x8},//7
{0x3c,0x42,0x42,0x3c,0x42,0x42,0x42,0x3c},//8
{0x3c,0x42,0x42,0x42,0x3e,0x2,0x42,0x3c}//9
//向MAX7219写入字节
void Write_Max7219_byte(INT8U DATA)
INT8U i;
CS=0; //CS=0有效,CS=1锁存
for(i=8;i>=1;i--)
CLK=0;
if(DATA & 0x80) DIN=1; else DIN=0;
//DIN=(DATA&0x80); //&10000000, 编译器对位操作的理解:非0即为1
DATA=DATA<<1;
CLK=1; //上升沿把数据送出去
//向M第一片MAX7219写入数据
void Write_Max7219_1(INT8U add1,INT8U dat1)
CS=0;
Write_Max7219_byte(add1); //写入地址,即数码管编号
Write_Max7219_byte(dat1); //写入数据,即数码管显示数字
CS=1;
//第二片MAX7219的写入数据
void Write_Max7219_2(INT8U add2,INT8U dat2)
CS=0;
Write_Max7219_byte(add2);
Write_Max7219_byte(dat2);
CLK=1;
Write_Max7219_byte(0x00); //片1写入空
CS=1;
//第三片MAX7219的写入数据
void Write_Max7219_3(INT8U add3,INT8U dat3)
CS=0;
Write_Max7219_byte(add3);
Write_Max7219_byte(dat3);
CLK=1;
Write_Max7219_byte(0x00); //片2写入空
CS=1;
//第四片MAX7219的写入数据
void Write_Max7219_4(INT8U add4,INT8U dat4)
CS=0;
Write_Max7219_byte(add4);
Write_Max7219_byte(dat4);
CLK=1;
Write_Max7219_byte(0x00); //片3写入空
CS=1;
//初始化芯片
void Init_MAX7219(void)
Write_Max7219_1(0x09, 0x00); //译码方式:不译码
Write_Max7219_1(0x0a, 0x00); //亮度最小
Write_Max7219_1(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_1(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_1(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0
Write_Max7219_2(0x09, 0x00); //译码方式:不译码
Write_Max7219_2(0x0a, 0x00); //亮度最小
Write_Max7219_2(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_2(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_2(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0
Write_Max7219_3(0x09, 0x00); //译码方式:不译码
Write_Max7219_3(0x0a, 0x00); //亮度最小
Write_Max7219_3(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_3(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_3(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0
Write_Max7219_4(0x09, 0x00); //译码方式:不译码
Write_Max7219_4(0x0a, 0x00); //亮度最小
Write_Max7219_4(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_4(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_4(0x0f, 0x00); //显示测试:1;测试结束,正常显示:
//*********************主程序**************************
void main(void)
INT8U i,j=0,k=0;;
TRISB=0;
PORTB=0x00;
__delay_ms(50);
Init_MAX7219();
while(1)
for(i=1;i<9;i++)
Write_Max7219_1(i,disp1[j%10][i-1]);
Write_Max7219_2(i,disp1[j/10%10][i-1]);
Write_Max7219_3(i,disp1[j/100%10][i-1]);
Write_Max7219_4(i,disp1[k][i-1]);
j+=1;
if(j>254)
j=0;k+=1;
if(k>9) k=0;
__delay_ms(300);
已退回
10
积分
金伟
2019-10-12 21:16:46
[media]https://v.youku.com/v_show/id_XNDM5NTk0NjAyOA==.html?spm=a2hzp.8244740.0.0[/media]
这是运行时的视频
这是运行时的视频
金伟
2019-10-15 14:13:31
解决了,代码问题。
解决了,代码问题。
2
叫懒呀:
具体哪个地方的问题
叫懒呀:
我有一个51单片机,一样的问题
光影1997
2021-6-25 15:54:42
请问是什么问题
请问是什么问题
PIC单片机
有关
MAX7219
驱动芯片的知识总结
2021-07-23
1737
max7219
工作几秒钟就不正常
2020-04-06
2869
使用STM32CubeMX工程中,SPI操作
MAX7219
结果错误
2019-01-23
4590
如何用
MAX7219
芯片来设计的8X8点阵
模块
2021-09-26
2046
max7219
怎么调节亮度?
2023-10-24
258
求助!单片机连
max7219
驱动数码管
2013-10-11
3458
74hc595和
max7219
驱动的点阵在驱动方式
有
什么不同?
2023-11-09
290
单片机通过
MAX7219
级联
***点阵做滚动效果的问题
2017-02-25
7215
MAX7219
驱动***点阵屏
2020-10-18
3122
16片
MAX7219
(8x8点阵
模块
)制作大屏点阵基模(左移)
2017-11-16
6505
