如题,遇到两个个问题,一是数码管显示不出来,二是max7219发烫
硬件部分,数码管是共阴极,这个脚接在DIG0-7任何一个脚都可以吗?
程序:
#include
#define uchar unsigned char
#define uint unsigned int
//定义Max7219端口
***it Max7219_pinCLK = P0^5;
***it Max7219_pinCS = P0^6;
***it Max7219_pinDIN = P0^7;
void Delay_xms(uint x)
uint i,j;
for(i=0;i
for(j=0;j<112;j++);
//功能:向MAX7219(U3)写入字节
//入口参数:DATA
//出口参数:无
//说明:
void Write_Max7219_byte(uchar DATA)
uchar i;
Max7219_pinCS=0;
for(i=8;i>=1;i--)
Max7219_pinCLK=0;
Max7219_pinDIN=DATA&0x80;
DATA=DATA<<1;
Max7219_pinCLK=1;
//功能:向MAX7219写入数据
//入口参数:address、dat
//出口参数:无
//说明:
void Write_Max7219(uchar address,uchar dat)
Max7219_pinCS=0;
Write_Max7219_byte(address); //写入地址,即数码管编号
Write_Max7219_byte(dat); //写入数据,即数码管显示数字
Max7219_pinCS=1;
void Init_MAX7219(void)
Write_Max7219(0x09, 0xff); //译码方式:BCD码
Write_Max7219(0x0a, 0x0F); //亮度
Write_Max7219(0x0b, 0x07); //扫描界限;4个数码管显示
Write_Max7219(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219(0x0f, 0x01); //显示测试:1;测试结束,正常显示:0
void main(void)
uchar i,j;
Delay_xms(50);
Init_MAX7219();
Delay_xms(2000);
Write_Max7219(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0
ax7219(4,5);
Write_Ma
Write_Max7219(1,8);
Write_Max7219(2,7);
Write_Max7219(3,6);
Write_Mx7219(5,4);
Write_Max7219(6,3);
Write_Max7219(7,2);
Write_Max7219(8,1);
Delay_xms(2000);
for(j=1;j<9;j++)
for(i=0;i<10;i++)
Write_Max7219(j,i);
Delay_xms(100);
while(1);
