STM32/STM8技术论坛
陈玉兰
7年用户 195经验值
用STM32F207的DMA+DAC+TIM6输出正弦波有问题
请高手帮我看看,我想用STM32F207的DMA+DAC+tiM6输出正玄波,现在遇到问题,不知道哪里不对,总是没有预期结果出来。有知道的请加我微信***,谢谢。代码如下:
#define                DAC1_DMA_ADDR                                                        0x40007408     //这个是DMA初始化要用的外设地址。是DAC_DHR12R1的地址
以下数组为余弦函数的数据 ,标题写的正玄波,不严谨,这里关系不大。
uc32 DAC_cosTAB[] = {
  4000        ,3998        ,3990        ,3978        ,3962        ,3940        ,3914        ,3883        ,
  3848        ,3808        ,3764        ,3715        ,3663        ,3606        ,3546        ,3482        ,
        3414        ,3343        ,3269        ,3191        ,3111        ,3028        ,2943        ,2855        ,
        2765        ,2674        ,2581        ,2486        ,2390        ,2293        ,2196        ,2098        ,
        2000        ,1902        ,1804        ,1707        ,1610        ,1514        ,1419        ,1326        ,
        1235        ,1145        ,1057        ,972        ,889        , 809        ,731        ,657        ,
         586        ,518        ,454        ,394        ,337        ,285        , 236        ,192        ,
         152        ,117        , 86        ,  60        , 38        , 22        , 10        ,         2        ,
           0        ,  2        , 10        , 22        , 38        , 60        , 86        ,117        ,
         152        ,192        ,236        ,285        ,337        ,394        ,454        ,518        ,
   586        ,657        ,731        ,809        ,889        ,972        ,1057        ,1145        ,
        1235        ,1326        ,1419        ,1514        ,1610        ,1707        ,1804        ,1902        ,
        2000        ,2098        ,2196        ,2293        ,2390        ,2486        ,2581        ,2674        ,
        2765        ,2855        ,2943        ,3028        ,3111        ,3191        ,3269        ,3343        ,
        3414        ,3482        ,3546        ,3606        ,3663        ,3715        ,3764        ,3808        ,
        3848        ,3883        ,3914        ,3940        ,3962        ,3978        ,3990        ,3998        ,
        4000
说明:管脚时钟,TIM时钟,DMA时钟都已经开了。
引脚配置代码段如下:
GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
DMA的配置如下:
void DAC_DMA_Config(void)
  DMA_InitTypeDef         DMA_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  DMA_DeInit(DMA1_Stream5);
  //DMA_StructInit( &DMA_InitStructure);
  DMA_InitStructure.DMA_Channel = DMA_Channel_7;
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC1_DMA_ADDR;
  DMA_InitStructure.DMA_Memory0BaseAddr = (u32)DAC_cosTAB;
  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  DMA_InitStructure.DMA_BufferSize = 128;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;// DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_FIFOMode=DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold=DMA_FIFOThreshold_1QuarterFull;
  DMA_InitStructure.DMA_MemoryBurst=DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst=DMA_PeripheralBurst_Single;
  DMA_Init(DMA1_Stream5, &DMA_InitStructure);
  DMA_Cmd(DMA1_Stream5, ENABLE);
         //DMA_ITConfig(DMA1_Stream5, DMA_IT_TC|DMA_IT_TE,ENABLE);
DAC的配置如下:
void DAC_Configuration(void)
        DAC_InitTypeDef DAC_InitStructure;
  DAC_DeInit();
        DAC_StructInit(&DAC_InitStructure);
        DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;//²»²úÉú²¨ÐÎ
        DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; //²»Ê¹ÄÜÊä³ö»º´æ
        DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;//DAC´¥·¢Æ÷Ϊ¶¨Ê±Æ÷6´¥·¢
        DAC_Init(DAC_Channel_1, &DAC_InitStructure);      //
        DAC_Cmd(DAC_Channel_1, ENABLE);                   //
        DAC_DMACmd(DAC_Channel_1, ENABLE);                //
TIM6的配置如下:
///////////////////////////    TIM6用作DAC的触发   配置如下    //////////////////////////////////////////////////////////////////////////////
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 50;                                     //
TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
TIM_Cmd(TIM6, ENABLE);
请高手帮我看看,我想用STM32F207的DMA+DAC+TIM6输出正玄波,现在遇到问题,不知道哪里不对,总是没有预期结果出来。有知道的请加我微信***,谢谢。
回帖(16)
陈利妮
2019-1-29 05:44:53
现在出来的波形是什么
何秀珍
2019-1-29 05:53:37
楼主使能了DMA中断,但未见到DMA中断处理函数,程序会跑飞的。
陈玉兰
2019-1-29 06:04:37
我是用的keil建工程的,数组数据没有问题的,我在单独DAC的情况下,可以看到标准的余弦波。这个数组决定的波形的幅值,跟频率没有关系,都是这些数据,我在单DAC的情况下,能输出5K以下的任意频率余弦波型。后面的DMA的问题,我再仔细看看,DMA我不太会用。谢谢,谢谢 ,谢谢
陈玉兰
2019-1-29 06:17:17
引用: jerry181855 发表于 2019-1-29 09:58
现在出来的波形是什么
现在出来的波形是不对的,幅值和波形都不对,就是波浪线,像是三角波 和正玄波的还有很多很多的毛刺。还不受控,就是改变数据,波形也是那个样子。
陈玉兰
2019-1-29 06:36:53
中断函数有的,忘记贴上来了,只是中断函数里没有任何处理。程序应该没有跑飞的。函数如下:
void DMA1_Stream5_IRQHandler(void)
        if( DMA1->HISR & ( DMA_FLAG_TCIF7|DMA_FLAG_HTIF7|DMA_FLAG_TEIF7|DMA_FLAG_DMEIF7|DMA_FLAG_FEIF7 ) )
                DMA1->HIFCR = (uint32_t)((DMA_FLAG_TCIF7|DMA_FLAG_HTIF7|DMA_FLAG_TEIF7|DMA_FLAG_DMEIF7|DMA_FLAG_FEIF7) & 0x0F7D0F7D );
陈玉兰
2019-1-29 06:49:55
DMA我用的是循环模式,还需要重置数组指针吗?
陈玉兰
2019-1-29 06:56:50
有大神来帮帮我吗?
袁富存
2019-1-29 07:09:11
DMA循环只是说DMA循环,不没有指定DMA的数据地址。数据DMA到DAC完了后,需要重置数据指针
陈玉兰
2019-1-29 07:22:57
具体该怎么做呢?我用了你的代码,出来了杂波,不是正玄波,估计是没有重置数组指针,请问这个在什么时候什么地方做这一步动作?谢谢
陈玉兰
2019-1-29 07:37:39
在哪里操作呢?DMA中断里?
袁富存
2019-1-29 07:51:58
引用: wufengju 发表于 2019-1-29 11:51
在哪里操作呢?DMA中断里?
陈玉兰
2019-1-29 07:57:52
你是用什么编译的,用什么建工程的,我的keil里好像没有文件:stm32f7xx_hal.h  ,所以也没办法#include "stm32f7xx_hal.h"的,
陈玉兰
2019-1-29 08:14:21
我用的是STM32F207。
陈玉兰
2019-1-29 08:34:02
问题解决了,其实我的那个程序是可以的,就是一个小地方没有搞对,谢谢你的帮助。我知道问题在哪里了 。谢谢!!!谢谢谢!!!!!!!
陈玉兰
2019-1-29 08:51:09
请问你是在哪里工作?是否可以加微信好友,或者QQ好友?
陈玉兰
2019-1-29 08:56:25
请问你是在哪···‘·‘·‘’’’里工作,是否可以加  微##¥信@!#好···友,或者Q·@为好···友??
