This manual is excerpted from the Denx UBOOT manual as described below. Primarily it has been made
specific to the Lite5200B board and has been reformatted. It is subject to GPL copyright restrictions as
described below and at the URL given below. You have the freedom to distribute copies of this document
in any format or to create a derivative work of it and distribute it provided that you:
• Distribute this document or the derivative work at no charge at all. It is not permitted to sell this
document or the derivative work or to include it into any package or distribution that is not freely
available to everybody.
• Send your derivative work (in the most suitable format such as sgml) to the author.
• License the derivative work with this same license or use GPL.
• Include a copyright notice and at least a pointer to the license used.
• Give due credit to previous authors and major contributors.
This document is derived from the DENX™ U-Boot User Manuals. (Copyright © 2001-2006 by Wolfgang
Denk, DENX Software Engineering.)
The manual can be found at:
