AC220V转DC(12V15W )电源板AD设计硬件原理图+PCB文件,2层板设计,大小为100*55mm, ALTIUM设计的原理图+PCB文件,可以做为你的学习设计参考。
主要器件型号如下:
Library Component Count : 24
Name Description
2N3904 NPN General Purpose Amplifier
2N3906 PNP General Purpose Amplifier
BRIDGE1 Diode Bridge
CON2 Connector
Cap Capacitor
Cap Pol1 Polarized Capacitor (Radial)
D Zener Zener Diode
DIODE
Diode 1N914 High Conductance Fast Diode
EC
ELECTRO2 Electrolytic Capacitor
FP103
FUSE-H
Header 2 Header, 2-Pin
INDUCTOR2
NMOS-2 N-Channel Power MOSFET
PC837 Optoisolator
RES2-B
Res Varistor Varistor (Voltage-Sensitive Resistor)
T
TR-2B
TRANS1
UCC28051
Volt Reg Voltage Regulator
| 文件名 | 大小 |
| SCH.Sch | |
| PCB.PCB |
