秋风宜人
13年用户 834经验值
擅长:基础元器件
stm32串口接收完整的数据包,错过肯定后悔
STM32串口接收完整的数据包,错过肯定后悔
张忠雨
2021-12-8 11:51:07
  借鉴了第四种中断方式
  串口的配置这里不做说明,仅对stm32接收中断中的数据进行解析。
  数据帧协议:
帧头1帧头2数据长度有效数据crc_1crc_2
B5 5B0300570B
  帧头1+帧头2+数据长度(包含有效数据、crc_1、crc_2)+有效数据 + crc_1 + crc_2(校验为帧头到有效数据)
  协议采用小端模式,低字节在前,高字节在后。
  crc16校验未深入学习,代码也不是自己写的,我仅是拿来用,所以未给出,也可以选择其他校验方法。
  crc16函数声明:uint16_t CRC16(uint8_t * buf, uint16_t Len); 返回值为uint16_t校验值
代码如下:
/****************************函数名称: USART2_IRQHandler功    能:串口2接收中断参    数:无返 回 值:无作    者:Yao****************************/uint8_t Uart2_Buffer[256];        //接收缓冲区uint8_t Uart2_Rx = 0;             //Uart2_Buffer下标uint8_t Uart2_head1;              //帧头1uint8_t Uart2_head2;              //帧头2uint8_t Uart2_Len;                //数据长度(第三字节以后包含crc)uint16_t Uart2_temp;              //CRC16()返回值uint8_t Uart2_Sta;                //数据帧正确标志uint8_t Uart2_tx2;                //发送计数uint16_t CRC16(uint8_t * buf, uint16_t Len);  //crc16函数声明,定义未给出。返回uint16_t校验值void USART2_IRQHandler() {   if(USART_GetITStatus(USART2,USART_IT_RXNE) != RESET)     {       USART_ClearITPendingBit(USART2,USART_IT_RXNE);      Uart2_Buffer[Uart2_Rx] = USART_ReceiveData(USART2);       Uart2_Rx++;       Uart2_Rx &= 0xFF;     }  if(Uart2_Buffer[Uart2_Rx-1] == 0xB5)   //判断帧头1    Uart2_head1 = Uart2_Rx-1;   else if((Uart2_Rx-1 == Uart2_head1+1)&&(Uart2_Buffer[Uart2_Rx-1] == 0x5B)) //判断帧头1数据后是否为帧头2    Uart2_head2 = Uart2_Rx-1;  else if(Uart2_Rx-1 == Uart2_head2+1) //得到数据长度    Uart2_Len = Uart2_Buffer [Uart2_Rx-1];   else if(Uart2_Rx-1 == Uart2_head1 + Uart2_Len+2) //确保接收一帧数据    {      Uart2_temp = CRC16(&Uart2_Buffer[Uart2_head1],Uart2_Len+1);  //计算crc      if(((Uart2_temp&0x00ff)==Uart2_Buffer[Uart2_head1+Uart2_Len+1])&&(((Uart2_temp>>8)&0x00ff)==Uart2_Buffer[Uart2_head1+Uart2_Len+2])) //判断crc是否正确      {        Uart2_Sta = 1;  //标志置1      }    }      if(USART_GetFlagStatus(USART2,USART_FLAG_ORE) == SET)     {       USART_ClearFlag(USART2,USART_FLAG_ORE);       USART_ReceiveData(USART2);     }   if(Uart2_Sta) //检测到标志    {       for(Uart2_tx2=0;Uart2_tx2 <= Uart2_Len+2;Uart2_tx2++,Uart2_head1++)      USART2_SendByte(Uart2_Buffer[Uart2_head1]); //从缓冲区中第Uart2_head1字节开始,接收总共Uart2_Len+2个字节            Uart2_Rx = 0; //下标清0      Uart2_Sta = 0; //标志置0    }}
