发生的方式
8年用户 1163经验值
擅长:处理器/DSP
怎样在STM32F407的开发板上测试SRAM程序呢
怎样在STM32F407的开发板上测试SRAM程序呢?求大神解答
庞书娟
2021-10-25 09:55:36
  以下SRAM的程序是在清时代STM32F407开发板上测试通过
  bsp_SRAM.c文件
  #include “sram.h”
  #include “usart.h”
  //本程序只供学习使用,未经作者许可,不得用于其它任何用途
  //STM32F407开发板
  //外部SRAM 驱动代码
  //All rights reserved
  //使用NOR/SRAM的 Bank1.sector3,地址位HADDR[27,26]=10
  //对IS61LV25616/IS62WV25616,地址线范围为A0~A17
  //对IS61LV51216/IS62WV51216,地址线范围为A0~A18
  #define Bank1_SRAM3_ADDR ((u32)(0x68000000))
  //初始化外部SRAM
  void FSMC_SRAM_Init(void)
  FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef readWriteTiming;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOG, ENABLE);//使能PD,PE,PF,PG时钟
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//使能FSMC时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;//PB15 推挽输出,控制背光
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化 //PB15 推挽输出,控制背光
  GPIO_InitStructure.GPIO_Pin = (3《《0)|(3《《4)|(0XFF《《8);//PD0,1,4,5,8~15 AF OUT
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化
  GPIO_InitStructure.GPIO_Pin = (3《《0)|(0X1FF《《7);//PE0,1,7~15,AF OUT
  GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化
  GPIO_InitStructure.GPIO_Pin = (0X3F《《0)|(0XF《《12);//PF0~5,12~15
  GPIO_Init(GPIOF, &GPIO_InitStructure);//初始化
  GPIO_InitStructure.GPIO_Pin =(0X3F《《0)| GPIO_Pin_10;//PG0~5,10
  GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);//PD0,AF12
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);//PD1,AF12
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);//PD15,AF12
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);//PE7,AF12
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);//PE15,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource0,GPIO_AF_FSMC);//PF0,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource1,GPIO_AF_FSMC);//PF1,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource2,GPIO_AF_FSMC);//PF2,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource3,GPIO_AF_FSMC);//PF3,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource4,GPIO_AF_FSMC);//PF4,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource5,GPIO_AF_FSMC);//PF5,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource12,GPIO_AF_FSMC);//PF12,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource13,GPIO_AF_FSMC);//PF13,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource14,GPIO_AF_FSMC);//PF14,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource15,GPIO_AF_FSMC);//PF15,AF12
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource2,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource3,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource10,GPIO_AF_FSMC);
  readWriteTiming.FSMC_AddressSetupTime = 0x02;//地址建立时间(ADDSET)为1个HCLK 1/36M=27ns
  readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到
  readWriteTiming.FSMC_DataSetupTime = 0x08; 数据保持时间(DATAST)为9个HCLK 6*9=54ns
  readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
  readWriteTiming.FSMC_CLKDivision = 0x00;
  readWriteTiming.FSMC_DataLatency = 0x00;
  readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;//模式A
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;// 这里我们使用NE3 ,也就对应BTCR[4],[5]。
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;//存储器写使能
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // 读写使用相同的时序
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //读写同样时序
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //初始化FSMC配置
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE); // 使能BANK1区域3
  bsp_SRAM.h头文件
  #ifndef __SRAM_H
  #define __SRAM_H
  #include “sys.h”
  //STM32开发板
  //外部SRAM 驱动代码
  void FSMC_SRAM_Init(void);
  #endif
  SRAM测试函数
  #define EXT_SRAM_ADDR ((uint32_t)0x68000000)
  #define EXT_SRAM_SIZE (1 * 1024 * 1024)
  * 函 数 名: bsp_TestExtSRAM
  * 功能说明: 扫描测试外部SRAM
  * 形 参: 无
  * 返 回 值: 0 表示测试通过; 大于0表示错误单元的个数。
  uint8_t bsp_TestExtSRAM(void)
  uint32_t i;
  uint32_t *pSRAM;
  uint8_t *pBytes;
  uint32_t err;
  const uint8_t ByteBuf[4] = {0x55, 0xA5, 0x5A, 0xAA};
  /* 写SRAM */
  pSRAM = (uint32_t *)EXT_SRAM_ADDR;
  for (i = 0; i 《 EXT_SRAM_SIZE / 4; i++)
  *pSRAM++ = i;
  /* 读SRAM */
  err = 0;
  if (*pSRAM++ != i)
  err++;
  if (err 》 0)
  return (4 * err);
  #if 0
  /* 对SRAM 的数据求反并写入 */
  *pSRAM = ~*pSRAM;
  pSRAM++;
  /* 再次比较SRAM的数据 */
  err = 0;
  if (*pSRAM++ != (~i))
  err++;
  if (err 》 0)
  return (4 * err);
  #endif
  /* 测试按字节方式访问, 目的是验证 FSMC_NBL0 、 FSMC_NBL1 口线 */
  pBytes = (uint8_t *)EXT_SRAM_ADDR;
  for (i = 0; i 《 sizeof(ByteBuf); i++)
  *pBytes++ = ByteBuf;
  /* 比较SRAM的数据 */
  err = 0;
  if (*pBytes++ != ByteBuf)
  err++;
  if (err 》 0)
  return err;
  return 0;
  多次复位,多次测试后稳定正常测试通过
  在GUI上电应用只要传入地址即可
