赛灵思
王波
7年用户 270经验值
使用远程服务器中的SDK编程elf文件:连接到Board失败
我在远程服务器上进行了设计,我可以使用硬件服务器对FPGA进行编程而没有问题。
但是如果我尝试通过远程服务器中的SDK将elf文件编程到FPGA,它就不起作用了。
它总是给我错误:连接到Board失败
我在我的本地Windows计算机上运行了“hw_server”并且端口已经被打开(所以我可以编写位文件而没有问题)。
但是为什么它不适用于SDK中的elf编程?
还有什么我需要设置的吗?
谢谢。
以上来自于谷歌翻译
以下为原文
I made my design in remote server and I can program FPGA using hardware server without problem. But if I try to program elf file to FPGA thru SDK in remote server, it doesn't work. It always gave me error : Connection to Board Failed
I have run "hw_server" in my local windows computer and the port has been opened sucesfully (so I can program bit file without problem). But why it doesn't work for programming elf in SDK?
Is there anything else I need to setup?
Thank you.
回帖(2)
张丽丽
2019-4-1 13:46:58
在远程主机上尝试不同的端口:http://127.0.0.1:59170 / help / index.jsp?topic =%2Fcom.xilinx.sdk.docs.user%2FSDK_tasks%2Ftask_settinguptheremotesystemenvironment.html& cp = 1_2_11_4_5_0& anchor = settinguptheremotesystemenvironmentConnect
使用以下步骤进行托管:http://127.0.0.1:59170 / help / index.jsp?topic =%2Fcom.xilinx.sdk.docs.user%2FSDK_tasks%2Ftask_settingupthelocalsystemforremotedebug.html& resultof =%22%73%79%
图6d%62%1207%6C%22%20%22%73%65%72%76%65%72%22%20
以上来自于谷歌翻译
以下为原文
Try a different port on remote host:
http://127.0.0.1:59170/help/index.jsp?topic=%2Fcom.xilinx.sdk.docs.user%2FSDK_tasks%2Ftask_settinguptheremotesystemenvironment.html&cp=1_2_11_4_5_0&anchor=settinguptheremotesystemenvironment
Connect to host using these steps:
http://127.0.0.1:59170/help/index.jsp?topic=%2Fcom.xilinx.sdk.docs.user%2FSDK_tasks%2Ftask_settingupthelocalsystemforremotedebug.html&resultof=%22%73%79%6d%62%6f%6c%22%20%22%73%65%72%76%65%72%22%20
李凤英
2019-4-1 13:57:22
谢谢你们俩。
我遵循Ashish发布的AR,它适用于我的情况。
以上来自于谷歌翻译
以下为原文
Thank you, both of you. I follow the AR that Ashish posted and it works in my case.
