是德科技
刘波
7年用户 916经验值
Command Expert无法连接到服务器
我已经安装了Command Expert 1.3,它无法连接到服务器,所以我无法下载命令集。
第一个问题是我们使用代理服务器而Command Expert无法上网。
这似乎是通过使用我在这些论坛上找到的CommandExpert.exe.config文件来修复的:现在CommandExpert尝试连接大约30秒,然后失败并出现以下两个错误之一:+无法从Command Expert Server检索可用的命令集
:操作超时+ +服务器地址:http://commandexpert-244967006.us-east-1.elb.amazonaws.com/mojo/+ +操作超时+ +无法从命令专家检索可用的命令集
服务器:无法连接到远程服务器+ +服务器地址:http://commandexpert.product.agilent.com/mojo/+ +无法连接到远程服务器+ +无法建立连接,因为目标计算机主动拒绝它107.22
.210.67:80+任何人都可以帮忙解决这个问题吗?
以上来自于谷歌翻译
     以下为原文
  I have installed Command Expert 1.3, and it cannot connect to the server so I cannot download command sets.
The first problem was that we use a proxy server and Command Expert could not get onto the internet. That appears to be fixed by using a CommandExpert.exe.config file I found on these forums:
Now CommandExpert tries to connect for about 30 seconds, then fails with one of two errors:
+Unable to retrieve available command sets from the Command Expert Server: The operation has timed out+
+Server address: http://commandexpert-244967006.us-east-1.elb.amazonaws.com/mojo/+
+The operation has timed out+
+Unable to retrieve available command sets from the Command Expert Server: Unable to connect to the remote server+
+Server address: http://commandexpert.product.agilent.com/mojo/+
+Unable to connect to the remote server+
+No connection could be made because the target machine actively refused it 107.22.210.67:80+
Can anyone help with this problem?
刘波
2018-11-26 09:18:46
我正在回答我自己的问题,以防其他人遇到类似的问题。
Command Expert不喜欢使用代理。
这里没有人,包括IT部门,可以让它发挥作用。
解决方案:使用不涉及代理的网络连接,下载所需的所有命令集,然后在本地工作。
以上来自于谷歌翻译
     以下为原文
  I am answering my own question in case someone else has similar problems.
Command Expert does not like working with a proxy. No-one here, including the IT department, could get it to work.
Solution: Use a network connection that does not involve a proxy, download all command sets you need, and then work locally.
