ST意法半导体
余英姿
7年用户 216经验值
ST电机控制工作台欠压故障
我正在使用带有STEVAL-IFN003V1的ST电机控制工作台,并且我的总线电压读数高于阈值,但即使我在设置中禁用低电压检查,欠压故障指示灯也会持续亮起。问题是什么?此外,是否有任何文档可用于解释这些故障究竟意味着什么以及如何使用该应用程序?
谢谢
#STEVAL-ifn003v1
以上来自于谷歌翻译
以下为原文
I'm using the ST Motor Control Workbench with STEVAL-IFN003V1 and my bus voltage is reading above the threshold but the Under Voltage fault light is constantly on even if I disable the low voltage checking in the settings. What could the issue be? Also, is there any documentation available to explain what these faults mean exactly and how to use the application?
Thanks
#steval-ifn003v1
