ST意法半导体
王华梅
7年用户 152经验值
如何安装stm32电机控制工作台
你好,
我最近买了两个BLDC电机控制器,STEVAL-SPIN3202和用于NUCLEO-F401RE的X-NUCLEO-IHM08M1屏蔽。
我有一个控制BLDC感应电机的项目。我不确定如何前进。我安装了AC6,IAR和MKD。我已经尝试安装电机控制工作台,没有运气。可以从以下链接下载的X-CUBE-MCSDK可执行文件由于某种原因不起作用。
http://www.st.com/en/embedded-software/stsw-stm32100.html
我想知道是否还有其他东西需要安装才能使用?
FIY,我使用的是Windows10,我安装了STM32CubeMX。
以上来自于谷歌翻译
以下为原文
Hello,
I recently bought two BLDC motor controllers, the STEVAL-SPIN3202 and the X-NUCLEO-IHM08M1 shield forNUCLEO-F401RE.
I have a project to control a BLDC sensored motor. I am not sure how to move forward. I have AC6, IAR and MKD installed. I have tried installed motor control workbench with no luck. X-CUBE-MCSDK executable that can be downloaded from the following link does not work for some reason.
I am wondering if there is something else I need to install for this to work?
FIY, I am using Windows10 and I have STM32CubeMX installed.
回帖(9)
陈磊
2018-10-19 11:36:32
似乎X-CUBE-MCSDK包实际上是一个zip文件而不是exe文件。
如果Windows抱怨“此文件的版本与您正在运行的Windows版本不兼容”请尝试首先解压缩该文件。它应该在未来几个小时内修复......
以上来自于谷歌翻译
以下为原文
It seems that the X-CUBE-MCSDK package is actually a zip file and not an exe.
If Windows complains that 'The version of this file is not compatible with the version of windows you're running' Try to unzip the file first. It should be fixed in the coming hours...
王华梅
2018-10-19 11:42:36
感谢您的帮助。
你是对的。我将文件域更改为zip,当我解压缩时,另一个可执行文件出现了。我能够运行它,似乎问题也在服务器端修复。
以上来自于谷歌翻译
以下为原文
Thank you for your help.
You are correct. I changed the file domain to zip, and when I unzipped it, another executable showed up. I was able to run that, and it seems the problem is fixed on the server side as well.
冯虎虔
2018-10-19 11:49:00
嗨阿卜杜勒,
您是否成功安装并生成电机控制代码?
以上来自于谷歌翻译
以下为原文
hi Abdul,
Have you succeed in installing and generating the code for motor control ?
王华梅
2018-10-19 11:56:01
是的,我设法安装它,但我还没有尝试过。
以上来自于谷歌翻译
以下为原文
Yes, I managed to install it, but I haven't tried it out yet.
