HelloTF14感谢您加入英特尔®社区。
您是否尝试清除浏览器的Cookie?
您是否尝试过全新安装英特尔®DSA?
请参阅以下信息。
如果您遇到无线问题,可以使用无线驱动程序进行全新安装(https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-io/wireless-
networking.html)干净安装Intel®Driver&的步骤
支持助手:使用位于此处的DSA卸载程序卸载当前版本:英特尔®驱动程序&
Support Assistant卸载程序版本:1.0.0.2(最新)https://downloadcenter.intel.com/download/28149/Intel-Driver-Support-Assistant-Uninstaller一旦卸载了以前的版本;
安装最新版本的英特尔®驱动程序&
支持助手:https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant?product = 128824请记住,英特尔提供的驱动程序是您系统的通用驱动程序,我们建议测试/
使用原始设备制造商(OEM)提供的驱动程序,因为这些是为您的系统定制的。希望这会有所帮助。
此致Leonardo C.Intel客户支持技术人员与英特尔公司签订合同
以上来自于谷歌翻译
以下为原文
Hello TF14
Thank you for joining the Intel® community.
Steps for a clean install of Intel®
Driver & Support Assistant:
Uninstall the current versions using the DSA uninstaller located here:
Intel® Driver & Support Assistant Uninstaller Version: 1.0.0.2 (Latest)
Once you have uninstalled the previous version; install the latest version of Intel® Driver & Support Assistant:
https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant?product=128824
Bear in mind that the drivers provided by Intel are the generic drivers for your system, we recommend to test/use the driver provided the Original Equipment Manufacturer (OEM) due to those are customized for your system.
Hope this helps.
Regards,
Leonardo C.
Intel Customer Support Technician
Under Contract to Intel Corporation
您是否尝试清除浏览器的Cookie?
您是否尝试过全新安装英特尔®DSA?
请参阅以下信息。
安装最新版本的英特尔®驱动程序&
以上来自于谷歌翻译
以下为原文
Hello TF14
Hope this helps.
Regards,
Leonardo C.
