ST意法半导体
李伟
7年用户 1500经验值
LSM303AGR如何通过软件关闭加速度计
我尝试通过SPI命令关闭加速度计,根据规格仅使用1uA。我没有发现任何SPI命令关闭它以将功耗降低到大约1uA,我尝试的所有东西仍然需要大约150uA。
#lsm303agr
以上来自于谷歌翻译
以下为原文
I try to turn off the accelerometer by SPI commands to use only 1uA according to the spec. I have not found any SPI commands to turn it off to reduce power consumtion to about 1uA, everything I tried  still needs about 150uA.
#lsm303agr
回帖(3)
曾玲娟
2018-9-19 17:10:55
为了最小化功耗,加速度计和磁力计必须在寄存器CTRL_REG1_A(20h)中设置为掉电模式ODR [3:0] = 0,并且在寄存器CFG_REG_A_M(60h)中将MD [1:0] = 2设置为0。
最好的祝福
米罗斯拉夫
以上来自于谷歌翻译
以下为原文
To minimize the power consumption accelerometer and magnetometer have to be set to power down mode ODR[3:0] = 0 in register CTRL_REG1_A (20h) and MD[1:0] = 2 in register CFG_REG_A_M (60h).
Best regards
Miroslav
李伟
2018-9-19 17:18:13
我将CTRL_REG1_A输出为0,它仍然需要大约70uA。我无法将其关闭到指定的1uA
数据表
。当我将其转换为10Hz低功率时,它需要大约5uA。看起来没有实现关闭电源。
以上来自于谷歌翻译
以下为原文
I output CTRL_REG1_A to 0 and it still needs about 70uA. I cannot get this turned off to the 1uA specified in the
data sheet
. When I turn it into 10Hz low power it needs about 5uA as specified. It looks like powering off is not implemented.
曾玲娟
2018-9-19 17:35:31
断电(掉电模式)已实现。
在附件中,您可以找到参考传感器设置,加速度计处于断电模式,磁力计处于空闲模式。
在此配置中,电流消耗为2uA@2.5V,符合规范(参见LSM303AGR数据表第15页,行IDd_PD)。
最好的祝福
米罗斯拉夫
以上来自于谷歌翻译
以下为原文
Power off (power-down mode) is implemented.
In attachment you can find reference sensor setup, accelerometer is in power down mode, magnetometer is in idle mode.
In this configuration the current consumption is 2uA@2.5V which is in line with specification (see page 15 of LSM303AGR datasheet, line Idd_PD).
Best regards
Miroslav
