Applications
For GPS application
Suitable for Automotive applicationsCompliant to the AEC-Q200 reliability standard
General Description Pin Configuration
The 856561 is a high-performance SAW filter designed for GPS applications. It is suitable for Automotive applications too.
Dimensions shown are nominal in millimeters All tolerances are 0.10mm
Body: Al2O3 ceramic Lid: Kovar or Alloy 42, Au over Ni plated Terminations: Au plating 0.5 - 1.0 m, over a 2 - 6 m Ni plating
