This equipment generates, uses, and can radiate radio frequency energy and has not been tested for
compliance with the limits of computing devices pursuant to subpart J of part 15 of FCC rules, which adesigned to provide reasonable protection against radio frequency interference. Operation of thisequipment in other environments may cause interference with radio communications, in which case theuser at his own expense will be required to take whatever measures may be required to correct thisinterferenc
