The X-Y Footprint is located here:
The RF-SOM 3D model is located here:
The Heat spreader plate 3D model is located here:
Note: Thermal material being used is Panasonic EYG-T7070A10A. The Power Control sequencer shuts down when the PCB reaches 90C.
The FMC connector pinouts are located here:
The System Clocking Tree Diagram is located here:
The System Power Map Diagram is located here:
Power sequence:
Rev C is the latest and is in mass production.
