uchar codeshu7[]={0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00};/*"7"*/
uchar code shu8[]={0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00};/*"8"*/
uchar codeshu9[]={0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00};/*"9"*/
uchar code you[]={
0x00,0x20,0x44,0x08,0x20,0xE0,0x92,0x94,0x10,0x28,0xAE,0x68,0x24,0x04,0x00,0x00,
0x00,0x0C,0x03,0x04,0x02,0x19,0x0C,0x03,0x02,0x12,0x22,0x1F,0x01,0x01,0x01,0x00};/*"游"*/
uchar code xi[]={
0x00,0x20,0xA0,0x90,0x10,0xF0,0x00,0x40,0x7F,0xC0,0x20,0x24,0x88,0x00,0x00,0x00,
0x10,0x08,0x04,0x02,0x01,0x02,0x14,0x10,0x08,0x05,0x06,0x09,0x10,0x20,0x38,0x00};/*"戏"*/
uchar code jie[]={
0x00,0x60,0x50,0xCC,0x40,0x30,0x40,0x40,0x40,0xFE,0x20,0x20,0x20,0x20,0x00,0x00,
0x00,0x12,0x13,0x0A,0x09,0x05,0x00,0x3A,0x2A,0x25,0x25,0x15,0x1D,0x00,0x00,0x00};/*"结"*/
uchar code shu[]={
0x00,0x00,0x00,0x60,0xA8,0xA8,0xA8,0xFF,0x94,0x54,0x70,0x00,0x00,0x00,0x00,0x00,
0x10,0x10,0x08,0x08,0x04,0x02,0x01,0x7F,0x02,0x04,0x08,0x08,0x10,0x10,0x10,0x00};/*"束"*/
uchar code tan[]=
0x20,0x20,0x10,0x90,0xA8,0xA4,0xAA,0xB1,0xA2,0xE4,0xA8,0x88,0x10,0x30,0x10,0x00,
0x00,0x00,0x80,0x9F,0x40,0x20,0x10,0x0E,0x10,0x20,0x60,0xDF,0x00,0x00,0x00,0x00,/*"贪"*/
uchar code chi[]=
0x00,0xFC,0x04,0x04,0xFC,0x20,0x58,0x4F,0x4A,0x48,0x48,0xC8,0x08,0x08,0x08,0x00,
0x00,0x0F,0x02,0x02,0x07,0x00,0x30,0x48,0x44,0x42,0x41,0x40,0x40,0x40,0x70,0x00/*"吃",1*/
uchar code she[]=
0x00,0xF0,0x10,0xFF,0x10,0xF0,0x20,0x18,0xE8,0x09,0x0E,0x0A,0xA8,0x18,0x08,0x00,
0x20,0x23,0x21,0x1F,0x11,0x3B,0x10,0x00,0x3F,0x42,0x41,0x41,0x40,0x38,0x00,0x00/*"蛇",2*/
uchar code wei[]={
/*-- 文字: 为 --*/
/*-- 楷体12; 此字体下对应的点阵为:宽x高=16x16 --*/
0x00,0x00,0x80,0x80,0x98,0xD8,0xD8,0xFE,0x7E,0x4C,0x60,0xE0,0xE0,0xC0,0x00,0x00,
0x00,0x20,0x30,0x38,0x1C,0x0F,0x07,0x03,0x26,0x66,0x76,0x7F,0x1F,0x01,0x00,0x00
uchar code qin[]={
/*-- 文字: 青 --*/
0x00,0x80,0x80,0x80,0xA8,0xA8,0xAA,0xFE,0x7E,0x78,0x78,0x48,0x40,0x40,0x40,0x00,
0x00,0x00,0x00,0x00,0x70,0x7F,0x1F,0x2D,0x6D,0x7F,0x7F,0x39,0x00,0x00,0x00,0x00};
uchar code chun[]={
/*-- 文字: 春 --*/
0x00,0x00,0x80,0x80,0xA8,0xA8,0xFE,0xFE,0xEE,0xFC,0x7C,0x4C,0x40,0x00,0x00,0x00,
0x10,0x10,0x18,0x0C,0x06,0x7F,0x7F,0x6E,0x2B,0x7F,0x7F,0x06,0x0E,0x0C,0x08,0x00
uchar code bu[]={
/*-- 文字: 不 --*/
0x00,0x00,0x10,0x10,0x10,0x18,0xE8,0xE8,0xF8,0x38,0x08,0x08,0x08,0x08,0x08,0x00,
0x00,0x10,0x18,0x0C,0x0E,0x07,0x33,0x7F,0x7F,0x01,0x03,0x03,0x06,0x0E,0x0C,0x00};
uchar code xiu[]={
/*-- 文字: 朽 --*/
0x00,0x00,0x40,0xC0,0xFE,0xFE,0x20,0x20,0x20,0xE0,0xE0,0x30,0x10,0x10,0x10,0x00,
0x18,0x1C,0x0E,0x07,0x7F,0x7F,0x03,0x02,0x21,0x61,0x61,0x7F,0x3F,0x0F,0x00,0x00};
uchar code er[]={
/*-- 文字: 而 --*/
0x00,0x00,0x00,0x10,0x10,0xD0,0xF0,0x70,0x18,0x08,0x08,0x88,0x88,0x00,0x00,0x00,
0x00,0x00,0x1F,0x1F,0x01,0x0F,0x0F,0x01,0x1F,0x1F,0x11,0x31,0x3F,0x3F,0x01,0x00};
uchar code fen[]={
/*-- 文字: 奋 --*/
0x00,0x00,0x10,0x90,0xD0,0xF0,0x7E,0x1E,0x32,0x78,0xD8,0x98,0x00,0x00,0x00,0x00,
0x0C,0x0E,0x06,0x3F,0x7F,0x7E,0x3E,0x3E,0x3F,0x7B,0x7F,0x3F,0x03,0x03,0x02,0x00};
uchar code dou[]={
/*-- 文字: 斗 --*/
0x00,0x00,0x00,0x00,0x40,0x48,0x58,0x5A,0xFE,0xFE,0x04,0x00,0x80,0x80,0x00,0x00,
0x00,0x02,0x02,0x02,0x02,0x02,0x03,0x01,0xFF,0xFF,0x01,0x01,0x01,0x01,0x01,0x00};
/******************************************开机画面代码*****************************************/
uchar code picture0[][64]=
/*-- 调入了一幅图像:C:UsersAdministratorDesktop贪吃蛇2.bmp --*/
/*-- 宽度x高度=128x64 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x80,0x80,0xA0,0xC0,0x30,0x90,0x90,
0xCC,0xC0,0x8C,0x10,0x10,0x10,0xE0,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0xC0,0xE0,0xF0,0xF0,0x3C,0x1C,0x1F,0x0F,0x0F,0x0F,0x1B,0x00,0x03,0x03,
0xC7,0xDF,0x07,0x30,0x30,0x18,0x07,0x07,0x07,0x1F,0x3F,0x3F,0x3F,0x3F,0xFC,0xF0,
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF8,0x3E,
0x07,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x0C,0x00,0x00,0xFF,0xFF,
0xC0,0x70,0x70,0x3C,0x46,0x43,0x79,0x79,0xF9,0x46,0x0C,0x0C,0x38,0x78,0xF0,0x40,
0x40,0x00,0xC0,0x00,0x00,0x00,0xC0,0x00,0xC0,0x70,0x70,0x3E,0x30,0x30,0x30,0x00,
0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0xFC,0xFC,0x04,0x00,0x00,0xC0,0xC0,0xF0,0x32,
0x36,0x36,0xB0,0x38,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,
0xF0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xFF,0xFF,0x07,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x3F,0x3F,0xDE,0x7E,0x7E,0x0F,0x01,
0x00,0x00,0x00,0xB6,0xE6,0x37,0x3F,0x3F,0xC7,0xFF,0x06,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x0F,0x0E,0x86,0x86,0x87,0x80,0xC6,0xFE,0xFE,0x87,0x81,0xC0,0xC0,0x60,
0x38,0x00,0x00,0x00,0x80,0xA7,0xE0,0xFF,0xFF,0x61,0x71,0xF0,0x80,0x80,0x01,0x7E,
0xCE,0xCE,0xC7,0x41,0x60,0x38,0x38,0x20,0x00,0x00,0x00,0x00,0xE0,0x7E,0x07,0xFF,
0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0x80,0x00,0x00,
0x00,0x00,0x80,0x80,0x80,0xEC,0xFC,0xF8,0xF8,0xFE,0x7E,0x7B,0x98,0x98,0xEC,0x0C,
0x1C,0x7E,0x7E,0x1F,0x1D,0x0C,0x08,0x08,0xF9,0xF3,0x72,0x72,0x78,0x98,0xEC,0xE4,
0xE4,0xE6,0x86,0xF6,0x67,0x67,0x0F,0x07,0x03,0x07,0x07,0x0F,0x19,0xF1,0xF1,0x10,
0x0C,0x7E,0x7E,0x7E,0xFF,0xFF,0xFF,0xFF,0xFF,0x7E,0x7C,0x01,0x03,0x03,0x06,0x1C,
0xF9,0xF9,0x01,0x00,0x00,0x80,0x80,0xE0,0xF0,0xFC,0x8E,0x8E,0x01,0x00,0x00,0xFF,
0x00,0x00,0x00,0x00,0x00,0x44,0x3C,0x3C,0x3C,0x3C,0x18,0x04,0x04,0x03,0x03,0x06,
0x04,0x04,0x04,0x1C,0x9C,0x9C,0xFE,0x3C,0x06,0xC0,0xC0,0xC0,0xC0,0x3C,0x3E,0x3E,
0x19,0x01,0x81,0x20,0x20,0x18,0x01,0x40,0x40,0xE6,0x1F,0x1F,0x1F,0x1F,0x07,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x03,0x81,0xD8,0xD8,0xC4,0xDC,0xC7,0xC7,
0xC7,0x07,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x1F,0x1F,0x00,
0x60,0xF8,0xFA,0xFA,0xFA,0xE6,0xE0,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xBB,0xBB,0x7F,0x1E,0x9F,0xC7,0xC7,0xF9,0xC1,0x87,0x07,0x07,0x00,0x00,0xF8,0xFF,
0xFF,0x27,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x30,0xFF,0xFF,0x00,0x00,0x07,0x0F,0x0F,0x0F,0x07,0x00,0x00,0x00,
0x00,0x00,0xF9,0xF8,0xF8,0xF8,0xFE,0xFE,0xFE,0x38,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0xE0,0x00,0x00,0x00,0xE1,0xE7,0xE7,0xE7,0xE7,0x07,0x07,0x01,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x20,0x00,0xC6,0xC0,0xC0,0xC0,
0xC8,0xDE,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xE0,0x18,
0x00,0x00,0x00,0x08,0x1F,0x3F,0x3F,0x3F,0x1F,0x0F,0xC0,0xC0,0xE0,0x3E,0x0F,0x00,
0x00,0x00,0x00,0x00,0x03,0x03,0x0E,0x0C,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,
0x0C,0x04,0x0F,0x0C,0x0C,0x3D,0x38,0x30,0x30,0x30,0x38,0x70,0x38,0x38,0x08,0x0C,
0x04,0x06,0x06,0x03,0x0F,0x38,0x30,0x30,0x71,0xF1,0xC1,0xC1,0xF1,0x70,0x70,0x30,
0x30,0x38,0x08,0x0C,0x06,0x06,0x07,0x03,0x03,0x0E,0x0E,0x3F,0x7F,0x7F,0x7F,0x3F,
0x77,0x37,0x72,0x72,0x30,0x38,0x38,0x3C,0x3C,0x0C,0x06,0x07,0x0D,0x0D,0x0C,0x0C,
0x0C,0x0C,0x0C,0x06,0x0E,0x06,0x06,0x06,0x03,0x03,0x01,0x01,0x01,0x00,0x00,0x00,
uchar code picture1[][64]={
/*-- 调入了一幅图像:C:UsersAdministratorDesktop学校校徽1.bmp --*/
0x80,0xC0,0xF0,0x70,0x78,0x08,0x0C,0xF6,0xF2,0xF8,0xF8,0x04,0x02,0x06,0x0C,0x08,
0x38,0x70,0xF0,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x70,0x1C,0x1E,0x0E,0x07,
0x83,0x01,0x81,0x80,0x00,0x80,0x80,0x00,0x91,0x8F,0x0F,0x9F,0x8E,0x00,0x00,0x80,
0x00,0x00,0x80,0x01,0x01,0x83,0x07,0x0E,0x1C,0x70,0xE0,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x10,0xE0,0x80,0x80,0x00,0x10,
0x1D,0x07,0x1F,0x1D,0x00,0x00,0x03,0x9E,0x1F,0x01,0x00,0x1F,0x9F,0x87,0x1E,0x1F,
0x18,0x00,0x1F,0x18,0x18,0x1F,0x04,0x80,0x80,0xE0,0x70,0x09,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x06,
0x1C,0x38,0x38,0xF0,0xE0,0xC0,0x07,0x0F,0x1E,0x34,0xF0,0x3E,0x3F,0x37,0x1F,0xC0,
0xE0,0xF0,0xF8,0xF8,0x3C,0x1E,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x03,0x06,0x04,0x03,0x05,0x06,0x02,0x03,0x01,
0x00,0x00,0x00,0xE0,0xF8,0x78,0x30,0x00,0x20,0x20,0x20,0x21,0x39,0x3E,0x1E,0x10,
0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0xC0,0x00,0x00,0x00,0x00,0x08,0x78,
0xB0,0x50,0xD8,0x31,0x1F,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xFC,
0x1E,0x6C,0xE8,0x40,0x00,0x00,0x10,0x18,0x98,0xF8,0x78,0x38,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x40,0x4E,0xFC,0xF8,0x68,0x24,0x04,0x02,0x0E,0x8E,0x86,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x80,0xFE,0xC0,0x02,0x1C,
0x58,0x58,0x6C,0xFE,0xD2,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xF8,
0x30,0x00,0x00,0xF0,0x70,0x20,0x30,0x3E,0x7E,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x06,0x1E,0xFD,0xF1,0xE0,0xC0,0x00,0x00,0x00,0xE0,0xA0,0xB0,0x92,0xD2,0x90,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,0x0F,0x0E,0x04,0xC0,0xC0,0xC0,0xE0,
0x61,0x34,0xBF,0x3C,0x24,0x20,0x00,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0xFD,0xFF,
0x10,0xF0,0xF3,0xC2,0x00,0x00,0x08,0x1C,0xDD,0xFF,0xE4,0x44,0x6C,0x28,0x00,0x00,
0x00,0x00,0x00,0x00,0x30,0x7C,0x60,0xFD,0xFF,0xCA,0x4C,0x00,0xC0,0xC2,0x0F,0x0F,
0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x05,0x06,0x00,0x00,0x41,0xC1,0xC1,0xC0,0xF8,
0xF8,0xDC,0xC0,0x03,0x03,0x02,0x00,0x00,0x00,0x00,0x00,0xE0,0xFC,0x18,0x08,0x0F,
0x02,0x00,0x00,0xB1,0xB6,0xF6,0x72,0x22,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x38,0x7F,0x3F,0x0F,0x00,0x00,0x00,0x00,0x07,0x0F,0x07,0x00,0x00,0x07,
0x0E,0x0E,0x00,0x00,0x00,0x00,0x00,0x3F,0x1F,0x00,0x00,0x00,0x00,0x00,0x01,0x07,
0x00,0x10,0x07,0x00,0x00,0x06,0x06,0x07,0x06,0x00,0x00,0x00,0x00,0x00,0x07,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0x0E,0x06,0x07,0x0F,0x0F,0x00,0x00,0x00,0x0F,0x0E,0x0E,0x0E,
0x0E,0x0E,0x0F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x10,0x18,0x18,
0x1F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x0F,0x00,0x00,0x00,
0x00,0x00,0x07,0x07,0x07,0x07,0x1E,0x18,0x18,0x18,0x18,0x17,0x01,0x00,0x00,0x00
uchar code picture2[][64]={
/*-- 调入了一幅图像:C:UsersAdministratorDesktop设计者.bmp --*/
0x00,0x08,0x08,0x08,0xC8,0x28,0xFE,0x28,0xC8,0x08,0x08,0x08,0x00,0x44,0x88,0x08,
0xFA,0x4C,0xC8,0x10,0x2E,0xA8,0x68,0x08,0x00,0x28,0xC8,0x08,0xC8,0x38,0x20,0x20,
0xFE,0x10,0xD2,0x14,0x00,0x00,0xF8,0x88,0x88,0x88,0xFE,0x88,0x88,0x88,0xF8,0x00,
0x00,0x04,0x02,0x05,0x04,0x04,0x1F,0x04,0x04,0x05,0x02,0x04,0x00,0x08,0x04,0x10,
0x0F,0x10,0x1F,0x01,0x11,0x1F,0x01,0x01,0x00,0x10,0x0C,0x03,0x0C,0x00,0x10,0x08,
0x05,0x06,0x09,0x1C,0x00,0x00,0x1F,0x08,0x08,0x08,0x0F,0x08,0x08,0x08,0x1F,0x00,
0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x40,
0x80,0x00,0x00,0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0xC0,0x00,0x00,
0x00,0xC0,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x40,
0xC0,0x40,0x40,0x40,0xC0,0x40,0x40,0x40,0x00,0x00,0x00,0x00,0xC0,0x00,0x80,0x40,
0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0xC0,0x80,0x80,0x80,
0x80,0x80,0x00,0x00,0x00,0xC0,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xF9,0x89,0x8F,0x89,0xF9,0x00,0xFF,0x24,0x24,0x24,0xFF,0x00,0x04,
0x88,0x12,0xF1,0x9E,0x92,0xDA,0x92,0x92,0xFE,0x90,0x00,0x22,0x1A,0xFF,0x12,0x08,
0x86,0x61,0x18,0x41,0x86,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x75,0x15,
0x17,0x95,0x75,0x95,0x97,0x15,0x75,0x07,0x00,0x08,0x04,0xFF,0x00,0x49,0x25,0x59,
0x91,0x51,0x35,0x0B,0x00,0x21,0x21,0x11,0x09,0x05,0x7F,0x05,0x09,0x11,0x21,0x21,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x44,0x4A,0x49,0x48,0xEF,0x58,0x49,0x42,
0x44,0x44,0x00,0x22,0x1A,0xFF,0x12,0x00,0x0F,0xB0,0x40,0xB0,0x0F,0x00,0x00,0x00,
0xFF,0x55,0xBD,0x95,0x75,0x01,0x3F,0xC1,0x31,0xCD,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x02,0x01,0x00,0x00,0x02,0x02,0x03,0x00,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x03,0x00,0x00,
0x01,0x01,0x01,0x01,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x01,
0x01,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x00,0x00,0x00,0x03,0x00,0x02,0x02,0x01,
0x00,0x01,0x02,0x02,0x00,0x02,0x01,0x00,0x01,0x02,0x00,0x01,0x02,0x00,0x01,0x02,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x03,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x02,0x01,0x00,0x00,0x00,0x01,0x02,0x00,0x02,
0x01,0x01,0x00,0x00,0x01,0x02,0x01,0x00,0x01,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x40,0x20,0x10,0x08,0x10,
0x20,0x40,0x80,0x80,0x00,0x00,0x80,0xE0,0x18,0x40,0x38,0xE0,0x20,0x20,0x20,0x20,
0x00,0x30,0x10,0x90,0x90,0x90,0x98,0x90,0x90,0x90,0x10,0x30,0x00,0x00,0xE0,0x20,
0x20,0x20,0x20,0xF8,0x20,0x28,0x30,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x80,0xF8,0x80,0xF0,0x90,0x90,0x90,0x88,0x88,
0x00,0x40,0x40,0xF8,0x40,0x10,0xF0,0x10,0x10,0x10,0xF0,0x00,0x00,0x00,0xF0,0x90,
0x90,0x88,0x00,0xF0,0x90,0x90,0x88,0x88,0x00,0x20,0x20,0xA0,0xE0,0xB8,0xA0,0xA0,
0xA0,0xA0,0xA0,0x20,0x00,0x00,0x00,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x25,0x25,0x25,0x25,0x25,
0x25,0x25,0x7C,0x00,0x00,0x01,0x00,0x7F,0x00,0x00,0x00,0x7F,0x09,0x09,0x09,0x08,
0x00,0x44,0x44,0x24,0x1C,0x04,0x04,0x04,0x3C,0x44,0x44,0x64,0x00,0x40,0x3F,0x01,
0x11,0x5F,0x20,0x17,0x08,0x14,0x23,0x78,0x00,0x00,0x00,0x16,0x0E,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x40,0x3F,0x04,0x7C,0x20,0x1F,0x40,0x2F,0x10,0x2C,0x43,
0x00,0x04,0x03,0x7F,0x02,0x40,0x21,0x16,0x08,0x16,0x21,0x40,0x00,0x40,0x3F,0x04,
0x04,0x4F,0x20,0x1F,0x00,0x00,0x7F,0x00,0x00,0x02,0x01,0x7F,0x0A,0x0A,0x0A,0x0A,
0x0A,0x4A,0x7F,0x00,0x00,0x00,0x00,0x19,0x19,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar code you[]={
uchar code xi[]={
uchar code jie[]={
uchar code shu[]={
uchar code tan[]=
uchar code chi[]=
uchar code she[]=
uchar code wei[]={
/*-- 文字: 为 --*/
uchar code qin[]={
/*-- 文字: 青 --*/
uchar code chun[]={
/*-- 文字: 春 --*/
uchar code bu[]={
/*-- 文字: 不 --*/
uchar code xiu[]={
/*-- 文字: 朽 --*/
uchar code er[]={
/*-- 文字: 而 --*/
uchar code fen[]={
/*-- 文字: 奋 --*/
uchar code dou[]={
/*-- 文字: 斗 --*/
1
