电路设计论坛
王超
7年用户 1272经验值
ad7172-2如何利用RDY引脚触发SPI中断进行数据接收?
您好!
           1.如何利用RDY引脚触发SPI中断进行数据接收?
           2.另外我现在需要采集多路模拟信号,但是在进行通道切换的时候无法正常读取数据,我通过置位接口模式寄存器配置中的AD717X_IFMODE_REG_DATA_STAT位,数据输出为32位,[24..31]位为状态寄存器的值,以此来判断我每次读取的是哪个通道的。寄存器初始化配置如下:
ad717x_st_reg ad7172_2_regs[] =
{AD717X_STATUS_REG,0x00,1},
{AD717X_DCDMODE_REG, 0x0000, 2},
ad717x_ifmode_reg,
AD717X_IFMODE_REG_DOUT_RESET | AD717X_IFMODE_REG_CRC_EN |             AD717X_IFMODE_REG_DATA_STAT,
2 2, 2, 2, 2
{ AD717X_REGCHECK_REG, 0x0000, 3},
{AD717X_Data_REG, 0x0000, 4},
{AD717X_GPIOCON_REG, 0x0000, 2},
{ AD717X_ID_REG, 0x0000, 2 },
ad717x_chmap0_reg,
AD717X_CHMAPA_REG_CH_EN  AD717X_CHMAPA_REG_AINPOS(0)  AD717X_CHMAPA_REG_AINNEG(0x16),
2 2, 2, 2, 2
ad717x_chmap1_reg,
AD717X_CHMAPA_REG_CH_EN,AD717X_CHMAPA_REG_AINPOS(1) AD717X_CHMAPA_REG_AINNEG(0x16),
2 2, 2, 2, 2
ad717x_chmap2_reg,
AD717X_CHMAPA_REG_CH_EN  AD717X_CHMAPA_REG_AINPOS(2)  AD717X_CHMAPA_REG_AINNEG(0x16),
2 2, 2, 2, 2
ad717x_chmap3_reg,
AD717X_CHMAPA_REG_CH_EN  AD717X_CHMAPA_REG_AINPOS(3)  AD717X_CHMAPA_REG_AINNEG(0x16),
2 2, 2, 2, 2
{ AD717X_SETUPCON0_REG, 0x0000, 2 },
{AD717X_SETUPCON2_REG,0x000,2},
ad717x_过滤器0_reg,
             /*通道0 滤波器设置:*/
AD717X_FILT_CONF_REG_ENHFILT(2)AD717X_FILT_CONF_REG_ODR(14),
2 2, 2, 2, 2
ad717x_过滤器1_reg,
ad717x_filt_conf_reg_enhfilt(2),
2 2, 2, 2, 2
ad717x_过滤器2_reg,
2 2, 2, 2, 2
ad717x_过滤器3_reg,
2 2, 2, 2, 2
{AD717X_OFFSET0_REG,0,3},,
{AD717X_OFFSET1_REG,0,3},,
{AD717X_OFFSET2_REG,0,3},,
{AD717X_OFFSET3_REG,0,3},,
{AD717X_GAINO_REG,0,3},,
{AD717X_GAIN1_REG,0,3},
{AD717X_GAIN2_REG,0,3},,
数据读取如下:
Get_ AD717X_Data( 撤销) 无效
AD717X_ReadData( 我的_ ad7172_ 2, AD7172_ Data);
      switch((uint8_t)(AD7172_Data>>24) 0x3)
案例 0x00: buf[0] = AD7172_Data (0xffffff); 折叠;
案例 0x01: buf[1] = AD7172_Data (0xffffff); 折射;
案例 0x02: buf[2] = AD7172_Data (0xffffff); 分解;
案例 0x03: buf[3] = AD7172_Data (0xffffff); 分解;
默认:中断;
时 时
