瑞芯微Rockchip开发者社区
一曲作罢
9年用户 834经验值
擅长:可编程逻辑 电源/新能源 MEMS/传感技术
怎样去解决RK3328 Android10.0的应用强制横屏显示的问题呢
怎样去解决RK3328  Android10.0的应用强制横屏显示的问题呢?
石正厚
2022-3-9 16:32:20
  测试平台
  Platform: RK3328
  OS: Android 10.0
  现象
  机器没有内置重力传感器,所以部分强制竖屏的App(例如360)在上面显示有问题,所以我们强制所有App都横屏显示。
  解决方案
  以抖音为例,修改方法及效果如下所示
  1. 强制横屏,居中竖屏显示
  屏幕保持横屏,app竖屏居中如图所示
  修改方案:
  1.build.prop添加属性设置
  persist.sys.forced_orient=2
  ro.target.product=box
  2.代码强制
  diff --git a/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java b/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java
  index f2879ce..5a9c1ba 100644
  --- a/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java
  +++ b/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java
  @@ -245,10 +245,12 @@ public class DisplayRotation {
  void configure(int width, int height, int shortSizeDp, int longSizeDp) {
  // $ adb shell wm size reset
  && !“true”.equals(SystemProperties.get(“config.override_forced_orient”));
  - if(“2”.equals(SystemProperties.get(“persist.sys.forced_orient”,“0”))
  + if(“2”.equals(SystemProperties.get(“persist.sys.forced_orient”,“0”))
  &&“box”.equals(SystemProperties.get(“ro.target.product”,“unknow”))){
  mDefaultFixedToUserRotation = true;
  + mDefaultFixedToUserRotation = true;
  2. 强制横屏,全屏显示
  屏幕保持横屏,app全屏如图所示
  修改方案:
  diff --git a/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java b/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java
  index cb38bac..81e345d 100644
  --- a/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java
  +++ b/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java
  @@ -27,6 +27,7 @@ import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_BEHIND;
  import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_UNSET;
  import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_UNSPECIFIED;
  import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_USER;
  +import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_LANDSCAPE;
  import static android.content.res.Configuration.ORIENTATION_LANDSCAPE;
  import static android.content.res.Configuration.ORIENTATION_PORTRAIT;
  import static android.os.Trace.TRACE_TAG_WINDOW_MANAGER;
  @@ -1323,7 +1324,8 @@ class DisplayContent extends WindowContainer《DisplayContent.DisplayChildWindowCo
  private boolean updateOrientat
