瑞芯微Rockchip开发者社区
djelje
8年用户 987经验值
擅长:光电显示
怎样去配置RK3288的双屛异显功能呢
怎样去配置RK3288的双屛异显功能呢?有哪些配置步骤?
李婧
2022-3-4 09:26:51
3288最强功能之一就是双屏异显,7.1以上不需要打补丁,RK已经把补丁打好,只需要配置dts以及build.prop变量即可。
1.配置dts支持mipi+edp双屏显示:
首先是mipi的dts配置
&dsi0 {
    status = "okay";
    //rockchip,lane-rate = <400>;
    panel: panel {
        compatible = "simple-panel-dsi";
        reg = <0>;
        backlight = <&backlight>;
        //enable-gpios = <&gpio7 3 GPIO_ACTIVE_HIGH>;  //gpio7_a3 mark
        //reset-gpios = <&gpio7 4 GPIO_ACTIVE_LOW>;
        power-supply = <&vcc_lcd>;
        dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST | MIPI_DSI_MODE_LPM | MIPI_DSI_MODE_EOT_PACKET|MIPI_DSI_MODE_VIDEO_HBP)>;
        dsi,format = ;
        dsi,lanes = <4>;
        reset-delay-ms = <20>;
        init-delay-ms = <20>;
        enable-delay-ms = <120>;
        prepare-delay-ms = <120>;
        status = "okay";
        panel-init-sequence = [
            05 78 01 11
            05 14 01 29
        panel-exit-sequence = [
            05 64 01 28
            05 96 01 10
        disp_timings: display-timings {
            native-mode = <&timing0>;
            timing0: timing0 {
                clock-frequency = <95000000>;
                hactive = <1920>;
                vactive = <1080>;
                hfront-porch = <48>;
                hsync-len = <32>;
                hback-porch = <80>;
                vfront-porch = <10>;
                vsync-len = <5>;
                vback-porch = <16>;
                hsync-active = <0>;
                vsync-active = <0>;
                de-active = <0>;
                pixelclk-active = <0>;
&dsi1 {
    status = "disabled";
&route_dsi0 {
    status = "okay";
    connect = <&vopl_out_dsi0>;
&dsi0_in_vopl {
    status = "okay";
&dsi0_in_vopb {
edp显示的配置:
&edp_panel {
    //backlight = <&backlight1>;
    //backlight = <&backlight>
    enable-gpios = <&gpio7 4 GPIO_ACTIVE_HIGH>;
    enable-delay-ms = <10>;
    pinctrl-0 = <&lcd_cs>;
    status = "okay";
    display-timings {
        native-mode = <&F402>;
        F402: timing0 {
            clock-frequency = <88266000>;
            hactive = <1600>;
            vactive = <900>;
            hfront-porch = <270>;
            hsync-len = <100>;
            hback-porch = <100>;
            vfront-porch = <20>;
            vsync-len = <20>;
            vback-porch = <30>;
            hsync-active = <0>;
            vsync-active = <0>;
            de-active = <0>;
&edp {
    status = "okay";
&edp_phy {
    status = "okay";
&route_edp {
    status = "okay";
    connect = <&vopb_out_edp>;
&edp_in_vopb {
    status = "okay";
&edp_in_vopl {
双屏由于需要两个背光控制,所以需要写两个backlight节点,我在edp这里,并没有绑定backlight节点,但可以在Hardware通过节点直接调节。直接在这里绑定backlight节点,会导致系统无法跑起来,没有仔细研究,因此没有做绑定
2.设置build.prop变量
sys.hwc.device.primary=eDP
sys.hwc.device.extend=DSI
