瑞芯微Rockchip开发者社区
陈燕
7年用户 1060经验值
搭建VS-RK3288 Ubuntu编译环境出错了怎么办呢
搭建VS-RK3288 Ubuntu编译环境出错了怎么办呢?
张波
2022-3-4 15:55:02
   注意了! - 开始了
  一个新安装的编译器的编译,使用的是:
  Ubuntu14.04.2 LTS (GNU/Linux 3.16.0-30-generic x86_64)
  构建会遇到一些小程序包的错误,如下。
  Build Kernel:
  Error 1:
  build@build--machine:~/rk3288/kernel$ make
  rk3288-tb_8846.img
  LD vmlinux
  SORTEX vmlinux
  SYSMAP System.map
  OBJCOPY arch/arm/boot/Image
  Kernel: arch /arm/boot/Image 准备好
  了 AS arch/arm/boot/compressed/head.o
  LZO arch/arm/boot/compressed/piggy.lzo
  /bin/sh: 1: lzop: not found
  CC arch/arm/boot/ compressed/misc.o
  make[2]: *** [arch/arm/boot/compressed/piggy.lzo] 错误
  1
  make[2]: *** Waiting for unfinished jobs.。..
  make[2]: *** wait: 没有子进程。
  停止。
  make[1]: *** [arch/arm/boot/compressed/vmlinux] 错误 2
  make: *** [zImage] 错误 2
  解决办法:
  #sudo apt-get install lzop
  错误 2:
  build@build--machine :~/rk3288/kernel$ make
  rk3288-tb_8846.img
  scripts/kconfig/conf --silentoldconfig Kconfig
  ^C
  rk3288-tb_8846.img
  CC scripts/mod/devicetable- offsets.s
  GEN scripts/mod/devicetable-
  offsets.h HOSTCC
  scripts/mod/file2alias.o
  HOSTLD
  scripts/mod/modpost
  CHK include/generated/uapi/linux/version.h
  CHK include/generated/utsrelease.h
  make[1]: `include/generated/mach-types.h‘ 是最新的。
  CALL scripts/checksyscalls.sh
  CHK include/generated/compile.h
  GEN drivers/video/rockchip/screen/lcd.h
  Kernel: arch/arm/boot/Image is ready
  LD arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/ arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
  make: *** [kernel.img] Error 127
  #### make failed to build some targets (18 seconds) ####
  解决办法:
  安装64位机子对32位程序运行的支持。
  #sudo apt-get install libc6:i386 libncurses5:i386
  libstdc++6:i386
  另外,Android 5.1用的java环境是openjdk-7,否则报错。
  解决办法:
  #sudo apt-get install openjdk-7-jdk
  # PATH=/usr/lib/jvm/java-7-openjdk-amd64/bin:$PATH
  Build Android:
  Error1:
  build@build--machine:~/rk3288/kernel$ make -j8
  注意文件:external/jarjar/NOTICE --
  out/host/linux-x86/obj/NOTICE_FILES/src //framework/jarjar.jar.txt
  Yacc:aidl 《=
  frameworks/base/tools/aidl/aidl_language_y.y
  prebuilts/misc/linux-x86/bison/bison -d -o
  out/host/linux-x86/obj/ EXECUTABLES/aidl_intermediates/aidl_language_y.cpp
  通知文件:frameworks/base/tools/aidl/NOTICE --
  out/host/linux-x86/obj/NOTICE_FILES/src//bin/aidl .txt词法
  :aidl 《=
  frameworks/base/tools/aidl/aidl_language_l.l
  制作:***
  [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp]
  管道损坏
  :*** 正在等待未完成的作业。..。
  flex-2.5.39:致命的内部错误,/usr/bin 的 exec /m4
  failed
  frameworks/base/tools/aidl/aidl_language_l.l:55: 警告,规则
  无法匹配
  make: ***
  [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp]管道
  损坏
  : *** 删除文件
  `out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp’
  注意:一些输入文件使用未经检查或不安全的
  操作。
  注意:使用 -Xlint:unchecked 重新编译以获取详细信息。
  注意:某些输入文件使用未经检查或不安全的
  操作。
  注意:某些输入文件使用或覆盖已弃用的 API。
  注意:使用 -Xlint:deprecation 重新编译以获取详细信息。
  注意:某些输入文件使用未经检查或不安全
  的操作。
  注意:使用 -Xlint 重新编译:unchecked for details.
  解决办法:
  #sudo apt-get install bison
  Error2:
  Copy: out/target/product/rk3288/system /etc/.allBlock
  Copy: out/target/product/rk3288/system/etc/.videoBlock
  Copy xml:
  out/target/product/rk3288/system/etc/GS8604.xml
  /bin/bash: xmllint: command not found
  make : *** [out/target/product/rk3288/system/etc/GS8604.xml]
  错误 127
  make: *** Waiting for unfinished jobs.。..
  准备 StaticLib: libc_common [包括
  out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_thread_atexit_impl_intermediates/libc_thread_atexit_impl.a]
  out/target/product /rk3288/obj/STATIC_LIBRARIES/libc_tzcode_intermediates/libc_tzcode.a]
  target StaticLib: libc_common
  (out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_common_intermediates/libc_common.a)
  #### make 无法构建一些目标 (12:49 (mm:ss))
  解决方法:
  #sudo apt-get install libxml2-utils
