RK3288[android 7.1]调试笔记 设置默认锁屏方式为None
修改路径为/frameworks/base/packages/SettingsProvider/res/values/defaults.xml 此文件中的def_lockscreen_disabled值由false变为true
wangxd@build-server-100:~/work/dsy/rk3288-Android-7.0/frameworks/base(m_android_7_0)$ git diff packages/SettingsProvider/res/values/defaults.xml
diff --git a/packages/SettingsProvider/res/values/defaults.xml b/packages/SettingsProvider/res/values/defaults.xml
old mode 100644
new mode 100755
index f4cefc2..2c088e3
--- a/packages/SettingsProvider/res/values/defaults.xml
+++ b/packages/SettingsProvider/res/values/defaults.xml
true
@@ -80,7 +80,7 @@
/system/media/audio/ui/Trusted.ogg
/system/media/audio/ui/WirelessCharg
- false
+ true
false
1
实际上系统的默认锁屏方式值的数据库是由frameworksbasepackagesSettingsProvidersrccomandroidproviderssettingsDatabaseHelper.java创建的
private void loadSecureSettings(SQLiteDatabase db) {
SQLiteStatement stmt = null;
if (SystemProperties.getBoolean("ro.lockscreen.disable.default", false) == true) {
loadSetting(stmt, Settings.System.LOCKSCREEN_DISABLED, "1");
} else {
loadBooleanSetting(stmt, Settings.System.LOCKSCREEN_DISABLED,
R.bool.def_lockscreen_disabled);//这里就是加载def_lockscreen_disabled这个布偶值,为true就设置默认锁屏方式为None,为false采用Android系统原生的默认锁屏方式是Swipe 滑动方式解锁
@Override
public void onUpgrade(SQLiteDatabase db, int oldVersion, int currentVersion) {
Log.w(TAG, "Upgrading settings database from version " + oldVersion + " to "
+ currentVersion);
if (upgradeVersion == 75) {
db.beginTransaction();
Cursor c = null;
try {
c = db.query(TABLE_SECURE, new String[] {"_id", "value"},
"name='lockscreen.disabled'",
null, null, null, null);
// only set default if it has not yet been set
if (c == null || c.getCount() == 0) {
stmt = db.compileStatement("INSERT INTO system(name,value)"
+ " VALUES(?,?);");
R.bool.def_lockscreen_disabled);//这里获取设置锁屏方式的布局
db.setTransactionSuccessful();
} finally {
db.endTransaction();
if (c != null) c.close();
if (stmt != null) stmt.close();
upgradeVersion = 76;
/************* The following are Jelly Bean changes ************/
old mode 100644
new mode 100755
true
@@ -80,7 +80,7 @@
- false
+ true
false
1
} else {
@Override
+ currentVersion);
Cursor c = null;
try {
+ " VALUES(?,?);");
} finally {
