#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "user_interface.h"
#include "espconn.h"
#include "ip_addr.h"
#include "mem.h"
# include "user_devicefind.h"
#include "user_webserver.h"
#include "pwm.h"
#if ESP_PLATFORM
#include "user_esp_platform.h"
#endif
#if ((SPI_FLASH_SIZE_MAP == 0) || (SPI_FLASH_SIZE_MAP == 1))
#error "不支持闪存映射"
#elif (SPI_FLASH_SIZE_MAP == 2)
#define SYSTEM_PARTITION_OTA_SIZE 0x6A000
#define SYSTEM_PARTITION_OTA_2_ADDR 0x81000
的#define SYSTEM_PARTITION_RF_CAL_ADDR 0xfb000
的#define SYSTEM_PARTITION_PHY_DATA_ADDR 0xfc000
的#define SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR 0xfd000
的#define SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM_ADDR 0x7c000
#elif指令(SPI_FLASH_SIZE_MAP == 3)
的#define SYSTEM_PARTITION_OTA_SIZE 0x6A000
的#define SYSTEM_PARTITION_OTA_2_ADDR 0x81000
的#define SYSTEM_PARTITION_RF_CAL_ADDR 0x1fb000
的#define SYSTEM_PARTITION_PHY_DATA_ADDR 0x1fc000
的#define SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR 0x1fd000
#elif指令(SPI_FLASH_SIZE_MAP == 4)
的#define SYSTEM_PARTITION_RF_CAL_ADDR 0x3fb000
的#define SYSTEM_PARTITION_PHY_DATA_ADDR 0x3fc000
的#define SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR 0x3fd000
#elif指令(SPI_FLASH_SIZE_MAP == 5)
的#define SYSTEM_PARTITION_OTA_2_ADDR 0x101000
的#define SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM_ADDR 0xfc000
#elif指令(SPI_FLASH_SIZE_MAP == 6)
的#else
#ERROR “闪光灯地图不被支持”
#ENDIF
的#define SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM SYSTEM_PARTITION_CUSTOMER_BEGIN
#define TCP_SERVER_IP "116.62.81.138"
#define qingqiu "GET /v3/weather/now.json?key=smtq3n0ixdggurox&location=beijing&language=en&unit=c HTTP/1.1rnHost:api.seniverse.comrnr n" //请求的接口
uint32 priv_param_start_sec;
静态 void tcp_client_sent_cb(void *arg);
static void tcp_client_recv_cb(void *arg,char *pdata,unsigned short length);
静态 void tcp_client_recon_cb(void *arg,sint8 错误);
静态 void tcp_client_discon_cb(void *arg);
静态 void tcp_client_connect_cb(void *arg);
os_timer_t os_timer;//
静态表_const partition_item_partition_item [] = {
{ SYSTEM_PARTITION_BOOTLOADER, 0x0, 0x1000},
{ SYSTEM_PARTITION_OTA_1, 0x1000, SYSTEM_PARTITION_OTA_SIZE},
{ SYSTEM_PARTITION_OTA_2, SYSTEM_PARTITION_OTA_2_ADDR, SYSTEM_PARTITION_OTA_SIZE},
{ SYSTEM_PARTITION_RF_CAL, SYSTEM_PARTITION_RF_0 }0_CAL_ADDR
{ SYSTEM_PARTITION_PHY_DATA, SYSTEM_PARTITION_PHY_DATA_ADDR, 0x1000},
{ SYSTEM_PARTITION_SYSTEM_PARAMETER, SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR, 0x3000},
{ SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM, SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM_ADDR, 0x1000},
void ICACHE_FLASH_ATTR user_pre_init(void)
if(!system_partition_table_regist(at_partition_table, sizeof(at_partition_table)/sizeof(at_partition_table[0]),SPI_FLASH_SIZE_MAP)) {
os_printf("system_partition_table_regist 失败rn");
而(1);
static void ICACHE_FLASH_ATTR
tcp_client_sent_cb(void *arg){
os_printf("tcp客户端发送数据成功rn");
* TCP Client 接收数据处理/函数发送,可以在这接收到的来的
static void
ICACHE_FLASH_ATTRtcp_client_recv_cb(void *arg,char *pdata,unsigned short tcp){
os_printf("tcp client receive tcp服务器数据rn");
os_printf("长度: %d rn数据: %srn",len,pdata);
tcp_client_recon_cb(void *arg,sint8 error){
os_printf("tcp client connect tcp server error %drn",error); /**
* TCP Client 破坏接口调用函数* /
tcp_client_discon_cb(void *arg){
os_printf("tcp客户端断开tcp服务器成功rn");
* TCP 客户端连接成功回调函数
static voidICACHE_FLASH_R
tcp_client_connect_cb(void *arg){
struct espconn *pespconn = arg;
os_printf("tcp客户端连接tcp服务器成功rn");
pconn_regist_recvcb(pespconn,tcp_recvcb(pespconn,tcp_recvcb);//注册接收数据_recv_cb;//注册接收数据_recv_cb
)(pespconn,tcp_client_sent_cb);//注册连接函数
espconn_regist_disconnb(pespconn,tcp_client_di***);//注册连接函数
/*char buffer[1024 ];
memset(缓冲区,0,1024);
os_sprintf(buffer,"/v3/weather/now.json?language=en&key=Sn5RsUO2O3kUx9tzO&location=lingao&unit=c","api.seniverse.com");
os_printf("user_esp_platform_connect_cbrn");
espconn_send(pespconn,buffer,os_strlen(buffer));*/
espconn_send(pespconn,青丘,os_strlen(青丘));
void ICACHE_FLASH_ATTR user_set_station_config
(void)
char ssid[32];
字符密码[64];
结构站配置站配置;
stationConf.bssid_set = 0; //不需要检查AP的MAC地址
os_memcpy(stationConf.ssid, ssid, 32);
os_memcpy(stationConf.password, 密码, 64);
wifi_station_set_config(&stationConf);
结构 espconn tcp_client;
tcp_client_init(struct espconn *espconn,uint8 *remote_ip,struct ip_addr *local_ip, int remote_port){
uint32 server_ip = ipaddr_addr(remote_ip);
os_printf("tcp客户端连接tcp服务器rn");
espconn->proto.tcp = (esp_tcp *)os_zalloc(sizeof(esp_tcp));
espconn->type = ESPCONN_TCP;
os_memcpy(espconn->proto.tcp->remote_ip,&server_ip,4);//设置要连接的服务器IP地址
espconn->proto.tcp->remote_port = remote_port;//设置要连接的服务器端口号
os_memcpy(espconn->proto.ip->local_ip,4);//设置本地IP地址
espconn->proto.tcp->local_port =espconn_port);//设置本地端口号
espconn_regist_connectcb(espconn,tcp_client_connect_cb); //注册连接成功回调函数注册
espconn_reg_reconn(espconn,cp_client_recon_cb);/连重连接c函数
espconn_connect(espconn);// ClientServer
void CHE_FLASH_ATTR
huidiao(void)
os_printf("hello word");
结构 ip_info local_ip;
wifi_get_ip_info(STATION_IF,&local_ip);
tcp_client_init(&tcp_client,TCP_SERVER_IP,&local_ip.ip,80);
os_printf("你好n");
os_timer_disarm(&os_timer);
user_init(void)
partition_item_t partition_item;
os_printf("SDK版本:%sn", system_get_sdk_version());
if (!system_partition_get_item(SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM, &partition_item)) {
os_printf("获取分区信息失败n");
priv_param_start_sec = partition_item.addr/SPI_FLASH_SEC_SIZE;
os_printf("你好!");
wifi_set_opmode(STATIONAP_MODE);
user_set_station_config();
os_timer_setfn(&os_timer,(os_timer_func_t*)huidiao,NULL);
os_timer_arm(&os_timer,10000,1);
#include "osapi.h"
#include "gpio.h"
#include "mem.h"
#include "pwm.h"
#if ESP_PLATFORM
#endif
#error "不支持闪存映射"
的#else
#ERROR “闪光灯地图不被支持”
#ENDIF
而(1);
static void
* TCP 客户端连接成功回调函数
memset(缓冲区,0,1024);
(void)
char ssid[32];
字符密码[64];
结构站配置站配置;
void CHE_FLASH_ATTR
huidiao(void)
os_printf("你好n");
user_init(void)
os_printf("你好!");
