瑞芯微Rockchip开发者社区
而无返还
8年用户 1182经验值
擅长:光电显示
怎样去配置一种Android8.1环境呢
如何对Android8.1进行编译呢?
怎样去配置一种Android8.1环境呢?
赵群山
2022-2-11 11:08:36
1.前期准备
1.1硬件以及软件配置
Ubuntu 16.04 系统(可使用真机也可使用虚拟机,虚拟机已经实测)
Ubuntu 16.04电脑配置:
CPU:4核级以上。
内存:12GB及以上。(实际在编译过程中使用8G内存编译显示内存不够,改成12G才编译通过)
显卡:无要求
存储:200G。
1.2虚拟机安装Ubuntu
2.更换软件更新源
我们在安装ubuntu时,由于ubuntu镜像一般默认自带的都是us的官方源。这些镜像源的地址在中国大多数难以连接,因此需要换国内的源,国内的源有网易源、阿里源、科大源等等
如果能自己挂VPN,或者***请无视这一步。
2.1替换源文件
sudo su     #输入密码
cd /etc/apt  #切换到apt源文件
mv  sources.list sources.list_bak  #备份源文件
vim sources.list  #新建一个,然后将下面的内容copy进去
deb cdrom:[Ubuntu 16.04 LTS _Xenial Xerus_ - Release amd64 (20160420.1)]/ xenial main restricted
deb-src http://archive.ubuntu.com/ubuntu xenial main restricted #Added by software-properties
deb http://mirrors.aliyun.com/ubuntu/ xenial main restricted
deb-src http://mirrors.aliyun.com/ubuntu/ xenial main restricted multiverse universe #Added by software-properties
deb http://mirrors.aliyun.com/ubuntu/ xenial-updates main restricted
deb-src http://mirrors.aliyun.com/ubuntu/ xenial-updates main restricted multiverse universe #Added by software-properties
deb http://mirrors.aliyun.com/ubuntu/ xenial universe
deb http://mirrors.aliyun.com/ubuntu/ xenial-updates universe
deb http://mirrors.aliyun.com/ubuntu/ xenial multiverse
deb http://mirrors.aliyun.com/ubuntu/ xenial-updates multiverse
deb http://mirrors.aliyun.com/ubuntu/ xenial-backports main restricted universe multiverse
deb-src http://mirrors.aliyun.com/ubuntu/ xenial-backports main restricted universe multiverse #Added by software-properties
deb http://archive.canonical.com/ubuntu xenial partner
deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://mirrors.aliyun.com/ubuntu/ xenial-security main restricted
deb-src http://mirrors.aliyun.com/ubuntu/ xenial-security main restricted multiverse universe #Added by software-properties
deb http://mirrors.aliyun.com/ubuntu/ xenial-security universe
deb http://mirrors.aliyun.com/ubuntu/ xenial-security multiverse
2.2更新配置
按ecs,然后:wq保存后退出
再执行命令更新配置
sudo apt-get update
3.搭建编译环境
搭建用于编译Android的环境,建议使用64位的Ubuntu 16.04,需要安装如下软件包
sudo apt-get install bison g++-multilib git gperf libxml2-utils make python-networkx zip
sudo apt-get install flex curl libncurses5-dev libssl-dev zlib1g-dev gawk minicom
sudo apt-get install openjdk-8-jdk
sudo apt-get install exfat-fuse exfat-utils device-tree-compiler liblz4-tool
sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev
libesd0-dev squashfs-tools build-essential zip curl
libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils
xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev
gcc-multilib libswitch-perl
libssl1.0.0 libssl-dev  lib32readline-gplv2-dev libwxgtk2.8-dev
  • 环境配置问题
ubuntu16.04  libwxgtk2.8-dev安装出错
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install libwxgtk2.8-dev
        ubuntu16.04 安装 lib32readline-gplv2-dev 出错
直接用 lib32readline6-dev 替代:lib32readline-gplv2-dev
sudo apt-get install  lib32readline6-dev
4.编译Android8.1源代码
4.1下载Android 8.1源代码
4.2编译生成并生成Image文件
4.2.1 JDK 安装
执行以下命令安装:
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
4.2.2编译Android源码包
说明:编译映像时一定要使用普通权限编译。编译生成的镜像统一放在 out/release 目录下,包括 MiniLoaderAll.bin、uboot.img、trust.img、resource.img、kernel.img、boot.img、misc.img, recovery.img、system.img、vendor.img、oem.img、update-android.img
  • 编译 uboot
    在 android 源码目录下执行如下命令编译 uboot,编译完成后映像文件会释放到 out/release 目录:MiniLoaderAll.bin、uboot.img、trust.img
./mk.sh        -u
  • 编译内核
    在 android 源码目录下执行如下命令编译 android 内核,编译完成后映像文件 kernel.img、 resource.img 会释放到 out/release 目录。
./mk.sh        -k
  • 编译 android 文件系统
    在 android 源码目录下执行如下命令编译 android 映像文件,编译完成后映像文件会释放到 out/release 目录。
./mk.sh        -s
  • 生成固件
./mk.sh        -U 编译完文件系统,在 out/release 目录下会生成如下文件:
MiniLoaderAll.bin、uboot.img、trust.img: uboot 映像文件
Kernel.img:内核映像
Resource.img:资源映像,内含开机图片和内核的设备树信息。
Boot.img: Android 的初始文件映像,负责初始化并加载 system 分区。
System.img:android 的 system 分区映像,ext4 文件格式系统。
Recovery.img:急救模式映像。
Misc.img:分区映像,负责启动模式切换和急救模式的参数传递。
oem.img:用于给厂家使用,存放厂家的 APP 或数据。只读
update-android.img:整个升级文件的单一映像,包括了 uboot,内核,文件系统等。
  • 查看编译帮助
    执行如下指令可查询 mk 脚本使用方法:
./mk.sh        -h
“-u”表示编译 uboot
“-k”表示编译内核
“-s”表示编译 Android 文件系统
“-U”表示所有的镜像编译完成后执行打包程序(生成 update-android.img 镜像)
“-j=”表示多线程编译(比如-j=20)
“-a”表示所有的都执行。注意,“-a”等同于“./mk.sh -u -k -s -U”
