邹俩珍
7年用户 1011经验值
STM32F103固件库编程的知识点汇总,错过绝对后悔
何羽衣
2021-12-14 11:26:25
  (一)USART寄存器映象
  (二)时钟函数及其参数
  USART1在APB2(高速)
USART2、USART3、USART4、USART5在APB1(低速)
void RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState)
  /* Check the parameters */
  assert_param(IS_RCC_APB2_PERIPH(RCC_APB2Periph));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    RCC->APB2ENR |= RCC_APB2Periph;
  else
    RCC->APB2ENR &= ~RCC_APB2Periph;
@arg RCC_APB2Periph_AFIO, RCC_APB2Periph_GPIOA, RCC_APB2Periph_GPIOB, RCC_APB2Periph_GPIOC, RCC_APB2Periph_GPIOD, RCC_APB2Periph_GPIOE,
RCC_APB2Periph_GPIOF, RCC_APB2Periph_GPIOG, RCC_APB2Periph_ADC1,RCC_APB2Periph_ADC2,
RCC_APB2Periph_TIM1, RCC_APB2Periph_SPI1,
RCC_APB2Periph_TIM8, RCC_APB2Periph_USART1, RCC_APB2Periph_ADC3,RCC_APB2Periph_TIM15, RCC_APB2Periph_TIM16, RCC_APB2Periph_TIM17,
RCC_APB2Periph_TIM9, RCC_APB2Periph_TIM10, RCC_APB2Periph_TIM11
@param NewState: new state of the specified peripheral clock.
This parameter can be: ENABLE or DISABLE.
(三)初始化USART_InitTypeDef;
typedef struct
  uint32_t USART_BaudRate;            /*!< This member configures the USART communication baud rate.
                                           The baud rate is computed using the following formula:
                                            - IntegerDivider = ((PCLKx) / (16 * (USART_InitStruct->USART_BaudRate)))
                                            - FractionalDivider = ((IntegerDivider - ((u32) IntegerDivider)) * 16) + 0.5 */
  uint16_t USART_WordLength;          /*!< Specifies the number of data bits transmitted or received in a frame.
                                           This parameter can be a value of @ref USART_Word_Length */
  uint16_t USART_StopBits;            /*!< Specifies the number of stop bits transmitted.
                                           This parameter can be a value of @ref USART_Stop_Bits */
  uint16_t USART_Parity;              /*!< Specifies the parity mode.
                                           This parameter can be a value of @ref USART_Parity
                                           @note When parity is enabled, the computed parity is inserted
                                                 at the MSB position of the transmitted data (9th bit when
                                                 the word length is set to 9 data bits; 8th bit when the
                                                 word length is set to 8 data bits). */
  uint16_t USART_Mode;                /*!< Specifies wether the Receive or Transmit mode is enabled or disabled.
                                           This parameter can be a value of @ref USART_Mode */
  uint16_t USART_HardwareFlowControl; /*!< Specifies wether the hardware flow control mode is enabled
                                           or disabled.
                                           This parameter can be a value of @ref USART_Hardware_Flow_Control */
} USART_InitTypeDef;
void USART_Init(USART_TypeDef* USARTx, USART_InitTypeDef* USART_InitStruct);
1
(四)代码
#ifndef __BSP_USART_H
#define __BSP_USART_H
#include "stm32f10x.h"
#include
#define DEBUG_USART1     1
#define DEBUG_USART2     0
#define DEBUG_USART3     0
#define DEBUG_USART4     0
#define DEBUG_USART5     0
#if DEBUG_USART1
// 串口1-USART1
#define  DEBUG_USARTx                   USART1
#define  DEBUG_USART_CLK                RCC_APB2Periph_USART1
#define  DEBUG_USART_APBxClkCmd         RCC_APB2PeriphClockCmd
#define  DEBUG_USART_BAUDRATE           115200
// USART GPIO 引脚宏定义
#define  DEBUG_USART_GPIO_CLK           (RCC_APB2Periph_GPIOA)
#define  DEBUG_USART_GPIO_APBxClkCmd    RCC_APB2PeriphClockCmd
#define  DEBUG_USART_TX_GPIO_PORT       GPIOA
#define  DEBUG_USART_TX_GPIO_PIN        GPIO_Pin_9
#define  DEBUG_USART_RX_GPIO_PORT       GPIOA
#define  DEBUG_USART_RX_GPIO_PIN        GPIO_Pin_10
#define  DEBUG_USART_IRQ                USART1_IRQn
#define  DEBUG_USART_IRQHandler         USART1_IRQHandler
#elif DEBUG_USART2
//串口2-USART2
#define  DEBUG_USARTx                   USART2
#define  DEBUG_USART_CLK                RCC_APB1Periph_USART2
#define  DEBUG_USART_APBxClkCmd         RCC_APB1PeriphClockCmd
// USART GPIO 引脚宏定义
#define  DEBUG_USART_TX_GPIO_PIN        GPIO_Pin_2
#define  DEBUG_USART_RX_GPIO_PIN        GPIO_Pin_3
#define  DEBUG_USART_IRQ                USART2_IRQn
#define  DEBUG_USART_IRQHandler         USART2_IRQHandler
#elif DEBUG_USART3
//串口3-USART3
#define  DEBUG_USARTx                   USART3
#define  DEBUG_USART_CLK                RCC_APB1Periph_USART3
// USART GPIO 引脚宏定义
#define  DEBUG_USART_GPIO_CLK           (RCC_APB2Periph_GPIOB)
#define  DEBUG_USART_TX_GPIO_PORT       GPIOB
#define  DEBUG_USART_TX_GPIO_PIN        GPIO_Pin_10
#define  DEBUG_USART_RX_GPIO_PORT       GPIOB
#define  DEBUG_USART_RX_GPIO_PIN        GPIO_Pin_11
#define  DEBUG_USART_IRQ                USART3_IRQn
#define  DEBUG_USART_IRQHandler         USART3_IRQHandler
#elif DEBUG_USART4
//串口4-UART4
#define  DEBUG_USARTx                   UART4
#define  DEBUG_USART_CLK                RCC_APB1Periph_UART4
// USART GPIO 引脚宏定义
#define  DEBUG_USART_GPIO_CLK           (RCC_APB2Periph_GPIOC)
#define  DEBUG_USART_TX_GPIO_PORT       GPIOC
#define  DEBUG_USART_RX_GPIO_PORT       GPIOC
#define  DEBUG_USART_IRQ                UART4_IRQn
#define  DEBUG_USART_IRQHandler         UART4_IRQHandler
#elif DEBUG_USART5
//串口5-UART5
#define  DEBUG_USARTx                   UART5
#define  DEBUG_USART_CLK                RCC_APB1Periph_UART5
// USART GPIO 引脚宏定义
#define  DEBUG_USART_GPIO_CLK           (RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD)
#define  DEBUG_USART_TX_GPIO_PIN        GPIO_Pin_12
#define  DEBUG_USART_RX_GPIO_PORT       GPIOD
#define  DEBUG_USART_RX_GPIO_PIN        GPIO_Pin_2
#define  DEBUG_USART_IRQ                UART5_IRQn
#define  DEBUG_USART_IRQHandler         UART5_IRQHandler
#endif
void USART_Config(void);
void Usart_SendByte(USART_TypeDef* pUSARTx, uint8_t data);
void Usart_SendHalfWord(USART_TypeDef* pUSARTx, uint16_t data);
void Usart_SendArray(USART_TypeDef* pUSARTx, uint8_t *array,uint8_t num);
void Usart_SendStr(USART_TypeDef* pUSARTx, uint8_t *str);
#endif  /* __BSP_USART_H */
#include "bsp_usart.h"
static void NVIC_Configuration(void)
  /* 嵌套向量中断控制器组选择 */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  /* 配置USART为中断源 */
  NVIC_InitStructure.NVIC_IRQChannel = DEBUG_USART_IRQ;
  /* 抢断优先级*/
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  /* 子优先级 */
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  /* 使能中断 */
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  /* 初始化配置NVIC */
        USART_InitTypeDef USART_InitStructure;
        // 打开串口GPIO的时钟
        DEBUG_USART_GPIO_APBxClkCmd(DEBUG_USART_GPIO_CLK, ENABLE);
        // 打开串口外设的时钟
        DEBUG_USART_APBxClkCmd(DEBUG_USART_CLK, ENABLE);
        // 将USART Tx的GPIO配置为推挽复用模式
        GPIO_InitStructure.GPIO_Pin = DEBUG_USART_TX_GPIO_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(DEBUG_USART_TX_GPIO_PORT, &GPIO_InitStructure);
  // 将USART Rx的GPIO配置为浮空输入模式
        GPIO_InitStructure.GPIO_Pin = DEBUG_USART_RX_GPIO_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init(DEBUG_USART_RX_GPIO_PORT, &GPIO_InitStructure);
        // 配置串口的工作参数
        // 配置波特率
        USART_InitStructure.USART_BaudRate = DEBUG_USART_BAUDRATE;
        // 配置 针数据字长
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        // 配置停止位
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        // 配置校验位
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        // 配置硬件流控制
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        // 配置工作模式,收发一起
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        // 完成串口的初始化配置
        USART_Init(DEBUG_USARTx, &USART_InitStructure);
        // 串口中断优先级配置
        NVIC_Configuration();
        // 使能串口接收中断
        USART_ITConfig(DEBUG_USARTx, USART_IT_RXNE, ENABLE);
        // 使能串口
        USART_Cmd(DEBUG_USARTx, ENABLE);
/* 发送一个字节 */
        USART_SendData(pUSARTx, data);
        while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET );
/* 发送两个字节的数据 */
        uint8_t temp_h,temp_l;
        temp_h = (data&0xff00) >> 8 ;
        temp_l = data&0xff;
        USART_SendData(pUSARTx, temp_h);
        USART_SendData(pUSARTx, temp_l);
/* 发送8位数据的数组 */
        uint8_t i;
        for( i=0; i   {
                Usart_SendByte(pUSARTx, array);
        while( USART_GetFlagStatus(pUSARTx, USART_FLAG_TC) == RESET );
/* 发送字符串 */
        uint8_t i=0;
        do
                Usart_SendByte(pUSARTx, *(str+i));
                i++;
        }while(*(str+i) != '');
///重定向c库函数printf到串口,重定向后可使用printf函数
int fputc(int ch, FILE *f)
                /* 发送一个字节数据到串口 */
                USART_SendData(DEBUG_USARTx, (uint8_t) ch);
                /* 等待发送完毕 */
                while (USART_GetFlagStatus(DEBUG_USARTx, USART_FLAG_TXE) == RESET);
                return (ch);
///重定向c库函数scanf到串口,重写向后可使用scanf、getchar等函数
int fgetc(FILE *f)
                /* 等待串口输入数据 */
                while (USART_GetFlagStatus(DEBUG_USARTx, USART_FLAG_RXNE) == RESET);
                return (int)USART_ReceiveData(DEBUG_USARTx);
#include "bsp_led.h"
int main(void)
  uint8_t a[10]={100,2,3,4,5,6,7,8,9,10};
        USART_Config();
//        Usart_SendByte(DEBUG_USARTx,'A');
//        Usart_SendHalfWord(DEBUG_USARTx, 0xff56);
//        Usart_SendArray(DEBUG_USARTx, a,10);
//        Usart_SendStr(DEBUG_USARTx, "欢迎使用秉火STM32F103开发板 n");
        printf( "串口printf函数测试n" );
        while (1)
(五)问题
  (1)???啥作用
(2)???
中断在哪里
(3)函数太多了
