ST意法半导体
周颂焱
7年用户 150经验值
ST25DV04如果ST25DV04一直处于读写器下,则会出现NFC I2C通信问题
ST25DV04如果ST25DV04一直处于读写器下,则会出现NFC I2C通信问题。有些情况(每几十分钟一个),I2C和RF上的通信一起关闭,如果ST25DV04处于正常状态,则无法复位。建议I2C长“启动条件”不能解决问题。在这种情况下我如何重置芯片。
#st25dv04-NFC-I2C
以上来自于谷歌翻译
以下为原文
ST25DV04 NFC I2C communication problem if ST25DV04 all time under Reader. There are cases (one per tens of minutes) that communication on I2C and RF is closed together and there is no way to reset if ST25DV04 to normal state. Recommended I2C long 'start condition' not solve problem. How I can reset chip in this case.
#st25dv04-nfc-i2c
回帖(2)
王立冕
2019-7-30 14:23:37
嗨弗拉基米尔,
我试着复制你的问题但是我没有成功,在等了很多时间与读者和i²c通信。
重置ST25DV的唯一方法是关闭电源(关闭VCC,取下阅读器或切断现场)。
 启动时的I²C超时仅复位I²C块而不是ST25DV。
您可以详细说明您的配置(电源,读卡器类型,断开通信时发送的命令,......)以便重现它。
最好的祝福。
以上来自于谷歌翻译
以下为原文
Hi Vladimir,
I tried to duplicate your problem but I did not succeed, after waiting a lot of time with a reader and i²c communication.
The only way to reset the ST25DV is by turning off the power (VCC off, and remove the reader or cut off the field).
The I²C timeout on Start only resets the I²C block and not the ST25DV.
Can you detail your configuration (power supply, reader type, commands send when it breaks communication, ...) in order to reproduce it.
Best Regards.
周颂焱
2019-7-30 14:37:10
嗨,
问题解决了!
我们使用ST25DV04(8引脚)代替M24LR04E。推荐M24LR04E硬件原理图
 AN4125(图10)
ST25DV04(ST25DV04
 数据表第22页
谢谢
以上来自于谷歌翻译
以下为原文
Hi,
Problem solved!
We use ST25DV04 (8 pin) on place of  M24LR04E. Recommendation  for M24LR04E hardware schematic in
AN4125 (Figure 10)     for
ST25DV04   (ST25DV04
  datasheet p.22
Thanks
