ST意法半导体
张玲玲
7年用户 127经验值
STEVAL-MKI109V2主板与LabView集成
嗨,
我的STEVAL-MKI109V2主板带有LSM9DS1惯性测量单元和STEVAL-MKI159V1适配器。 ST Microelectronics已经在提供该软件。但我想通过labview整合主板的输出。有人可以告诉我是否可以使用LabView作为此主板的采集软件而不是ST Microelectronics默认软件?
#inemo-M1
以上来自于谷歌翻译
以下为原文
Hi,
I have STEVAL-MKI109V2 motherboard with LSM9DS1 Inertial Measurement unit and STEVAL-MKI159V1 adaptor. ST Microelectronics is already giving the software. But I would like to integrate the output from the motherboard through LabView. Can someone please tell me whether it is possible to use LabView as acquisition software for this motherboard instead of ST Microelectronics default software?
#inemo-m1
曾玲娟
2019-5-30 09:44:26
请看看
https://my.st.com/resource/en/user_manual/cd00280880.pdf
 用于控制eMotion板的命令的STEVAL-MKI109V2。可以在LabView中实现通信协议,然后您可以从LabView项目控制板。
以上来自于谷歌翻译
以下为原文
Please look into the
for STEVAL-MKI109V2 for commands used to control the eMotion board.It is possible to implement the communication protocol in LabView and then you can control the boards from your LabView projects.
