ST意法半导体
乔飞
8年用户 153经验值
STEVAL-IHM039V1的JTAG编程无法通过OpenOCD连接到主板
你好!我正在使用STEVAL-IHM039V1和STEVAL-IHM027V1构建电机控制器。我收到了这些主板,为我的设置配置了固件(FOC SDK 3.4)和硬件设置(三分频pmsm w /霍尔传感器),并使用JTAG连接器,ARM-USB-tiNY-H编程器/调试器刷新代码和gdb / OpenOCD。 LCD接口工作等。
但是,一旦我刷了代码,我就再也无法通过OpenOCD连接到主板了。它说它无法检测到电路板。但是,如果我在连接时按住重置按钮,我可以连接到它并重新刷新它。这让我觉得固件中的某些引脚设置可能不正确,这会使JTAG不起作用。有任何想法吗?
以下是尝试连接的OpenOCD的输出:
#foc-sdk#f4xx#motor-control
以上来自于谷歌翻译
以下为原文
Hello! I'm building a motor controller using the STEVAL-IHM039V1 and the STEVAL-IHM027V1. I received these boards, configured the firmware (FOC SDK 3.4) and hardware settings for my setup (three-shunt pmsm w/ hall sensors), and flashed the code using the JTAG connector, an ARM-USB-TINY-H programmer/debugger, and gdb/OpenOCD. The LCD interface works and so on.
However, once I flashed the code, I can no longer connect to the board through OpenOCD. It says that it can't detect the board. However, I can connect to it and reflash it if I hold down the reset button while connecting. This makes me think that some pin setting might be incorrect in the firmware that somehow makes the JTAG not work. Any ideas?
Here is the output of OpenOCD trying to connect:
  • Open On-Chip Debugger 0.8.0 (2014-05-13-11:37) Licensed under GNU GPL v2 For bug reports, read http://openocd.sourceforge.net/doc/doxygen/bugs.html Info : only one transport option; autoselect 'jtag' adapter speed: 1000 kHz adapter_nsrst_delay: 100 jtag_ntrst_delay: 100 cortex_m reset_config sysresetreq Info : clock speed 1000 kHz Error: JTAG scan chain interrogation failed: all ones Error: Check JTAG interface, timings, target power, etc. Error: Trying to use configured scan chain anyway... Error: STM32f4x.cpu: IR capture error; saw 0x0f not 0x01 Warn : Bypassing JTAG setup events due to errors Warn : Invalid ACK 0x7 in JTAG-DP transaction
#foc-sdk #f4xx #motor-control
张秀兰
2019-5-14 09:50:41
Ciao martirosyan.hayk
 我可以假设,对于错误的配置,JTAG的某个引脚已重新映射为另一个功能。对于STEVAL-IHM039V1来说,这不是一个好消息。另一件事可能是错误的时钟设置。
 在这里发布您的工作台项目,以便我们检查。
 再见
 梁咏琪
以上来自于谷歌翻译
以下为原文
What I can suppose is that for a wrong configuration some pin of the JTAG has been remapped for another function. This is not usal for the STEVAL-IHM039V1. Another thing can be a wrong clock setting.
Post here your workbench project so we can check.
Ciao
Gigi
