Microchip
王桂芝
7年用户 277经验值
MPLAB X 3.61挂起在Linux上
你好,我打开MPLABX X 3.61。我用PIC18F27 K40启动了一个新项目(但它不仅仅是这个项目……)。我打开MCC(V.3.24.4)。我按下保存图标。系统挂起。我所能做的就是重启。我不能关闭程序,图标显示它被连续按下。我怀疑这是文件权限问题。tiA,史提夫
以上来自于百度翻译
      以下为原文
    Hi,
I open MPLAB_X 3.61.  I start a new project with a PIC18F27K40 (but it isn't just this project...).  I open the MCC (v.3.26.4).  I press the save icon.
The system hangs.
All I can do is reboot.  I can't close the program, the icon shows it is pressed continuously.
I suspect it is a file permissions issue somewhere...
TIA,
Steve
回帖(17)
周菊
2019-3-21 12:12:15
所以我卸载了3.61,然后卸载了以前的版本3.60。然后我重新安装3.60.1,它似乎没有冻结在第一个实例。然后我通过下拉菜单安装了代码配置器3.24.4,因为它建议。现在我再次陷入僵局。我已经加载了一个项目,并按下代码配置按钮。它只是悬挂着。
以上来自于百度翻译
      以下为原文
    So I've uninstalled 3.61 then uninstalled the previous version 3.60 also.  Then I re-installed 3.60.
It seemed to not freeze in the first instance at least.
Then I installed through the drop-down menu the Code Configurator 3.26.4 as it suggested.
Now I am stalled again.
I have loaded a project and pressed the Code COnfigurator button.  It is just hanging.
杨玲
2019-3-21 12:23:24
KIALL - 9 JAVA从命令行将杀死它,所以你不必重新启动。我使用3.61,在Linux上没有问题,但我不使用MCC。
以上来自于百度翻译
      以下为原文
    killall -9 java
from the command line will kill it so you don't have to reboot.
I'm using 3.61 with no issues on Linux, but I don't use MCC.
周菊
2019-3-21 12:28:49
谢谢。谢谢你的回复,看起来好像是MCC相关的。我刚刚打开了MPLABX X 3.60的旧项目,使用老的芯片,我可以改变一些简单的东西,比如振荡器设置,按下“生成”,然后“保存”。在MpLabx 3.60的新PIC18F27 K40上用MCC 3.23.4尝试它,在我移动鼠标之前它就被破解了!(看来……)MCC似乎是很难实现的,但我认为这是一个很好的概念。我想回到MPLABX X 3.61,但没有什么意义,因为它们都使用最新的MCC。
以上来自于百度翻译
      以下为原文
    Thanks.  I appreciate your reply.
It looks as though it is MCC related.  I have just now been opening older projects on MPLAB_X 3.60 and using older chips and I can change something simple like the oscillator settings, press 'generate' and also then 'save'.
Trying it on the newer PIC18F27K40 with MPLAB_X 3.60 with MCC 3.26.4 and it is broken before I move the mouse! (so it seems ...)
The MCC is proving to be something difficult to implement it seems to me but I think it is a very good concept.
I'd like to move back to MPLAB_X 3.61 but there isn't much point as they are both using the latest MCC.
周菊
2019-3-21 12:35:23
好的,自从上一篇文章以来,我已经卸载了所有以前的和不活动的MPLAB版本。我还重新加载或安装了Java相关的任何东西,并且在最新的Linux MINT(2017年5月)上的所有包上都是最新的。我已经尝试再次运行MPLAB 3.61。我看到的是,当你开始一个新的项目并且在你做任何事情之前,你需要按下“生成”按钮。这样做会给你一个弹出窗口来确认项目文件和你的一代结果的文件名。如果你按下“保存”按钮,情况就不是这样了。如果按下“保存”按钮,你得到的是一个挂起的系统。当然还有更多的东西,当然还有其他人看到了吗??
以上来自于百度翻译
      以下为原文
    OK.
Since the last post I have uninstalled all previous and inactive MPLAB versions.  I have also re-loaded or installed anything java related and am up-to-date on all packages on the latest Linux Mint (May 2017).
I have tried to run MPLAB 3.61 again.
What I see is that when you start a new project and before you do anything you need to press the 'generate' button.  Doing this gets you a pop-up window to confirm the project file and filename for the results of your generation.
This is not the case if you press the 'save' button instead.  What you get if you press the 'save' button is a hung system.
Fairly simple problem ... surely there is more to it and surely someone else has seen this ??
