我在Windows 10机器上安装了X IDE 3.61。(唯一值得注意的改进是,现在启动大约4分钟,这给了我更多的时间来喝啤酒)。在为PIC18F26K22创建一个简单的XC8程序之后,我提出了MCC来配置CCP5和TMR2。事情一直持续到我退出IDE。IDE挂起后,我回答“是”,“你想保存MPLAB代码配置器?”今天早上我开始工作,在我的WI7机器上尝试了同样的东西。在我离开工作之前,我已经安装了3.61IDE。我也有同样的问题。除非我挖掘出旧的汇编手册,否则我找不到解决办法。任何想法都可以理解为:FLIZZY产品版本:MPLAB X IDE V3.61Java:1.80Y121;Java热点(TM)64位服务器VM 25.121-B13Run
time:Java(TM)SE运行时环境1.80Y121-B13Stase:Windows 7版本6.1,运行在AMD64;CP1252;CP1252EnnUS(MPLAB)MCC 3.24.4
以上来自于百度翻译
以下为原文
I installed X IDE 3.61 on a Windows 10 machine. (the only noticeable improvement is that it now takes about 4 minutes to start up which gives me more time to drink beer).
After creating a simple XC8 program for the PIC18F26K22 I brought up MCC to configure CCP5 and TMR2. Things worked until I tried to exit the IDE. The IDE hung after I responded "yes" to the "Do you want to save MPLAB Code Configurator?".
I got into work this morning and tried the same thing on my WIN7 machine. I had installed 3.6.1 IDE on it before I left work last. I am having the same problem. I cannot find a workaround unless I dig out my old assembler manuals.
Any ideas appreciated-
Fritz
Product Version: MPLAB X IDE v3.61
Java: 1.8.0_121; Java HotSpot(TM) 64-Bit Server VM 25.121-b13
Runtime: Java(TM) SE Runtime Environment 1.8.0_121-b13
System: Windows 7 version 6.1 running on amd64; Cp1252; en_US (mplab)
MCC 3.26.4
