ST意法半导体
陈枫希
7年用户 201经验值
主板不支持MKI172V1
我有一个MKI72V1适配器板。在Unico with V5上,它确实出现在设备列表中,但是当我选择设备时,我收到一条错误消息,指出设备不受主板支持。请指教。
#mki172v1#lsm303agr
以上来自于谷歌翻译
以下为原文
I have a MKI72V1 adapter board. On Unico with V5 it does show up on the devices list however when I select the device I get an error message saying the device is not supported by the motherboard. Please advise.
#mki172v1 #lsm303agr
回帖(4)
曾玲娟
2019-3-11 16:47:44
可以请更新电路板中的固件。您需要与Unico v5.0.0一起在STSW-MKI109W中分发的固件。
有关如何更新FW的说明,请查看目录DFU和UM0412 - DFU用户指南.pdf。
以上来自于谷歌翻译
以下为原文
Can you please update the firmware in your board. You need the firmware which is distributed in the STSW-MKI109W together with the Unico v5.0.0.
Please check the directory DFU and the UM0412 - DFU User Guide.pdf for instruction how to update the FW.
陈枫希
2019-3-11 16:57:04
您好,感谢您的回复。我检查了DFU文件夹,它包含eMotionV5.0.0.dfu文件。但是,使用此文件更新FW后,仍然会导致相同的错误。
以上来自于谷歌翻译
以下为原文
Hello and thanks for your response. I checked the DFU folder and it contained the eMotionV5.0.0.dfu file. However After updating FW using this file it still results in the same error.
曾玲娟
2019-3-11 17:05:02
是的,eMotionV5.0.0.dfu是正确的文件。您确定FW升级是否正确完成。你看到Unico的固件版本现在是5.0.0吗?
以上来自于谷歌翻译
以下为原文
Yes, the eMotionV5.0.0.dfu is the correct file. Are you sure that the FW upgrade was done correctly. Do you see that the firmware version is now 5.0.0 in Unico?
陈枫希
2019-3-11 17:16:29
是的它现在正在工作......谢谢
以上来自于谷歌翻译
以下为原文
Yes it's working now... thank you
