可以创建任何类型的文件,这完全取决于如何将数据写入文件。这取决于你。SD卡并没有真正进入它。如果你要写一个Excel文件的例子,那就不同了。什么是Excel文件?XLS?XLSX?CSV?你为什么要用它?哪些文件格式特性对你很重要?(你不能用TXT做什么)
以上来自于百度翻译
以下为原文
It is possible to create any type of file, it all depends on how you write the data to the file. This is up to you. The SD card doesn't really enter into it. If you are asking for an
example of writing an Excel file then that is different.
What is an Excel File for you ? xls ? xlsx ? csv ?
Why do you need to use it ?
Which of the file format features are important for you ? (what you can't do with .txt )
以上来自于百度翻译
以下为原文
