是德科技
丁兵溢
7年用户 179经验值
安捷伦是否可以提供O/S升级包?
自微软宣布“2014年4月8日起,Windows XP的支持和更新将不再可用”。
安捷伦表示他们将支持XP O / S,直到2015年3月1日 - 安捷伦对所有无数测试仪器(如EXA,MXA和其他使用XP的测试仪器)的建议是什么?
安捷伦是否可以提供O / S升级包?
应该自己制定计划转移到Windows 7还是现在就坐好不过担心?
评论 - 建议?
史蒂夫
以上来自于谷歌翻译
     以下为原文
  Since Microsoft has declared that "On April 8, 2014, support and updates for Windows XP will no longer be available." and Agilent says they will support the XP O/S until March 1, 2015 - what is Agilent recommendations for all the myriad of test instruments such as the EXA, MXA and others that use XP? Will there be a O/S upgrade package available through Agilent? Should be go make plans to move to Windows 7 on our own or just sit tight for now and not worry?
Comments - recommendations?
Steve
张英
2019-1-18 14:02:43
与安捷伦交谈时,任何接近支持终止的过时或停产产品都不会获得系统升级。
这并不意味着没有支持。
它就像PC支持一样。
基于Windows的仪器在操作系统中遇到的最大障碍是当最终用户将其用作PC并开始进行网络搜索,游戏和下载s / w时,这将使仪器像任何PC一样容易受到攻击。
您可以安装最新的S / W程序来保护它,但需要不断更新这些程序。
如果最终用户只是按原样使用仪器,并使用以太网端口进行数据传输和远程控制,那么您应该遇到的问题非常少。
我们支持仍然具有Win95,Win98,Win2000Pro,WinXP的传统产品。
新产品将根据产品寿命获得更新,并接受新平台的稳定性。
戴夫
以上来自于谷歌翻译
     以下为原文
  When speaking with Agilent, any obsolete or discontinued products that is close to end of support will not acquire a systems upgrade.   That does not mean support is not available.  It is just like PC support.   The biggest obstacle the the Windows based instruments have in the operating system is when end users use it as a PC and start doing web searches, game playing and downloading s/w which will make the instrument vulnerable as any PC.  You can install the latest S/W programs to protect it but requires constant updates of those programs.
If the end user simply uses the instrument as it was meant to be, and use the Ethernet port to data transmission and remote control you should have very little problems.
We support legacy products that still have Win95, Win98, Win2000Pro, WinXP.
The newer products will get updates based on product life and acceptance the new platforms for stability.
Dave
