你好,
我目前正致力于:
- ISE13.4 - 浮动许可证,连接到服务器
- ML605
所以我使用ISE / XPS / SDK三重奏...当我在SDK中,并在ML605中为Microblaze编写代码,并连接ML605时,它工作正常......直到ML605循环上电
然后....当试图将位文件下载到ML605时挂起SDK ....然后在我必须使用任务管理器关闭SDK并重新打开后许可证被锁定...所以我什么都做不了
......直到我让IT人员来清除许可证
为什么会发生以下情况:
- 为什么SDK处理目标板的
电源周期很差?
似乎USB-JTAG之后都搞砸了......难道不应该只是承认另一次重新连接吗?
荒谬的......
- 我如何自己清理许可证?
所有这一切的解决方法是什么?
如果可以,请帮助......我的IT支持很糟糕。
谢谢,
-Peter
以上来自于谷歌翻译
以下为原文
Hello,
I am currently working on/with:
- ISE13.4 - FLOA
tiNG LICENSE, connected to server
- ML605
So I use the ISE/XPS/SDK trio...when I am in the SDK, and writing code for a Microblaze in the ML605, and connect up the ML605, it works fine...UNTIL I CYCLE THE POWER ON THE ML605. THEN....it hang up SDK when trying to download the bit file to the ML605....then the license is LOCKED after I have to use task manager to close SDK and reopen...so I can't do anything...until I get IT here to clear the license..
WHY does the following happen:
- Why does SDK handle the power cycle so poorly of the target boards? seems like the USB-JTAG is all messed up after...shouldn't it just acknowledge another reconnection? rediculous...
- How can I cleanr the license myself?
What is the fix around all of this?
Please help if you can...my IT support is horrible.
Thanks,
-Peter
