Cypress技术论坛
甘蔼宾
7年用户 162经验值
I2S如何填充到样本数据
你好,
我有下面的代码片段,用于初始化来自Id2s的D2HTP://wwwyCysP.com /Fiel/13461/1下载页面196。
*配置I2S接口。*/
CYU3PMESET((UIT88T**)和;I2SCFG,0,SIZEOF(I2SCFG));
I2SCFG.ISMONOO=CyFrE;
I2SCFG.ILSBB1=CyFrE;
I2SCFG.ISDMA=Cyress;
I2SCFG.PADMODE=CYU-U3PII2S1PADYMO正常;
I2SCFG.SAMPLERATE=CYU-U3PII2SYSAMPPLYRATER 44×1KHz;
I2SCFG采样宽度=CyuU3pII2sWithth1616BIT;
状态= CYU3PI2SSETCONFIG(和;I2SCFG,NULL);
如果PAD模式是正常的,那么在32位样本数据中,LSB应该用零填充。
在上面的示例代码中,它将I2S配置为PAD模式正常,样本宽度为16位。它创建的DMA是自动DMA(第196页,第8章,第8节,第4.13页)。如果它的自动DMA模式,零如何填充到样本数据?
2)汽车DMA是否存在缓冲区溢出现象?如果发生,请给我一个处理I2S自动DMA缓冲区欠载的例子代码。
以上来自于百度翻译
     以下为原文
  Hi,
I have got following code snippet for initialising I2S with DMA from http://www.cypress.com/file/134661/download   page no 196.
  /* Configure the I2S interface. */
  CyU3PMemSet ((uint8_t *)&i2sCfg, 0, sizeof (i2sCfg));
  i2sCfg.isMono = CyFalse;
  i2sCfg.isL***First = CyFalse;
  i2sCfg.isDma = CyTrue;
  i2sCfg.padMode = CY_U3P_I2S_PAD_MODE_NORMAL;
  i2sCfg.sampleRate = CY_U3P_I2S_SAMPLE_RATE_44_1KHz;
  i2sCfg.sampleWidth = CY_U3P_I2S_WIDTH_16_BIT;
  status = CyU3PI2sSetConfig (&i2sCfg, NULL);
It is mentioned that if the pad mode is NORMAL, then in the 32 bit sample data, its LSB shall be padded with zeroes.
In the above example code, it configures the I2S as PAD MODE NORMAL and sample width is 16 bit. The DMA it creates is auto DMA (Page no 196, sec 8.8.4.13). If its auto DMA mode, how does the zeroes get padded to the sample data?
2) Can buffer underrun occur for Auto DMA? If it occurs, can you please give me example code which handles the buffer underrun for I2S Auto DMA?
刘辉
2018-11-15 16:09:19
你好,
1)期望垫零。但这一特性尚未在内部进行测试。请继续执行,如果有任何问题,请告诉我们。
2)如果发生,请调用CYU3PDMACHANNELRESET,刷新并重置CONCHRONED ENF点。
当做,
- Madhu Sudhan
以上来自于百度翻译
     以下为原文
  Hi,
1) It is expected to pad zeros. But this feature has not been tested internally. Please go ahead with the implementation and let us know, if you face any issue.
2) If it occurs, please call, CyU3PDmaChannelReset, and flush and reset the corresonding enf point.
Regards,
- Madhu Sudhan
