您好,感谢您加入英特尔社区。为了更好地帮助您,我想收集有关您在计算机中配置的更多信息。
请在.txt文件中附上.txt文件,英特尔®系统支持实用程序将生成https://downloadcenter.intel.com/download/25293/Intel-System-Support-UtilityHas英特尔®虚拟化技术以前工作正常吗?您是否尝试过启用
Hyper-V看看它是否正常工作?要附加文件,必须单击响应框右上角的“使用高级编辑器”,然后“附加”选项将出现在右下角
响应框.Regards,Fred D.
以上来自于谷歌翻译
以下为原文
Hello
pleung,
Thank you for joining the Intel Communities.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate
Has Intel® Virtualization Technology worked fine before?
Have you tried enabling Hyper-V to see if it works fine?
To attach a file, you must click “Use Advanced Editor” on the upper right hand corner of the response box, then the “attach” option will appear on the bottom right hand corner of the response box.
Regards,
Fred D.
响应框.Regards,Fred D.
以上来自于谷歌翻译
以下为原文
Hello
pleung,
Regards,
Fred D.
