您好HaroldC,感谢您联系英特尔技术支持。要回答您的问题,请查看“英特尔®Optane™内存常见问题”和“有关英特尔®Optane™安装和配置的常见问题解答”中包含的信息
记忆“下面:1。
用于系统加速的英特尔®Optane™内存系列的软件和硬件要求的完整列表是什么?您正在加速的SATA启动驱动器必须包含:•GPT分区•512B扇区格式•Windows®1064位操作系统
启动卷末尾至少有5 MB的连续未分配空间注意•系统加速不支持PCIe * NVMe *驱动器•仅使用软件版本16.0.2.1086或更高版本支持系统加速的辅助/数据驱动器。
有关详细信息,请参阅此处。•系统加速不支持具有多个操作系统的单个SATA驱动器。
我们不建议使用此功能,但我们不保证结果。
请参阅“用户和安装指南”中的完整要求。•双OS引导系统 - 具有多个存储驱动器的系统,每个系统包含一个操作系统 - 不受支持,并且无法保证结果。
我是否可以在包含多个卷的SATA驱动器上启用系统加速(例如,启动卷和数据卷)?支持包含一个启动分区/卷以及数据分区/卷的SATA驱动器的系统加速。
具有多个引导分区/卷的SATA驱动器不是受支持的配置或用例。
结果无法保证,我们不建议配置。
我打算在我的系统上跨多个驱动器使用多个操作系统。
英特尔®Optane™内存能否提升多个硬盘的性能?•不,英特尔®Optane™内存可以加速一个基于SATA的硬盘。我们希望您发现这些信息非常有用。最好的问候,Josh B.Intel客户支持技术人员与英特尔的合同
公司
以上来自于谷歌翻译
以下为原文
Hello HaroldC,
Thank you for contacting Intel Technical Support.
To answer to your questions, please find the information included on the “Frequently Asked Questions for Intel® Optane™ Memory” and the “Frequently Asked Questions about Installation and Configuration for Intel® Optane™ Memory” below:
1. What is the complete list of software and hardware requirements for the Intel® Optane™ memory series for system acceleration?
The SATA boot drive you're accelerating must contain:
• GPT partition
• 512B Sector format
• Windows® 10 64-bit operating system with at least 5 MB of continuous unallocated space at the end of the boot volume
Note
• PCIe* NVMe* drives aren't supported for system acceleration
• Secondary/Data drives are supported for system acceleration with software version 16.0.2.1086 or later only. For more information, see here.
• A single SATA drive with multiple operating systems isn't supported with system acceleration. We don't recommend this use, and we don't guarantee results. See the full requirements in the User and Installation Guide.
• Dual OS Boot systems--systems with more than one storage drive, each containing an OS--aren't supported and results can't be guaranteed.
2. Can I enable system acceleration on my SATA drive that contains more than one volume (for example, a boot volume and a data volume)?
System acceleration of a SATA drive that contains one boot partition/volume and also data partitions/volumes is supported.
A SATA drive with multiple boot partitions/volumes isn't a supported configuration or use case. Results can't be guaranteed and we don't recommend the configuration.
3. I intend to have multiple operating systems on my system across multiple drives. Can Intel® Optane™ memory boost the performance of multiple drives?
• No, Intel® Optane™ memory can accelerate one SATA-based drive.
We hope you find this information useful.
Best regards,
Josh B.
Intel Customer Support Technician
Under Contract to Intel Corporation
记忆“下面:1。
结果无法保证,我们不建议配置。
公司
以上来自于谷歌翻译
以下为原文
Hello HaroldC,
• GPT partition
Note
Best regards,
Josh B.
