英特尔
康选谦
8年用户 228经验值
不支持的系统驱动器错误
我的speci5 8600k
asrock z370极端3
wd blue 2tb -gpt(我要加速的驱动器)
samsung 270 evo nvme m.2 -gpt(启动不支持的系统驱动器错误驱动器)
CSM禁用
RST已启用
重新安装后我得到了这个错误
90.8 K.
210.6 K.
128.9 K.
以上来自于谷歌翻译
以下为原文
my spec
i5 8600k
asrock z370 extreme 3
wd blue 2tb -gpt (drive that i want to accelerate)
samsung 270 evo nvme m.2 -gpt (boot drive)
CSM disabled
RST enabled
after reinstall i got this error
回帖(2)
汤宇
2018-10-15 11:45:15
您好xbreaker316,感谢您在英特尔®社区发布。从磁盘管理屏幕截图看,您的启动驱动器实际上是蓝色驱动器,而三星驱动器只是一个带有单个C:分区的辅助驱动器。启动驱动器
除了主屏幕之外还应该有其他分区,就像屏幕截图中的磁盘0一样。请确认哪个驱动器确实是启动驱动器,因为我们可能会有困惑。另一方面,请下载英特尔®
系统支持实用程序(SSU)来自以下站点并运行完整报告以收集您的系统信息?
该工具可以从以下站点下载:https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-。
请在回复中附上报告文件。还请截取以下信息的屏幕截图:
以管理员身份打开命令提示符。
运行命令diskpart。
运行命令列表磁盘。
请截取输出的截图并将其包含在您的回复中。我将等待您的回复。祝您有个美好的一天。感谢,Diego V.
以上来自于谷歌翻译
以下为原文
Hi xbreaker316,
Thank you for posting in the Intel® communities.
From the Disk Management screenshot, it looks like your booting drive is actually the wd blue drive while the Samsung drive is just a secondary drive with a single C: partition.
The boot drive should have other partitions besides the main one, just as it appears for the Disk 0 in the screenshot.
Please confirm which drive is indeed the boot drive because we may have a confusion here.
On the other hand, could you please download the Intel® System Support Utility (SSU) from the following site and run the full report to collect your system information? The tool can be downloaded from this site: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-. Please attach the report file in your response.
Please also take a screenshot of the following information:
  • Open your Command Prompt as Administrator.
  • Run the command diskpart.
  • Run the command list disk. Please take a screenshot of the output and include it in your response too.
I’ll be waiting for your response.
Have a nice day.
Regards,
Diego V.
李玉鑫
2018-10-15 12:00:08
我重新安装窗口,然后我遇到了新的错误
我想我在970 evo上安装了窗口,所以我重新安装但是仍然有相同的分区设置
为了您的要求
report.txt.zip
5.4 K.
以上来自于谷歌翻译
以下为原文
I reinstall window then I got new error
I think I install window on 970 evo, so I reinstall but I still got same partition setting
for your request
