ST意法半导体
刘溪
7年用户 192经验值
使用UDE怎么更改GPDI寄存器值
各位早上好,
我对通用调试器有一点问题。
在我在发现板上的测试应用程序中,我设置了输入寄存器的读数
SIUL.GPDI48.B.PDI。
现在,阅读手册,我理解通过调试器可以更改寄存器的值。
我尝试了指南所说的内容。在SFR视图中,我选择了寄存器并尝试更改值,但没有结果。
寄存器不受保护。如果我尝试将寄存器的值更改为例如STM寄存器,我就成功了。
有人知道为什么会这样吗?
谢谢,
伊万
#UDE调试器输入寄存器
以上来自于谷歌翻译
以下为原文
Good morning to everyone,
I have a little problem with the universal debugger.
In my testing application on the discovery board, I set the reading of a input register
SIUL.GPDI48.B.PDI.
Now, reading the manual, I understand that is possible, via debugger, change the value of the registers.
i tried what the guide tells. In the SFR view, I selected the register and tried to change is value, but with no result.
The register is not protected. If I try to change the value of register as the STM register for exampple, I succed.
Someone has some idea on why it is the case?
Thank you,
Ivan
#ude-debugger-input-registers
回帖(2)
刘鑫
2018-11-1 14:30:32
你好伊万,
GPIO焊盘数据输入寄存器(GPDI)
这些寄存器可用于通过字节访问来填充数据。
你不能写
 最好的祝福
 二万
以上来自于谷歌翻译
以下为原文
Hello Ivan ,
GPIO Pad Data Input Registers (GPDI)
These registers can be used to  pad data with a byte access.
you can not write
  • * @brief   Reads a logical state from an I/O pad.
  • * @note    The @ref PAL provides a default software implementation of this
  • *          functionality, implement this function if can optimize it by using
  • *          special hardware functionalities or special coding.
  • * @param[in] port      port identifier
  • * @param[in] pad       pad number within the port
  • * @return              The logical state.
  • * @retval PAL_LOW      low logical state.
  • * @retval PAL_HIGH     high logical state.
  • * @notapi
  • #define pal_lld_readpad(port, pad)
  • (SIU.GPDI[((port) * 16) + (pad)].R)
  Best regards
            Erwan
刘溪
2018-11-1 14:43:52
你好,Erwan,
谢谢你的建议。
问候,
 伊万
以上来自于谷歌翻译
以下为原文
Hello Erwan,
thank you for the advice.
Regards,
Ivan
