英特尔
刘芳
7年用户 1260经验值
Lenovo ideapad 320S-14IKB是否支持Intel optane内存模块?
我的笔记本电脑Lenovo ideapad 320S-14IKB(81BN型)是否支持Intel optane内存模块?
它有M.2 M键类型的ssd端口。
以上来自于谷歌翻译
以下为原文
Does my laptop Lenovo ideapad  320S-14IKB (Type 81BN)  supports Intel optane memory module? It is having M.2 M key type ssd port.
回帖(2)
汤宇
2018-10-23 11:05:38
嗨fstream,感谢您在英特尔®社区发帖。我们知道您想知道英特尔®Optane™内存是否适用于您的笔记本电脑。我想告诉您,特定笔记本电脑型号与英特尔的兼容性
®Optane™内存,建议联系制造商并与他们确认模块的支持。
即使您有可用的M.2插槽,但这并不意味着英特尔®Optane™内存可以正常工作。
还有其他细节,如处理器,主板的芯片组或BIOS版本,模块才能正常工作。
处理台式计算机时有时会提供此信息,但在处理笔记本电脑时,通常无法获得此信息。
这就是为什么我们建议联系制造商。但是,在对这款笔记本电脑型号进行一些研究后,我在联想*网站上找到了一个线程,其他用户试图安装英特尔®Optane™内存但没有成功。
显然他得到了一个不支持的BIOS错误,这意味着BIOS不支持该模块。
根据这些信息,我会说您的笔记本电脑与Intel®Optane™内存不兼容。
您可以在以下链接中查看此用户在Lenovo *站点中发布的内容:https://forums.lenovo.com/t5/Lenovo-IdeaPad-1xx-3xx-5xx-7xx/Ideapad-320S-14lkb-80x4-installation
-of-Intel-Optane-16GB / td-p / 3794653我希望您发现此信息有用。
如果还有什么我可以帮助你,请告诉我。祝你有个美好的一天。感谢,迭戈V.
以上来自于谷歌翻译
以下为原文
Hi fstream,
Thank you for posting in the Intel® communities.
I understand that you would like to know if the Intel® Optane™ Memory works with your laptop.
I’d like to let you know that for specific laptop models compatibilities with the Intel® Optane™ Memory, it is recommendable to contact the manufacturer and confirm with them the support of the module. Even though you have an M.2 slot available, it doesn’t mean the Intel® Optane™ Memory will work. There are other details like the processor, the motherboard’s chipset or BIOS version that will be required for the module to work properly. This information is sometimes available when dealing with Desktop computers, but when dealing with laptops, this information is usually not available. That’s why we recommend to contact the manufacturer.
However, after doing some research about this laptop model, I found a thread in the Lenovo* site where another user tried to install the Intel® Optane™ Memory with no success. Apparently he got an unsupported BIOS error which means the BIOS doesn’t support the module. Based on that information, I’d say that your laptop is not compatible with the Intel® Optane™ Memory. You can check in the following link what this user posted in the Lenovo* site: https://forums.lenovo.com/t5/Lenovo-IdeaPad-1xx-3xx-5xx-7xx/Ideapad-320S-14lkb-80x4-installation-of-Intel-Optane-16GB/td-p/3794653
I hope you find this information useful. If there is anything else I can help you with, let me know.
Have a nice day.
Regards,
Diego V.
李玉鑫
2018-10-23 11:11:47
嗨fstream,我想知道是否还有其他任何我可以帮助你的英特尔®Optane™内存,或者如果我上面发布的信息回答你的问题。祝你有个美好的一天.Regards,Diego V.
以上来自于谷歌翻译
以下为原文
Hi fstream,
I was wondering if there is anything else I can help you with regarding to the Intel® Optane™ Memory, or if the information I posted above answered your concern.
Have a nice day.
Regards,
Diego V.
