英伟达
冯虎虔
7年用户 169经验值
无法从370.17发行版安装vGPU VM来宾操作系统Windows Server 2012R2驱动程序
嗨!
已将ESXI 6.0.0-20170202001上的主机驱动程序更新为版本367.123。
Xorg服务已启动并正在运行,nVidia SMI正常报告。
重新启动主机。
当我尝试更新VM中的驱动程序,其中客户操作系统是Windows Server 2012R2,从之前的版本362.13到370.17附带v 367.123 ESXI主机驱动程序,我从安装程序收到错误消息“此NVIDIA图形驱动程序与
这个版本的Windows。图形驱动程序找不到兼容的图形硬件。“
Windows设备管理器在Nvidia Grid K160Q设备下显示错误代码43。
Horizo​​n Server版本是7.1.0 build 5170113.以前使用361.40 ESXi主机驱动程序和362.13客户机操作系统驱动程序一切正常。
除主机驱动程序外没有任何更改。
我错过了什么以及如何解决这个问题?
以上来自于谷歌翻译
以下为原文
Hi!
Have updated the host driver on ESXI 6.0.0-20170202001 to version 367.123. Xorg service is up and running, nVidia SMI reports properly. Rebooted the host.
When I try to update the driver in a VM where guest OS which is Windows Server 2012R2 from a previous version 362.13 to 370.17 which came with v 367.123 ESXI host driver I get an error message from the installer "This NVIDIA graphics driver is not compatible with this version of Windows. The graphics driver could not find compatible graphics hardware.". Windows device manager shows Error Code 43 under the Nvidia Grid K160Q device.
The Horizon Server version is 7.1.0 build 5170113. Previously with 361.40 ESXi host driver and 362.13 guest OS driver everything worked fine. Nothing except for the host driver has changed.
What am I missing and how to resolve the issue?
王琳
2018-9-13 17:20:49
试图安装包中的每个驱动程序,发现367.123捆绑包中的“370.17_grid_win8_win7_32bit_international”命名驱动程序在Windows Server 2012R2 x64上正确安装,这很奇怪,但谁在乎它是否有效。
以上来自于谷歌翻译
以下为原文
Tried to install every driver from the pack and found out that "370.17_grid_win8_win7_32bit_international" named driver from the 367.123 bundle installs correctly on Windows Server 2012R2 x64 which is odd, but who cares if it works.
