你好,
我们正在为少量远程桌面会话主机服务器规划硬件(6-8 RDSH w.Server 2012 R2,2016年晚些时候。办公室工作负载.RemoteFX):
1.)裸金属w。
Quadro M4000或P4000
2.)通过离散设备分配(DDA,每个RDSH 1GPU),使用Server 2016 Hyper-V主机和Tesla M10直通进行虚拟化。
为了评估第二种情况,我们使用旧的K1卡设置了Server 2016主机并安装了一些VM:
a。)Server 2016(德语)
- > DDA正在运作。
- >可以安装驱动程序(Server 2016,R367(370.16))
=> GPU用于远程桌面会话。
b。)Server 2012 R2(德语)
*修补程序KB3133690由Windows更新安装
- > DDA正在运作。
- >驱动程序安装工作(Server 2012 R2,R367(370.16))
=>重新启动后,VM挂起。
“点圈”仍然没问题。
之后屏幕颜色切换为黑暗,几秒钟后变为深蓝色。
然后没有反应。
移除DDA-GPU后,VM将启动。
c。)Windows 8.1(德语)
=>与Server 2012 R2相同的行为
根据:
http://docs.nvidia.com/grid/4.4/grid-vgpu-release-notes-microsoft-windows-server/index.html
这应该工作:
*测试硬件是经过验证的服务器硬件平台。
* Server 2016 Hyper-V
* Windows Server 2012 R2 w。
KB3133690支持来宾操作系统
有没有人提示将Server 2012 R2用作访客?
此致,赫尔穆特
以上来自于谷歌翻译
以下为原文
Hello,
we're planning the hardware for a small number of Remote Desktop Session Host-Servers (6-8 RDSH w. Server 2012 R2, later 2016. Office workloads. RemoteFX):
1.) Bare metal w. Quadro M4000 or P4000
2.) Virtualized with Server 2016 Hyper-V Hosts and Tesla M10 passthrough via Discrete Device Assignment (DDA, 1GPU per RDSH).
For evalua
ting the second scenario we set up a Server 2016 Host with an older K1 Card and installed some VMs:
a.) Server 2016 (German)
-> DDA is working.
-> Driver can be installed (Server 2016, R367 (370.16))
=> The GPU is used in Remote Desktop sessions.
b.) Server 2012 R2 (German)
* Patch KB3133690 is installed by Windows Updates
-> DDA is working.
-> Driver Installation works (Server 2012 R2, R367 (370.16))
=> After reboot the VM hangs. "Point circling" is still okay. After that the screen color is switching do dark und some seconds later to dark blue. Then no reaction. After removing the DDA-GPU the VM boots up.
c.) Windows 8.1 (German)
=> same behavior as Server 2012 R2
According to:
this should work:
* The test hardware is a validated server hardware platform.
* Windows Server 2012 R2 w. KB3133690 is supported guest OS
Does anyone has a hint for using Server 2012 R2 as a guest?
Regards, Helmut
