英伟达
任青
7年用户 182经验值
将网格服务器添加到现有池
我目前有一个xenserver池,在4台服务器上运行大约500个xendesktops。
我购买了一台带有2x k1网格的额外服务器,我想将它添加到池中。
我将创建一个cad系统目录,我将分配给该服务器,并允许我的传统系统在此服务器上根据需要启动。
当我将它添加到我的池中时,我丢失了服务器上的GPU选项卡。
这不可能吗?
我还希望使用与其余池相同的共享存储。
Ps的xenservers都是6.2 sp1而xd是5.5f1 ....(很快就会是7.6)
以上来自于谷歌翻译
以下为原文
I currently have a xenserver pool with approx 500 xendesktops running on 4 servers.  I purchased an additional server with 2x k1 grids and I would like to add it to the pool.  I would create a catalog of cad systems that I would assign to this server and allow my traditional systems to launch as needed on this server.  When I add this to my pool, i lose the GPU tab on the server.  Is this not possible?  I would also like the benefit of using the same shared storage as the rest pool.
Ps the xenservers are all 6.2 sp1 and the xd is 5.5f1....(soon to be 7.6)
回帖(6)
李林
2018-9-5 09:41:21
您是否修补了XenServer和GRID支持特别需要的所有必需的修补程序?
这是什么型号的服务器 - 戴尔,Supermicro等 - 并且已经存在所有BIOS /固件存储器?
它与您的第一台服务器型号相同吗?
服务器是否与池中的NTP正确同步?
您是否看到使用nvidia-smi报告的K1以及GPU在什么时候从XenCenter中消失(您是否正在运行新版本的XenCenter)?
以上来自于谷歌翻译
以下为原文
Are you patched with all the necessary hotfixes for both XenServer and any ones specifically needed for GRID support? What model server is this -- a Dell,Supermicro, etc. -- and dies it have all the BIOS/firmware patrches in place? Is it the same model as your first server?  Are the servers properly synchronized to NTP in the pool? Do you see the K1s reported with nvidia-smi and at what point does the GPU disappear from XenCenter (are you running a new enough release of XenCenter)?
孙婷
2018-9-5 09:54:55
它是一个戴尔720,所以池服务器一切都完全打补丁。
在游泳池外面它显示了gpu ......当我将它添加到游泳池时它就没有了。
其余池服务器是nongrid。
只是想知道它是否可以这样工作。
(非网格服务器池中的单个网格)
以上来自于谷歌翻译
以下为原文
Its a dell 720 and so are the pool servers everything is fully patched.  Outside of the pool it shows the gpu... It just doesnt when I add it to the pool.  The rest of the pool servers are nongrid.  Just wondering if it can work that way. ( a single grid in a pool of non grid servers)
钱杨静
2018-9-5 10:00:45
啊,我明白了 - 这是因为确实硬件不同而且池期望配置在所有服务器之间是统一的。
坦率地说,我认为你不想像这样经营一个游泳池。
XenServer池需要具有高度通用的硬件才能正常运行。
您是否有特殊原因想要将主机分开?
以上来自于谷歌翻译
以下为原文
Ah, I see -- it's because indeed the hardware is different and the pool expects the configuration to be uniform among all the servers.  Frankly, I don't think you'd want to run a pool like that. XenServer pools need to have a high degree of common hardware to be able to function properly. Is there a specific reason you do not want to keep the hosts separate?
孙榕
2018-9-5 10:10:18
我打算使用服务器来允许我们当前的一些池化XD使用该资源。
如果我不能,那没什么大不了的。
我实际上遇到了另一个问题,虽然是独立的。
我将很快讨论一个新线程来解决它。
以上来自于谷歌翻译
以下为原文
I was planning on using the server to allow some of our current pooled XD use the resource.  Not a big deal if I cant.
I have actually come across another issue though as stand alone.  I will be crteating a new thread shortly to address it.
