www.ti.com/litv/zip/swrc257
例子中有T4的PWM基本例子。现在timer都留给客户自己实现了,如果需要可以google下以前版本zigbee协议栈,有借鉴作用
- Filename: hal_timer.c
- Revised: $Date: 2007-11-01 08:44:53 -0700 (Thu, 01 Nov 2007) $
- Revision: $Revision: 15821 $
- Description: This file contains the interface to the Timer Service.
- Copyright 2006-2007 Texas Instruments Incorporated. All rights reserved.
- IMPORTANT: Your use of this Software is limited to those specific rights
- granted under the terms of a software license agreement between the user
- who downloaded the software, his/her employer (which must be your employer)
- and Texas Instruments Incorporated (the "License"). You may not use this
- Software unless you agree to abide by the terms of the License. The License
- limits your use, and you acknowledge, that the Software may not be modified,
- copied or distributed unless embedded on a Texas Instruments microcontroller
- or used solely and exclusively in conjunction with a Texas Instruments radio
- frequency transceiver, which is integrated into your product. Other than for
- the foregoing purpose, you may not use, reproduce, copy, prepare derivative
- works of, modify, distribute, perform, display or sell this Software and/or
- its documentation for any purpose.
- YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
- PROVIDED 揂S IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
- INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
- NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
- TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
- NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
- LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
- INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
- OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
- OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
- (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
- Should you have any questions regarding your right to use this Software,
- contact Texas Instruments Incorporated at www.TI.com.
- NOTE: The following mapping is done between the logical timer
- names defined in HAL_TIMER.H and the physical HW timer.
- HAL_TIMER_0 --> HW Timer 3 (8-bits)
- HAL_TIMER_2 --> HW Timer 4 (8-bits)
- HAL_TIMER_3 --> HW Timer 1 (16-bits)
- NOTE: The timer code assumes only one channel, CHANNEL 0, is used
- for each timer. There is currently no support for other
- channels.
- NOTE: Only Output Compare Mode is supported. There is no provision
- to support Input Capture Mode.
- NOTE: There is no support to map the output of the timers to a
- physical I/O pin
- * INCLUDES
- #include "hal_mcu.h"
- #include "hal_defs.h"
- #include "hal_types.h"
- #include "hal_timer.h"
- * MACROS
- * CONSTANTS
- #define HW_TIMER_1 0x00
- #define HW_TIMER_3 0x01
- #define HW_TIMER_4 0x02
- #define HW_TIMER_INVALID 0x03
- #define HW_TIMER_MAX 0x03
- #define IEN1_T1IE 0x02 /* Timer1 Interrupt Enable */
- #define IEN1_T3IE 0x08 /* Timer3 Interrupt Enable */
- #define IEN1_T4IE 0x10 /* Timer4 Interrupt Enable */
- #define T1CTL_CH2IF 0x80
- #define T1CTL_CH1IF 0x40
- #define T1CTL_CH0IF 0x20
- #define T1CTL_OVFIF 0x10
- #define TIMIF_T1OVFIM 0x40
- #define TIMIF_T4CH1IF 0x20
- #define TIMIF_T4CH0IF 0x10
- #define TIMIF_T4OVFIF 0x08
- #define TIMIF_T3CH1IF 0x04
- #define TIMIF_T3CH0IF 0x02
- #define TIMIF_T3OVFIF 0x01
- #define T34CTL_OVFIM 0x80
- #define T134CCTL_IM 0x40 /* Interrupt Mask */
- #define T134CCTL_CMP_BITS 0x38 /* Bits[5:3] == CMP[2:0] */
- #define T134CCTL_MODE 0x04 /* Capture(0)/Compare(1) mode */
- #define T134CCTL_CAP_BITS 0x03 /* Bits[1:0] == CAP[1:0] */
- #define T134CCTL_CMP_OC 0x18 /* Set output on compare, clear at 0 */
- #define T134CCTL_CAP_RE 0x01 /* Set input capture on rising edge */
- /* Timer clock pre-scaler definitions for 16bit timer1 */
- #define HAL_TIMER1_16_TC_DIV1 0x00 /* No clock pre-scaling */
- #define HAL_TIMER1_16_TC_DIV8 0x04 /* Clock pre-scaled by 8 */
- #define HAL_TIMER1_16_TC_DIV32 0x08 /* Clock pre-scaled by 32 */
- #define HAL_TIMER1_16_TC_DIV128 0x0c /* Clock pre-scaled by 128 */
- #define HAL_TIMER1_16_TC_BITS 0x0c /* Bits 3:2 */
- /* Timer clock pre-scaler definitions for 8bit timer3 and timer4 */
- #define HAL_TIMER34_8_TC_DIV1 0x00 /* No clock pre-scaling */
- #define HAL_TIMER34_8_TC_DIV2 0x20 /* Clock pre-scaled by 2 */
- #define HAL_TIMER34_8_TC_DIV4 0x40 /* Clock pre-scaled by 4 */
- #define HAL_TIMER34_8_TC_DIV8 0x60 /* Clock pre-scaled by 8 */
- #define HAL_TIMER34_8_TC_DIV16 0x80 /* Clock pre-scaled by 16 */
- #define HAL_TIMER34_8_TC_DIV32 0xA0 /* Clock pre-scaled by 32 */
- #define HAL_TIMER34_8_TC_DIV64 0xC0 /* Clock pre-scaled by 64 */
- #define HAL_TIMER34_8_TC_DIV128 0xE0 /* Clock pre-scaled by 128 */
- #define HAL_TIMER34_8_TC_BITS 0xE0 /* Bits 7:5 */
- /* Operation Mode definitions */
- #define HAL_TIMER1_OPMODE_STOP 0x00 /* Free Running Mode, Count from 0 to Max */
- #define HAL_TIMER1_OPMODE_FREERUN 0x01 /* Free Running Mode, Count from 0 to Max */
- #define HAL_TIMER1_OPMODE_MODULO 0x02 /* Modulo Mode, Count from 0 to CompareValue */
- #define HAL_TIMER1_OPMODE_BITS 0x03 /* Bits 1:0 */
- #define HAL_TIMER34_START 0x10 /* Timer3 and Timer4 have separate Start bit */
- #define HAL_TIMER34_OPMODE_FREERUN 0x00 /* Free Running Mode, Count from 0 to Max */
- #define HAL_TIMER34_OPMODE_MODULO 0x02 /* Modulo Mode, Count from 0 to CompareValue */
- #define HAL_TIMER34_OPMODE_BITS 0x03 /* Bits 1:0 */
- #define HAL_TIMER_MODE_STOP 0x03
- /* Prescale settings */
- #define HAL_TIMER1_16_PRESCALE HAL_TIMER1_16_TC_DIV128
- #define HAL_TIMER1_16_PRESCALE_VAL 128
- #define HAL_TIMER3_8_PRESCALE HAL_TIMER34_8_TC_DIV128
- #define HAL_TIMER3_8_PRESCALE_VAL 128
- #define HAL_TIMER4_8_PRESCALE HAL_TIMER34_8_TC_DIV128
- #define HAL_TIMER4_8_PRESCALE_VAL 128
- /* Clock settings */
- #define HAL_TIMER_16MHZ 16
- #define HAL_TIMER_32MHZ 32
- /* Default all timers to use channel 0 */
- #define TCHN_T1CCTL &(X_T1CCTL0)
- #define TCHN_T1CCL &(X_T1CC0L)
- #define TCHN_T1CCH &(X_T1CC0H)
- #define TCNH_T1OVF &(X_TIMIF)
- #define TCHN_T1OVFBIT TIMIF_T1OVFIM
- #define TCHN_T1INTBIT IEN1_T1IE
- #define TCHN_T3CCTL &(X_T3CCTL0)
- #define TCHN_T3CCL &(X_T3CC0)
- #define TCHN_T3CCH &(X_T3CC0)
- #define TCNH_T3OVF &(X_T3CTL)
- #define TCHN_T3OVFBIT T34CTL_OVFIM
- #define TCHN_T3INTBIT IEN1_T3IE
- #define TCHN_T4CCTL &(X_T4CCTL0)
- #define TCHN_T4CCL &(X_T4CC0)
- #define TCHN_T4CCH &(X_T4CC0)
- #define TCNH_T4OVF &(X_T4CTL)
- #define TCHN_T4OVFBIT T34CTL_OVFIM
- #define TCHN_T4INTBIT IEN1_T4IE
- * TYPEDEFS
- typedef struct
- bool configured;
- bool intEnable;
- uint8 opMode;
- uint8 channel;
- uint8 channelMode;
- uint8 prescale;
- uint8 prescaleVal;
- uint8 clock;
- halTimerCBack_t callBackFunc;
- ] halTimerSettings_t;
- typedef struct
- uint8 volatile XDATA *TxCCTL;
- uint8 volatile XDATA *TxCCH;
- uint8 volatile XDATA *TxCCL;
- uint8 volatile XDATA *TxOVF;
- uint8 ovfbit;
- uint8 intbit;
- ] halTimerChannel_t;
- * GLOBAL VARIABLES
- static halTimerSettings_t halTimerRecord[HW_TIMER_MAX];
- static halTimerChannel_t halTimerChannel[HW_TIMER_MAX];
- * FUNCTIONS - External
- * FUNCTIONS - Local
- uint8 halTimerSetCount (uint8 cc2430id, uint32 timePerTick);
- uint8 halTimerSetPrescale (uint8 cc2430id, uint8 prescale);
- uint8 halTimerSetOpMode (uint8 cc2430id, uint8 opMode);
- uint8 halTimerSetChannelMode (uint8 cc2430id, uint8 channelMode);
- void halTimerSendCallBack (uint8 timerId, uint8 channel, uint8 channelMode);
- uint8 halTimerRemap (uint8 timerId);
- void halProcessTimer1 (void);
- void halProcessTimer3 (void);
- void halProcessTimer4 (void);
- * FUNCTIONS - API
- * @fn HalTimerInit
- * @brief Initialize Timer Service
- * @param None
- * @return None
- void HalTimerInit (void)
- T1CCTL0 = 0; /* Make sure interrupts are disabled */
- T1CCTL1 = 0; /* Make sure interrupts are disabled */
- T1CCTL2 = 0; /* Make sure interrupts are disabled */
- T3CCTL0 = 0; /* Make sure interrupts are disabled */
- T3CCTL1 = 0; /* Make sure interrupts are disabled */
- T4CCTL0 = 0; /* Make sure interrupts are disabled */
- T4CCTL1 = 0; /* Make sure interrupts are disabled */
- /* Setup prescale & clock for timer0 */
- halTimerRecord[HW_TIMER_1].prescale = HAL_TIMER1_16_PRESCALE;
- halTimerRecord[HW_TIMER_1].clock = HAL_TIMER_32MHZ;
- halTimerRecord[HW_TIMER_1].prescaleVal = HAL_TIMER1_16_PRESCALE_VAL;
- /* Setup prescale & clock for timer2 */
- halTimerRecord[HW_TIMER_3].prescale = HAL_TIMER3_8_PRESCALE;
- halTimerRecord[HW_TIMER_3].clock = HAL_TIMER_32MHZ;
- halTimerRecord[HW_TIMER_3].prescaleVal = HAL_TIMER3_8_PRESCALE_VAL;
- /* Setup prescale & clock for timer3 */
- halTimerRecord[HW_TIMER_4].prescale = HAL_TIMER4_8_PRESCALE;
- halTimerRecord[HW_TIMER_4].clock = HAL_TIMER_32MHZ;
- halTimerRecord[HW_TIMER_4].prescaleVal = HAL_TIMER4_8_PRESCALE_VAL;
- /* Setup Timer1 Channel structure */
- halTimerChannel[HW_TIMER_1].TxCCTL = TCHN_T1CCTL;
- halTimerChannel[HW_TIMER_1].TxCCL = TCHN_T1CCL;
- halTimerChannel[HW_TIMER_1].TxCCH = TCHN_T1CCH;
- halTimerChannel[HW_TIMER_1].TxOVF = TCNH_T1OVF;
- halTimerChannel[HW_TIMER_1].ovfbit = TCHN_T1OVFBIT;
- halTimerChannel[HW_TIMER_1].intbit = TCHN_T1INTBIT;
- /* Setup Timer3 Channel structure */
- halTimerChannel[HW_TIMER_3].TxCCTL = TCHN_T3CCTL;
- halTimerChannel[HW_TIMER_3].TxCCL = TCHN_T3CCL;
- halTimerChannel[HW_TIMER_3].TxCCH = TCHN_T3CCH;
- halTimerChannel[HW_TIMER_3].TxOVF = TCNH_T3OVF;
- halTimerChannel[HW_TIMER_3].ovfbit = TCHN_T3OVFBIT;
- halTimerChannel[HW_TIMER_3].intbit = TCHN_T3INTBIT;
- /* Setup Timer4 Channel structure */
- halTimerChannel[HW_TIMER_4].TxCCTL = TCHN_T4CCTL;
- halTimerChannel[HW_TIMER_4].TxCCL = TCHN_T4CCL;
- halTimerChannel[HW_TIMER_4].TxCCH = TCHN_T4CCH;
- halTimerChannel[HW_TIMER_4].TxOVF = TCNH_T4OVF;
- halTimerChannel[HW_TIMER_4].ovfbit = TCHN_T4OVFBIT;
- halTimerChannel[HW_TIMER_4].intbit = TCHN_T4INTBIT;
- * @fn HalTimerConfig
- * @brief Configure the Timer Serivce
- * @param timerId - Id of the timer
- * opMode - Operation mode
- * channel - Channel where the counter operates on
- * channelMode - Mode of that channel
- * prescale - Prescale of the clock
- * cBack - Pointer to the callback function
- * @return Status of the configuration
- uint8 HalTimerConfig (uint8 timerId, uint8 opMode, uint8 channel, uint8 channelMode,
- bool intEnable, halTimerCBack_t cBack)
- uint8 hwtimerid;
- hwtimerid = halTimerRemap (timerId);
- if ((opMode & HAL_TIMER_MODE_MASK) && (timerId < HAL_TIMER_MAX) &&
- (channelMode & HAL_TIMER_CHANNEL_MASK) && (channel & HAL_TIMER_CHANNEL_MASK))
- halTimerRecord[hwtimerid].configured = TRUE;
- halTimerRecord[hwtimerid].opMode = opMode;
- halTimerRecord[hwtimerid].channel = channel;
- halTimerRecord[hwtimerid].channelMode = channelMode;
- halTimerRecord[hwtimerid].intEnable = intEnable;
- halTimerRecord[hwtimerid].callBackFunc = cBack;
- else
- return HAL_TIMER_PARAMS_ERROR;
- return HAL_TIMER_OK;
- * @fn HalTimerStart
- * @brief Start the Timer Service
- * @param timerId - ID of the timer
- * timerPerTick - number of micro sec per tick, (ticks x prescale) / clock = usec/tick
- * @return Status - OK or Not OK
- uint8 HalTimerStart (uint8 timerId, uint32 timePerTick)
- uint8 hwtimerid;
- if (halTimerRecord[hwtimerid].configured)
- halTimerSetCount (hwtimerid, timePerTick);
- halTimerSetPrescale (hwtimerid, halTimerRecord[hwtimerid].prescale);
- halTimerSetOpMode (hwtimerid, halTimerRecord[hwtimerid].opMode);
- halTimerSetChannelMode (hwtimerid, halTimerRecord[hwtimerid].channelMode);
- if (hwtimerid == HW_TIMER_3)
- T3CTL |= HAL_TIMER34_START;
- if (hwtimerid == HW_TIMER_4)
- T4CTL |= HAL_TIMER34_START;
- HalTimerInterruptEnable (hwtimerid, halTimerRecord[hwtimerid].channelMode,
- halTimerRecord[hwtimerid].intEnable);
- else
- return HAL_TIMER_NOT_CONFIGURED;
- * @fn HalTimerTick
- * @brief Check the counter for expired counter.
- * @param None
- * @return None
- void HalTimerTick (void)
- if (!halTimerRecord[HW_TIMER_1].intEnable)
- halProcessTimer1 ();
- if (!halTimerRecord[HW_TIMER_3].intEnable)
- halProcessTimer3 ();
- if (!halTimerRecord[HW_TIMER_4].intEnable)
- halProcessTimer4 ();
- * @fn HalTimerStop
- * @brief Stop the Timer Service
- uint8 HalTimerStop (uint8 timerId)
- uint8 hwtimerid;
- switch (hwtimerid)
- case HW_TIMER_1:
- halTimerSetOpMode(HW_TIMER_1, HAL_TIMER_MODE_STOP);
- break;
- case HW_TIMER_3:
- T3CTL &= ~(HAL_TIMER34_START);
- break;
- case HW_TIMER_4:
- T4CTL &= ~(HAL_TIMER34_START);
- break;
- default:
- return HAL_TIMER_INVALID_ID;
- * @fn halTimerSetCount
- * @param hwtimerid - ID of the timer
- * timerPerTick - Number micro sec per ticks
- uint8 halTimerSetCount (uint8 hwtimerid, uint32 timePerTick)
- uint16 count;
- uint8 high, low;
- /* Load count = ((sec/tick) x clock) / prescale */
- count = (uint16)((timePerTick * halTimerRecord[hwtimerid].clock) / halTimerRecord[hwtimerid].prescaleVal);
- high = (uint8) (count >> 8);
- low = (uint8) count;
- *(halTimerChannel[hwtimerid].TxCCH) = high;
- *(halTimerChannel[hwtimerid].TxCCL) = low;
- * @fn halTimerSetPrescale
- uint8 halTimerSetPrescale (uint8 hwtimerid, uint8 prescale)
- case HW_TIMER_1:
- T1CTL &= ~(HAL_TIMER1_16_TC_BITS);
- T1CTL |= prescale;
- break;
- case HW_TIMER_3:
- T3CTL &= ~(HAL_TIMER34_8_TC_BITS);
- T3CTL |= prescale;
- break;
- case HW_TIMER_4:
- T4CTL &= ~(HAL_TIMER34_8_TC_BITS);
- T4CTL |= prescale;
- break;
- default:
- * @fn halTimerSetOpMode
- * @brief Setup operate modes
- * opMode - operation mode of the timer
- uint8 halTimerSetOpMode (uint8 hwtimerid, uint8 opMode)
- /* Load Waveform Generation Mode */
- switch (opMode)
- case HAL_TIMER_MODE_NORMAL:
- case HW_TIMER_1:
- T1CTL &= ~(HAL_TIMER1_OPMODE_BITS);
- T1CTL |= HAL_TIMER1_OPMODE_FREERUN;
- break;
- case HW_TIMER_3:
- T3CTL &= ~(HAL_TIMER34_OPMODE_BITS);
- T3CTL |= HAL_TIMER34_OPMODE_FREERUN;
- break;
- case HW_TIMER_4:
- T4CTL &= ~(HAL_TIMER34_OPMODE_BITS);
- T4CTL |= HAL_TIMER34_OPMODE_FREERUN;
- break;
- default:
- break;
- case HAL_TIMER_MODE_CTC:
- case HW_TIMER_1:
- T1CTL |= HAL_TIMER1_OPMODE_MODULO;
- break;
- case HW_TIMER_3:
- T3CTL |= HAL_TIMER34_OPMODE_MODULO;
- break;
- case HW_TIMER_4:
- T4CTL |= HAL_TIMER34_OPMODE_MODULO;
- break;
- default:
- break;
- case HAL_TIMER_MODE_STOP:
- if (hwtimerid == HW_TIMER_1)
- T1CTL |= HAL_TIMER1_OPMODE_STOP;
- break;
- default:
- return HAL_TIMER_INVALID_OP_MODE;
- * @fn halTimerSetChannelMode
- * @brief Setup channel modes. Currently, only output compare mode is supported. Input capture
- * mode is NOT supported. Additionally, mapping timer channel inputs/outputs to I/O pins
- * is NOT supported.
- * channelMode - channel mode of the timer
- uint8 halTimerSetChannelMode (uint8 hwtimerid, uint8 channelMode)
- switch (channelMode)
- case HAL_TIMER_CH_MODE_OUTPUT_COMPARE:
- *(halTimerChannel[hwtimerid].TxCCTL) &= ~(T134CCTL_CMP_BITS);
- *(halTimerChannel[hwtimerid].TxCCTL) |= (T134CCTL_CMP_OC | T134CCTL_MODE);
- break;
- case HAL_TIMER_CH_MODE_INPUT_CAPTURE: /* Not Supported */
- *(halTimerChannel[hwtimerid].TxCCTL) &= ~(T134CCTL_CAP_BITS | T134CCTL_MODE);
- *(halTimerChannel[hwtimerid].TxCCTL) |= T134CCTL_CAP_RE;
- break;
- default:
- return HAL_TIMER_INVALID_CH_MODE;
- * @fn HalTimerInterruptEnable
- * enable - TRUE or FALSE
- uint8 HalTimerInterruptEnable (uint8 hwtimerid, uint8 channelMode, bool enable)
- case HAL_TIMER_CH_MODE_OVERFLOW:
- if (enable)
- *(halTimerChannel[hwtimerid].TxOVF) |= halTimerChannel[hwtimerid].ovfbit;
- else
- *(halTimerChannel[hwtimerid].TxOVF) &= ~(halTimerChannel[hwtimerid].ovfbit);
- break;
- if (enable)
- *(halTimerChannel[hwtimerid].TxCCTL) |= T134CCTL_IM;
- else
- *(halTimerChannel[hwtimerid].TxCCTL) &= ~(T134CCTL_IM);
- break;
- default:
- if (halTimerRecord[hwtimerid].intEnable)
- IEN1 |= halTimerChannel[hwtimerid].intbit;
- else
- IEN1 &= ~(halTimerChannel[hwtimerid].intbit);
- * @fn halTimerSendCallBack
- * @brief Send Callback back to the caller
- * channel - channel where the interrupt occurs
- * @return None
- uint8 hwtimerid;
- if (halTimerRecord[hwtimerid].callBackFunc)
- (halTimerRecord[hwtimerid].callBackFunc) (timerId, channel, channelMode);
- * @fn halTimerRemap
- * @brief Maps API HAL_TIMER_ID to HW Timer ID.
- * HAL_TIMER_0 --> HW Timer 3
- * HAL_TIMER_2 --> HW Timer 4
- * HAL_TIMER_3 --> HW Timer 1
- * @return HW timer ID
- switch (timerId)
- case HAL_TIMER_0:
- return HW_TIMER_3;
- case HAL_TIMER_2:
- return HW_TIMER_4;
- case HAL_TIMER_3:
- return HW_TIMER_1;
- default:
- return HW_TIMER_INVALID;
- * @fn halProcessTimer1
- * @brief Processes Timer 1 Events.
- * @param
- * @return
- if (halTimerRecord[halTimerRemap(HAL_TIMER_3)].channelMode == HAL_TIMER_CH_MODE_OUTPUT_COMPARE)
- if (T1CTL & T1CTL_CH0IF)
- T1CTL &= ~(T1CTL_CH0IF);
- halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_A, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- if (T1CTL & T1CTL_CH1IF)
- T1CTL &= ~(T1CTL_CH1IF);
- halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_B, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- if (T1CTL & T1CTL_CH2IF)
- T1CTL &= ~(T1CTL_CH2IF);
- halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_C, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- else if (halTimerRecord[halTimerRemap(HAL_TIMER_3)].channelMode == HAL_TIMER_CH_MODE_OVERFLOW)
- if (T1CTL & T1CTL_OVFIF)
- T1CTL &= ~(T1CTL_OVFIF);
- halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_SINGLE, HAL_TIMER_CH_MODE_OVERFLOW);
- * @fn halProcessTimer3
- * @brief Processes Timer 3 Events.
- * @param
- * @return
- if (halTimerRecord[halTimerRemap(HAL_TIMER_0)].channelMode == HAL_TIMER_CH_MODE_OUTPUT_COMPARE)
- if (TIMIF & TIMIF_T3CH0IF)
- TIMIF &= ~(TIMIF_T3CH0IF);
- halTimerSendCallBack (HAL_TIMER_0, HAL_TIMER_CHANNEL_A, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- if (TIMIF & TIMIF_T3CH1IF)
- TIMIF &= ~(TIMIF_T3CH1IF);
- halTimerSendCallBack (HAL_TIMER_0, HAL_TIMER_CHANNEL_B, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- else if (halTimerRecord[halTimerRemap(HAL_TIMER_0)].channelMode == HAL_TIMER_CH_MODE_OVERFLOW)
- if (TIMIF & TIMIF_T3OVFIF)
- TIMIF &= ~(TIMIF_T3OVFIF);
- halTimerSendCallBack (HAL_TIMER_0, HAL_TIMER_CHANNEL_SINGLE, HAL_TIMER_CH_MODE_OVERFLOW);
- * @fn halProcessTimer4
- * @brief Processes Timer 4 Events.
- * @param
- * @return
- if (halTimerRecord[halTimerRemap(HAL_TIMER_2)].channelMode == HAL_TIMER_CH_MODE_OUTPUT_COMPARE)
- if (TIMIF & TIMIF_T4CH0IF)
- TIMIF &= ~(TIMIF_T4CH0IF);
- halTimerSendCallBack (HAL_TIMER_2, HAL_TIMER_CHANNEL_A, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- if (TIMIF & TIMIF_T4CH1IF)
- TIMIF &= ~(TIMIF_T4CH1IF);
- halTimerSendCallBack (HAL_TIMER_2, HAL_TIMER_CHANNEL_B, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
- else if (halTimerRecord[halTimerRemap(HAL_TIMER_2)].channelMode == HAL_TIMER_CH_MODE_OVERFLOW)
- if (TIMIF & TIMIF_T4OVFIF)
- TIMIF &= ~(TIMIF_T4OVFIF);
- halTimerSendCallBack (HAL_TIMER_2, HAL_TIMER_CHANNEL_SINGLE, HAL_TIMER_CH_MODE_OVERFLOW);
- * INTERRUPT SERVICE ROUTINE
- * @fn halTimer1Isr
- * @brief Timer 1 ISR
- * @param
- * @return
- HAL_ISR_FUNCTION( halTimer1Isr, T1_VECTOR )
- * @fn halTimer3Isr
- * @brief Timer 3 ISR
- * @param
- * @return
- HAL_ISR_FUNCTION( halTimer3Isr, T3_VECTOR )
- * @fn halTimer4Isr
- * @brief Timer 4 ISR
- * @param
- * @return
- HAL_ISR_FUNCTION( halTimer4Isr, T4_VECTOR )
- channels.
- physical I/O pin
- * INCLUDES
- * MACROS
- * CONSTANTS
- * TYPEDEFS
- typedef struct
- bool configured;
- bool intEnable;
- uint8 opMode;
- uint8 channel;
- uint8 prescale;
- uint8 clock;
- typedef struct
- uint8 ovfbit;
- uint8 intbit;
- * FUNCTIONS - API
- * @param None
- * @return None
- uint8 hwtimerid;
- else
- uint8 hwtimerid;
- else
- * @param None
- * @return None
- uint8 hwtimerid;
- case HW_TIMER_1:
- break;
- case HW_TIMER_3:
- break;
- case HW_TIMER_4:
- break;
- default:
- uint16 count;
- uint8 high, low;
- case HW_TIMER_1:
- break;
- case HW_TIMER_3:
- break;
- case HW_TIMER_4:
- break;
- default:
- switch (opMode)
- case HW_TIMER_1:
- break;
- case HW_TIMER_3:
- break;
- case HW_TIMER_4:
- break;
- default:
- break;
- case HW_TIMER_1:
- break;
- case HW_TIMER_3:
- break;
- case HW_TIMER_4:
- break;
- default:
- break;
- break;
- default:
- break;
- break;
- default:
- if (enable)
- else
- break;
- if (enable)
- else
- break;
- default:
- else
- * @return None
- uint8 hwtimerid;
- switch (timerId)
- case HAL_TIMER_0:
- case HAL_TIMER_2:
- case HAL_TIMER_3:
- default:
- * @param
- * @return
- * @param
- * @return
- * @param
- * @return
- * @param
- * @return
- * @param
- * @return
- * @param
- * @return
